Question about Dryers
Tumble dyer my tumble dryer keeps on cutting off after 5 seconds it cuts off all the other sockets in the house i have tried changing the fuse a few times. Today i put it on and it worked for an hour then it cut off again can it be repaired? if so how/how much would it cost???
  • xyvonnex Oct 29, 2008
    where is the exhaust at. thanks for ur answer hopefuly it will help.
    its a condenser dryer???
Oh, sorry i have never worked on a condenser dryer
Posted on Oct 29, 2008
  • 67 Answers
First, you should check the exhaust system, make sure every inch of it is clean on the inside. if it is clogged, there is sensors that turn off your heating element as a safety measure. if this is clean, there is 2 heat sensors, one of them probably needs replaced.
Posted on Oct 28, 2008
  • knvosss Oct 29, 2008
    the exhaust is the air tube that carries the hot air from the back of your dryer to the outside of your house.
Where will I find the heat reset button on my tcm580 condenser dryer
Hello Mandy, I am not sure what you mean by a heat reset button; perhaps explaining what the problem is, I may be able to assist you. Are you referring to the dryer motor's overload reset button? As a safety feature, a dryer has a high-limit thermostat and either a thermal fuse or thermal cut-off fuse.
In the event of poor air flow where there is no proper ventilation to the heating element- the internal temperature of the dryer exceeds its high-limit, the dryer will shut-down; once it cools off, you should be able to run it again.
However, if the thermal fuse (located on the blower housing) or the thermal cut-off fuse (located on the heater housing) goes, the dryer heating element will will not heat up or the dryer will stop running altogether.
Please note, a dryer will have either a thermal fuse OR a thermal cut-off fuse, but not both.
By-the-way, there has been a recall on certain models of HotPoint Creda, and Indesit tumble dryers due to a fire hazard risk; I am sending you the link...If your dryer is manufactured by HotPoint model TCM580, then your dryer maybe affected. Read the info in the link- it'll give you instructions on how to determine if your specific dryer is affected and what to do.
Feb 15, 2017 | Dryers
White knight gas tumble dryer lights then cuts out
Flame sensor next to the burner is eather bad or there is a bad connection at the flame sensor (that's why the kick works)
Jan 05, 2014 | Dryers
The model number posted doesn't to exist but one for sure is that all Whirlpool Electric Dryers do have a thermal cut-out (off) which is actually a non-resettable fuse located on the heater housing. Click on the link below then enter the exact model of your dryer then select and click bulkhead and locate the part named thermal cut-out/off, a non-resettable fuse.
Aug 12, 2011 | Dryers
No heat but tumbles. Heater coil is good. Fuse will be checked next. How do I get into the top control panel so I can check the resistors$
what you need to check is not only the heater but the 2 thormostat mounted on the housing where the heater goes BOTH should have continuty with zero ohms.The thermal fuse will cut off the motor so since it tumbles thermal fuse is good
Aug 09, 2011 | Kenmore 67841 Electric Dryer
Run no heat
Common faults -
1 The heating elements can fail (meaning open circuit)
2 There are cut-outs (T.O.C's) that might need resetting
3 The thermostats (stats) can trip out or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehave programs that can fail and circuitry although most should produce an errorcode showing you were the fault is.
5 Faultyconnections and burned wires may also be the fault.
Free tumble dryer repair videos
We have a Free full video library on appliance repair video’s
Jan 13, 2010 | Whirlpool Dryers
My dyer will not cut off
I would suggest checking to see if your start button is stuck
Jun 17, 2009 | Dryers
Hoover HDC7FM condensor dryer starts then cuts out
Open the dryer door (right after the breaker trips) and check for a burned smell. If it smells in the dryer, you probably have a direct short in the dryer wiring. Check for a burn smell at the wall socket. There may be a short in the socket itself, but not likely unless a mouse is lying across the contacts in the wall.
If everything checks ok replace the circuit breaker if this is an older home. Circuit breakers weaken after years of use. A 30 amp circuit breaker will trip at a much lower amperage after a period of years especially if it has tripped often.
Mar 12, 2009 | Hoover HDC7FM Dryer
Tumble dryer when switched on cuts power to all sockets in house
Try it with the heater disconnected, you will find it at the rear of the m/c at the bottom left behind a removable panel.
You may have to remove the top cover and the right hand side panel looking at the m/c from the front. Try it again.
I fit does not trip. then your heater is faulty.
If it still trips then you are probably going to have to call en engineer
Nov 26, 2008 | Hotpoint NWXR473EV Dryer
Keeps on cutting out on Hot drying cycle
this will be a problem with your thermostats 1 of them will have a thermal cut-out switch built onto it this thermostat needs replacing it is faulty
Dec 07, 2006 | Zanussi TC7114W Electric Dryer
Dryers Logo
89 people viewed this question
Top Dryers Experts
