13-inch TVs. Require converter box in Feb '09 ?
SOURCE: Universal Remote control code on Sharp 13H-M60
Your remote should have come with a sheet of paper with all the codes on it for different TV's, VCR's, , etc.
http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf
This
is the user's manual for a Phillips remote control. There is a list of
codes in it. They should be rather universal. There's also instructions
as to how to program it. I believe that there is a way to program it
without using the codes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4.
Press the Channel Up button repeatedly (up to 300 times) until the
device could be controlled changes channel. The red indicator blinks,
then stays lit. If you accidentally overshoot the code required, press
the Channel Down button to backtrack through the library until the
device changes channel. Pressing Channel Up changes direction to
forward again. Press and release the Mute button to install the code.
Hope this helps :)
SOURCE: MOD# PS1955 C125 DIGITALY READY FOR FEB. 09 ?
If you have cable or satellite, you will be OK. The converter box is required when using an outside antenna. (rabbit ears). Please rate my response if I was able to help. Thanks
