Question about Husqvarna Designer I
Designer 1 Embroidery Bobbin problem
Hi
Sometimes when doing embroidery on Designer 1 I have problems with the bobbin thread coming through (currently using pre-wound ones bought from Husqvarna dealer in England). I was doing some embroidery today and everything was okay until I had to change the bobbin. As soon as I inserted a new bobbin the bobbin thread showed through on the other side again.
    Sniper:
  • 87 Answers
Designer 1 bobbin case tension adjustment:
When the bobbin runs out, sometimes it bends the bobbin case tension spring. Then tension is too light. Take the bobbin case out of the machine. Tie the loose bobbin thread to the Designer 1 needle plate. Insert the bobbin in the bobbin case. Here’s the tricky part set the bobbin case on the table as if it’s in the machine (Bobbin is visible and sitting horizontal to table top) threaded as if sewing and loose end tied to needle plate (that is removed from the machine). Lift the bobbin case off the table rotate it so that the flat side of the bobbin are vertical to the table and no longer horizontal. Have the bobbin case oriented so that the thread coming out of the bobbin case sprint (slot area where it is put for sewing) is at the top. Lift it high enough that the needle plate is lifted from the table. It should not release thread unless you shake it gently and then a very small amount of thread. The needle plate is the exact weight resistance your bobbin case should have on the thread.
Posted on Mar 18, 2009
    Novelist:
  • Husqvarna Expert
  • 371 Answers
Clean bobbin area and thread cutter area, removing lint and thread.
Check bobbin tension, should get slight resistance when pulling thread.
Make sure the bobbin is unwinding counter clockwise when going through the bobbin case.
Remove fabric. Pull extra long bobbin thread (about 3 inches). Hold upper thread tail in left hand, turn handwheel toward you for 1 revolution. Is the bobbin thread caught by the top thread and pulled through the opening of the needle plate?
Could be needle/hook timing. With machine off do the following to check timing -
remove bobbin and bobbin case.
push needle all the way to the left.
Turn handwheel toward you watching the needle and bobbin housing hook. The point of the hook should line up right above the eye of the needle.
If you are still having problems, take to an authorized Husqvarna Viking dealer for service or have them send to Husqvarna Viking (SVP) Technical Service Dept for repair. A list of dealers close to you can be found at the Husqvarna Viking website - http://www.husqvarnaviking.com/us
Good luck.
Posted on Sep 26, 2009
Why doesn't the machine pick up the bobbin?
You may have fuzz in your bobbin case or under the plate. If you have canned air, spray it out. Are you using a pre-wound bobbin or one you wound yourself. I've found pre-wounds to be the best. Make sure your thread is pulled thru the bobbin case correctly and your needle up top is threaded correctly too. It's real easy to miss either one. Also, be sure to use a good backing when using fuzzy fabric. What size needle are you using. Too small of a needle may cause this also. For standard embroidery or sewing usually use an 11. Hope maybe this will help. Kindest regards,
Jody
Apr 20, 2015 | Singer Quantum XL-1000 Computerized Sewing...
Why is thread is making multiple loops around bobbin
are you using pre-wound bobbins? or bobbins you've wound yourself? they might be too full or over wound (too much thread) this happens with pre-wound or some you've wound yourself. Also make sure you are loading the bobbin correctly. You also might try another bobbin, as sometimes they can get warped if they are the plastic kind.
Jun 27, 2014 | Singer 4423 Sewing Machine
Viking Designer SE-Limited Edition 43 hours of sewing. bobbin thread comes up around edges of desing
try changing the needle
check for burrs in the needle plate area & bobbin area
check also the top thread tension
Mar 12, 2012 | Husqvarna Sewing Machines
Where can I locate the fuse<
The Pfaff 7570 Creative Designer is a computerized sewingand embroidery machine that has the ability to connect to the computer, andhave embroidery designs sent to the embroidery machine. The sewing andembroidery machine has many features, including hundreds of general sewingfunctions, a separate embroidery module, and on-screen editing features. TheCreative Designer 7570, manufactured in the 1990s, was the first sewing andembroidery combination machine ever made by Pfaff.
