I have a Bosch Axxis washer model WFR2460UC/01. I know the motor brushes need replaced. The Bosch Appliances web site has a breakout drawing showing the brushes and providing part numbers. However, I cannot find a repair manual or instructions for removing either the motor from its mounts or the brushes from their brush holders. I cannot accomplish either by experimentation.
SOURCE: remove bosch axxis 2060 washer motor
Remove the back panel to get to the motor which is at the bottom at the back. Notice two bolts holding the motor into the mount. Remove these two bolts. Notice the back part of the motor is sitting in the mount with black rubber washers. Carefully, pull the motor forward, and this will be abit hard. You can take a flat head screw driver and tap down (in between) on each front plastic washer and the motor will slowly come forward. Becarefull because there is a wire harness still attached to the motor. You have to take wire cutters and clip the placstic band holding the wire harness to the motor. Then grip the harness and wiggle it free. Then remove the single wire also. Putting the belt back is a bit tricky too. Make sure you put back the two black rubber washers and the two front plastic washers.
SOURCE: Bosch Axxis WFL 2060 Washer, not spinning.
IF THERE IS BLACK DUST UNDER THE MOTOR IT IS USUALL DEAD. YOU CAN REMOVE MOTOR FROM THE BACK I HAVE DON IT. YOU NEED A METER TO CHECK THE MOTOR. I CAN HELP.
SOURCE: BOSCH WFR2460UC Washer displays an
Hi First unplug it for 15-30minutes then plug it back and if
the issue returns remove the front door seal from the front and clean the lock.
If that won't solve this then the control board should be replaced. Hope this
helps...please post back for further assistance. Daniel
