Question about Jandy AQUALINK RS TELELINK KIT
Jandy aqua link main control box
Pool light randomly goes on and off. cannot conrol it anymore
  • Anonymous Mar 29, 2014
    Model 6614 Jandy pool controller, the waterfall (Aux 2) comes on /off randomly when the filter pump is on, the light does the same thing
  • 22 Answers
Do you have a 4 button switch in the spa and is the light on the button that is slightly under water? If so , the button is bad as the water is completing the circuit and turning the light on and off.
Repalce the button or disconnect it at the outdoor panel.
Posted on Dec 21, 2008
Jandy PDA PS4 Firmware 4.1 Date reads 10/10/14 "SAT"should be Friday.
go into system setup then find time and date reset to correct if every time the power goes out it is wrong you need to replace the battery backup either a 9 volt or a nicad on back of PCB board
Oct 10, 2014 | Jandy Aqua Link RS PDA-P4 - PDA for...
Want to program my pool but my aqua link 8265 PDA does not show the "PROGRAM" menu, as per the instructions..
your aqualink has a one touch chip in it you have to program with the hard wired controller if you dont have one you need to upgrade the chip to a PDA chip to program with the hand held
Sep 18, 2014 | Jandy Aqualink Pda Ps4 Wireless Handheld...
I have a jandy pda and have no idea what the message that its displaying means. This is our first pool and the owners manual has not helped! It says aqua pure 100% salt 4500 ppm, check aqua pure high salt...
it is showing your status aqua pure is set at 100% salt is at 4500 parts per million which is too high to operate should be between 2700 and 3400 to work properly you need to drain some water out and add fresh to dilute the salt general fault is because salt level is too high it is showing your filter pump and extra aux is on go to the equipment on on main screen it will give you a list of all your equipment any questions send me more info
Sep 20, 2013 | Jandy Aqualink Pda Ps6 Wireless Handheld...
Cannot find reset button on aqua link rs system
top left of control panel there is a reset button make sure to write down all your auxillaries and programming because if you reset make sure to go into controller and clear memory also
Aug 13, 2013 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Jandy aqua link , message 6521 rev hh. How do I resolve?
check 4 pin connectors see if shorted or see if wires cut
Sep 15, 2012 | Jandy Aqualink RS6 Pool Only/Spa Only...
Jandy PDA-PS4 lost link to salt system?? There is no more
go to system setup find aqua pure up setting from 0 to something and it will apear
May 27, 2012 | Jandy Aqualink Pda Ps4 Wireless Handheld...
Power to the box but fuse keeps blowing.
Yes their are 2 fuses on a aqualink. most fuses are clear mome are white make sure the fuse was the same, becuase a white fuse will burn slower, take more heat.
Oct 03, 2009 | Jandy AQUALINK RS TELELINK KIT
Jandy AQUALINK RS TELELINK KIT  Logo
435 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Bill Jordan
Ian Kime
Ian Kime
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
