Question about Panasonic CT-27G14 27" TV
Picture bounce This new 27" panasonic tv works fine except the picture bounces nonstop.Any help would be greatly appreciated.This was bought used so no warrenty is avialable.
  • adia79
    adia79 May 10, 2012
    I know you posted this six years ago but I'm hoping you'll see this comment. I'm having the exact same problem with my Panasonic TV. Did you ever get it fixed or did you just buy a new one?
    Problem Solver:
  • 11 Answers
I think that maybe your horizontal hold is messed up. If there is anyway you can change it with a button or dial or something on the TV that would do it but if there isn't one then there is nothing you can do but to take it to a repairman but it is really expensive. You'll probably spend more on fixing it than you for the TV itself.You're better of to get a new television.
Posted on Jan 15, 2007
Sanyo Sound going in and out
the first thing you should try is to connect exturnal speakers, if they work fine, then use them, as the wireing harness has a bad solder joint (inside the TV) you will need to go to yoru onscreen menu to activate the exturnal speakers. If this still occurs, then there is a major inturnal fault, with luck it is still under warrenty, otherwise it will be costly to fix. Due to teh high number if flatscreen failures I and other tech friends of mine have run into, we all agree this is the one case where extended warrentys are well worth the investment.
Feb 08, 2010 | Sanyo DS27800 27" TV
Magnavox Demo TV
Could you please provide the model number of your TV?
It appears that the TV demo was activated by accident.
Jul 23, 2008 | Philips Magnavox 27MS343S 27" TV
Panasonic 27'' tube television
There are some components in the vertical deflection circuit area that are failing. An experienced TV service man should be able to troubleshoot and repair this for you. It could take several hours of labour cost.
Jerry G.
Apr 26, 2009 | Panasonic CT-36D12D 36" TV
Picture but no sound
press mute button on tv remote
Oct 20, 2008 | Zenith B27A11Z 27" TV
Magnavox TR2510C101
Pressing the volume up and volume
down buttons on the set simultaneously should work.
Good Luck.
Jul 28, 2008 | Philips Magnavox 27MS343S 27" TV
Just a line on the screen?
Your tv has a failure in the vertical circuit. Most likley since you explained that it was coming in and out you could fix it by Resoldering the connections on the vertical output IC. Replacing the vertical output IC would be your next step after this.
-Josh
Mar 04, 2008 | Panasonic CT-2784VY 27" TV
Buzzing sound, no picture on my Panasonic TV
You might have a short causing the set not to start. Probably in the horizontal/high voltage circuit. The buzzing sound that you're hearing is the power supply overloaded. Stargazer
Apr 22, 2007 | Panasonic CT-27G23 27" TV
Picture on Panasonic tv intermittently becomes striated and bottom half of picture shows on top half of screen
Hello! What you're describing sounds like a vertical deflection problem if it also occurs when you're watching a TV program. This type of trouble is a component failing in the vertical circuit of your set. A loose solder connection could cause this. On the other hand, if it just happens when you run the VCR, your problem could be somewhere in the tape drive mechanism or possibly a bad tape. Things like slipping clutches,bad belts sticking guide rollers are a few things that will cause this in a VCR. You need to have a tech check it for you. Hope this gives you some help. Stargazer
Feb 03, 2007 | Panasonic CT-34WX54 34" TV
Panasonic CT-27G14 27" TV Logo
111 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
