Question about Kodak EasyShare DX6340 Zoom Digital Camera
Replacing battery door
I have the new the door that came with no installation instructions.How do I take out the old door and put in the new the one without breaking it?
I just did it 2 minutes ago, you have to remove all the screws around the body (7)and loosen or separate the body of the camera, then you remove the old cover at an angle, it comes out easily, then replace with the new one, making sure the little spring goes under the hinge... piece of cake... good luck.
Posted on Mar 16, 2007
If my battery went dead on my remote for my gagage door opener do I have to reprogram remote when I put in new battery?
WIth car remotes they do not need re-coding if the battery is replaced within a few minutes of the old one being taken out.
source: car remote battery sales assistant.
Dec 24, 2014 | Genie gict390-1bl new g3t-bx garage door...
How do I change the batteries on my WW60X? I can't find my manual but was able to open the battery cover to get the number for the batteries. Now I can't get the batteries out of the scales. ...
Your Instruction Manual is here:
http://www.conaircanada.ca/pdf/en/ibs/en_WW60XC.pdf
Battery Replacement Instructions
1. Turn over the scale and open the battery door. (Push ribbed switch and pull up)
2. Replace old batteries with two new 3V Lithium batteries (CR2032).
3. Close battery door.
4. Properly dispose of old batteries.
There is nothing holding the batteries in place once the battery door is opened. If the batteries are difficult to remove, use a small screwdriver to gently pry up on the battery or simply after opening battery door invert the scale and shake.
Mar 10, 2011 | Conair WW60X memory electronic Weight...
How i can mount a new battery cover on Olympus SP-560 UZ
i just purchased a new cover for $33 from uscamera. part#omp vg4293. You will need a jewlers philips screw driver. Make sure you lay out screws where they came out. They're different. Looking at the bottom,Remove 1 screw under battery door. Two screws on bottom my mount. Open little door on left for mem card and remove 2 screws. Open little door on right side where cable goes, remove 2 screws. Then gently on end wher door goes, pull back cover back just enough to remove old door and reinstall new door. Press back together and install screws.
Jun 18, 2010 | Olympus SP-560 UZ Digital Camera
Need instructions for replacing passenger side mirrow on 97 F-250 xlt. mirrow was knocked off and new one has screws but I can't figure how to disassemble to install.
In front of the side window theres a cover that can be the inside door panel or its own cover remove and see the bolts take off the nuts remove the old part and put on the new one and hook up the wire and put the panel back on
Nov 28, 2009 | 1997 Ford F250 SuperCab
Just need to know how to insert a new memory stick I bought for my dinosaur 3000. Fry's salesman said I could find a step-by-step instruction. THX!
Dinosaur, as in a old acer aspire 3000 or what?
Most likely two screws on the bottom of the laptop that hold the memory cover closed, inside you will find 1-2 memory modules, you may have to remove one of the old ones and then install the new one, or if one is free install the new one there.
Sep 11, 2009 | Acer Aspire 3000 Notebook
Remove/replacing side view mirror on a jeep grand cherokee
    Remove the Old Mirror
  1. Step 1 Disconnect the negative battery cable before you take off the grand Cherokee front door trim panel. Remove all screws and clips.
  2. Step 2 Detachthe window trim cover screw, and control lever screw beforedisconnecting the entire mirror trim cover. Remove the rubber coverinside the mirror cover, and disconnect the electrical wire.
  3. Step 3 Remove three nuts from the power mirror using a Torx® star-shaped screwdriver.
  4. Step 4 Pull out the outside rear view mirror. Guide the power wire through the hole in the door.
  5. Install the New Mirror
  6. Step 1 Replace the old mirror. Put the new power mirror in place. Push the new wiring through the hole in the door.
  7. Step 2 Install and tighten the three retaining screws you took off when removing the old mirror.
  8. Step 3 Connect the power mirror wiring to the connection located on the door panel. Replace the rubber cover and interior mirror cover.
  9. Step 4 Put the front door trim panel back in place by securing all clips and tightening all screws.
  10. Step 5 Connect the Subaru Outback's battery cable to restore the power.
i will recommend i site where you will get all the information you need to remove and replace your side mirror
http://www.wjjeeps.com/mirrors.htm
Sep 10, 2009 | 2004 Jeep Grand Cherokee
Door of the Battery compartment broken
To buy a replacement battery door is easy - go to Ebay - buy the replacement or, for the same price (around $20), buy an old camera just for the sake of the door. The second part, replace the door is much more difficult but I found out how to do it. The door has a hinge (a 1 inch long pin) which needs to be slid out from the camera to take the old door out and then to insert the new door. However, this pin just comes out if you open up the camera. To open it up, you need to remove 6 screws with Philips precision screw driver 1.6 mm ($7 at Radioshack) - there are 2 screws on 3 sides of the camera. After removing these screws carefully separate the two parts of the camera - you just need a gap of (maybe ) 1/16, just enough for the pin to slide out, which can be done forcing it out with a sharp knife. After the pin is removed, remove the old door, put the new door in place, put the pin back and use some pressure to join the two parts of the camera together. They join back with a click, put the 6 screws back and it is done.
Jul 11, 2008 | Cameras
Canon A75 Battery door
Never did it on an S1, but on other models it required removing the back face of the camera to access the battery doory hinge pin.
Examine your camera, and if this sounds feasible, remove all screws along the perimeter of the camera (keeping track of their sizes and where they came from, write it down with a crude drawing of their locations/sizes). Also look for screws in the battery compartment, and any visible screws behind flaps/doors. Once all perimeter screws are removed, you should be able to remove the back face of the camera by prying it open from the bottom. Once opened, the pin holding the battery door should be able to be slid out, enabling removal of the old door. Then in reverse slide the pin into the new door, and reassemble the camera and its screws.
May 06, 2008 | Canon PowerShot S1 IS Digital Camera
How to replace battery door?
I just replaced my battery door. You have to take every screw out of the camera. I used a philips eye glass screw driver. Then, pull the front and back covers apart carefully, its only plastic. There is a pin that holds the door to the rear cover. If you push the battery door button back and fourth the pin will start to show out the side of the camera. I pulled it out once it showed with small pair of needle nose pliers. Just reverse the procedure to install the new door.
Dec 12, 2006 | Canon PowerShot A20 Digital Camera
Kodak EasyShare DX6340 Zoom Digital Camera Logo
78 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
