Question about AFG Venetia Crib
Replace front right post
When changing the crib sheet, the front right post splintered and broke. The front cannot slide up or down. I cannot find infomation about ordering the new piece immediately.
0 characters
1 Points
I.need.instructions for the afg baby furniture.009e expresso athena naomi convertible crib 009
Tips a safety crib must have:
  • No missing, loose, broken, or improperly-installed screws, brackets, or other hardware on the crib or the mattress support.
  • No much more than 2 3/8 inches between crib slats so a baby's physique cannot fit via the slats.
  • A firm, snug-fitting mattress so a infant cannot get trapped between the mattress and also the side of the crib.
  • No corner posts more than 1/16 of an inch above the finish panels (unless they are more than 16 inches high for a canopy) so a baby can't catch clothing and strangle.
  • No cutout areas on the headboard or foot board so a baby's head cannot get trapped.
  • A mattress assistance that doesn't effortlessly pull apart from the corner posts so a infant can't get trapped in between mattress and crib.
  • No cracked or peeling paint to stop lead poisoning.
  • No splinters or rough edges.
Jan 20, 2014 | AFG Baby Furniture 009E Espresso Athena...
How to I take apart the drop down side of this crib. I had it installed and can't figure it out
This is tricky but I have put it together and taken it apart countless times (3 kids, 2 houses and everyone switching rooms). All of the screws keeping the crib together need to be as loose as possible without the crib coming apart. I found it easiest to have someone help so they can help hold the crib. It's important not to pull the drop side apart as it will break the plastic slides (I've done this and had to replace them). Have your helper hold one side of the drop crib right against the side piece of the crib and slide the drop side down to detach it from the side your helper isn't on. once this side is detached do the same for the opposite side. On the crib side that attaches to the drop side is a "screw" that slides down the plastic slide and a "peg" at the bottom. I always get the peg out of the track and then you can slide the screw all the way down the slide to get it out.
Jan 04, 2011 | Cara Mia Louise Crib
I have a Storkcraft baby crib model number 704873, the problem is one of the top recieving guide brackets for the non-sliding back side of the crib is broke. I need to find a replacement. Can you point me...
You can order parts from StorkCraft Baby from the following link:
You can fill out the online order form above or you can call them at
877-274-0277 M-F from 7:00 AM to 3:00 OM PST.
Be advices that StorkCraft has issued a recall on dropside cribs. They offer a free conversion kits to change the dropside cribs to non-dropside cribs.
You can view the recall and ordering information at the following link:
Jan 05, 2010 | Cribs, Cradles & Bassinets
How do I get parts?
Childdesigns has gone out of business so it may be rather difficult in locating parts. You could try posting on various buy/sell sites,or try secondhand shops,yardsales,etc.
Oct 14, 2009 | Childesigns Bellmont Crib
Upper guide broke on pottery barn sleigh crib.
Puchase the parts at they are identical to the original pbk ones. Worked for us and very reasonable!
Jan 16, 2009 | Pottery Barn Kids Espresso Sleigh
Have a Lullabye Crib - 28 yrs old, no instructions for reassembly
I have directions for the Lullabye Princeton Crib, Model 311146
that I purchased in 1993. It sounds like the same type of hardware
that allows the front rail (only) to move up and down, with springs
at the bottom to cushion the drop. If you think this might help you
and you want me to post these directions, just let me know.
Nov 19, 2008 | Cribs, Cradles & Bassinets
Trying to find replacement parts
Hi, replacement parts can be found on amazon, click here: Amazon com Storkcraft Baby crib parts and take a look. Wish you best of luck. Cheers
Sep 09, 2008 | Cribs, Cradles & Bassinets
Sliding latch/railing
Go to You can get hardware for any crib made in the US I think within the last 10 years. Hope this helps.
Aug 24, 2008 | Childesigns Dayton 21-815 Crib
Childesigns Ravello Crib
Try you local hardware store. ACE Hardware or a True Value.
If you think that the parts are repairable you might ask the hardware folks for a glue that will bond that material to itself. Plastic Welder brand glue usually works well for this.
Jan 21, 2008 | Childesigns Ravello Crib
AFG Venetia Crib Logo
14 people viewed this question
Top AFG Cribs, Cradles & Bassinets Experts
tina gallow
Jennifer Rock
Jennifer Rock
Are you an AFG Crib, Cradle and Bassinet Expert? Answer questions, earn points and help others