1. Usingthe Sewing Machine
1 Turn on your sewing machine using the "On"button located just below the turn wheel on the right side of the machine.Thread your Pfaff 7570. Note that Pfaff sewing machines thread from left toright, not right to left like other sewing machines. The upper tension discsshould be raised at their highest position while threading, and the presserfoot should be raised up until you thread the needle. Drop the presser footright before you thread the needle. The prevents thread problems during use. 2 Insert a full bobbin and retrieve the bobbin threadthrough the thread plate. Raise your sewing foot and needle to its highestposition; hold the needle thread taught with your left hand, lower the needleinto the thread plate using your right hand, and then raise the needle. As youraise the needle, the needle thread will catch the bobbin thread, and pull itup. There should be a loop of thread intertwined with the needle thread. Usetweezers, your finger, or a straight pin to retrieve the bobbin thread that isvisible through the thread plate, and pull it through the plate. 3 Place the fabric under the presser foot, and drop thepresser foot. Choose the stitch you want to use from the top stitch display,right above the top thread feed. Press the '0-9" button located on thesewing machine's front panel, and a display screen will come up. Input thethread number, and press the 'OK' button located on the sewing machine's frontpanel. The stitch will display, and you are ready to sew. Repeat Step 3 foreach stitch you want to use.
2. SettingUp the Embroidery Unit
1 Turn the sewing machine off. Take out the embroiderymachine unit, locate the connection bushing on the back of your embroideryunit, and match it up with the connection bushing on your sewing machine. Theconnection bushing should be located next to a yellow sticker on yourembroidery unit, and somewhat resembles a serial port on a computer. Slide theembroidery unit onto the sewing machine with the sewing machine turned off. Connectto the bushing carefully as you slide the embroidery unit onto the sewingmachine. Use your embroidery unit manual if you need assistance. 2 Insert an embroidery card. Your embroidery unitshould contain an embroidery card labeled embroidery card 1. Use that or useanother Pfaff 7570 card that you own. Turn on the sewing machine. 3 Open the bobbin case area just below the threadplate, and lower the feed dogs by pushing the feed dog switch to the right.Press the card button located on the front face of your sewing machine. Adisplay with pop up; choose embroidery designs or monogram and a new screenwill pop up with your design choices. Choose the design you want, and press"OK." A checklist screen appears. Do everything on the checklist, andpress "OK." Use your embroidery unit manual if you need help. 4 Start embroidery by pressing the foot pedal. At thistime, your hoop should already be attached to the embroidery unit becauseyou've already gone through the checklist. Your embroidery manual displayscolored picture diagrams that are very helpful in understanding everything inyour checklist menu.
Thanks for using fixya
Jul 31, 2011 | PfaFF Creative 7570
I have a designer 1 and the bobbin thread is showing on the top when I embroider. I have tried rewinding with the same thread I am using on the top, replacing the needle, cleaning the bobbin area,...
It sounds as though maybe the bobbin thread is not "clicked" into the tension slot correctly. You need to be sure it goes into the slot and you can hear/feel it seat itself in there. As a last resort, you can tighten the bobbin tension. Take the bobbin case out. On the side there is a recessed screw. If you think of it as a clock, turn the screw in no greater than 5 minute increments - to the right to tighten, to the left to loosen.
Is your machine sewing regular stitching (i.e. not embroidery, hoop off) okay or is the bobbin thread not right for that either? Next time you have your machine serviced, be sure to take in your embroidery unit too so the technician can set it up to be good for both ordinary sewing and for embroidery. I actually have a second bobbin case that I adjust if necessary for whatever project I'm working on that needs anything other than "default" setting for the bobbin. Thay way, I'm not messing about with the bobbin that has been set correctly by the technician but you can easily adjust your bobbin if it needs it. Just remember to put it back to "normal" when you are done.
Dec 02, 2010 | Husqvarna Designer I
I have a ce 100 and the bobbin thread comes up and gets into my embroidery pattern. how do i loosen the top tension to stop this from happening. my purple flower has white in it from the bobbin :(
Just an FYI-the bobbin thread needs to match your top thread. The majority of the thread that appears in the top of your embroidery actually IS the bobbin thread. The machine is working correctly. Don't use a bobbin full of white thread-instead, thread a bobbin with the color your doing the embroidery work in to match and you will have a perfectly beautiful embroidery.
Nov 11, 2010 | Singer CE-100 Futura Computerized Sewing...
How can I get rid of birdnesting? I am using
Bobbin thread for machine embroidery is recommended. It is usually 60 weight.
Embroidery Library is about the best when it comes to Techniques and Tips for machine embroidery and they address bird nesting here - http://www.emblibrary.com/EL/elprojects/SimpleProduct_ELP.aspx?CS_ProductID=PR1239&CS_Catalog=Elprojects
May 11, 2010 | Husqvarna Designer I
How to thread the bobbin on designer 1 the bobbin thread keeps coming to the top of embroidery
Easy as pie to thread the bobbin, look it up in your book. It even shows you pictures.
Feb 11, 2010 | Husqvarna Designer I
Needle up down moves the embroider
It's okay - it's supposed to do that! The Needle Down button has a different function when you are in Embroidery mode i.e. you have the emb. unit attached.
It moves the emb. arm forward for two reasons: so you can cut top-side jump stitches more easily between colour changes (you touch the button again and the emb. arm returns to under the needle so you can finish the design); and secondly so you can "park" the embroidery unit when you are finished. You can then turn the machine off, remove the emb. unit and replace it in the carry case. If you DON'T do this, the emb. arm is not in the right position to fit into the moulded carry case properly.
The Broken Thread message usually means that it has started the colour, but the thread has been pulled down underneath instead of making nice locked stitches. Hold onto the thread end until the machine has stopped and beeped for you to cut the thread. This usually solves that problem. Sometimes the thread gets pulled out of your hand so just back up the stitches a few and start over, holding the thread more tightly. Don't tug on the thread - just keep a firm grip.
Designer 1s often cut the bobbin thread too short so that it can't make those nice locked stitches when it starts. You need to take off the hoop, open up the bobbin cover and use your stylus, the tip of a pair of scissors, tweezers (whatever is to hand) to pull the bobbin thread out a little. Instead of cutting it on the bobbin thread cutter, just let it hang outside by 1/8" or so. That way you can be sure there is enough bobbin thread available for the stitch to lock. Don't use the scissors button on the machine after every colour change. Sure, it makes for a tidier back of the embroidery with less work for you afterwards, but if it means you are taking the hoop and bobbin cover off after every colour change then it is not worth it in time-saving.
If your machine is doing this - cutting the bobbin thread too short - mention it to your tech. when you machine goes in for its next service. He may be able to tweak the bobbin cutter so it does not cut so close.
Jan 05, 2010 | Husqvarna Designer I
When I sew with the regular portion of my Designer One, all is fine. I've been using the embroidery attachment and when I embroidery a simple design, the top looks great, but the bobbin thread is sooo taut...
The bobbin tension sounds ok if regular sewing is ok. The upper tension unit may be the culprit in that there are loose threads or fluff causing the discs not to tighten enough for embroidery. The best solution is to have it serviced by an authorized husqvarna viking dealer. You can locate a dealer near you by visiting the husqvarna viking website and clicking on the Dealer link on the left-hand side of the page - http://www.husqvarnaviking.com
Good luck.
Oct 30, 2009 | Husqvarna Designer I
Sewing Machines Logo
1,271 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
