Question about Sony FD Trinitron WEGA KV-32FV300 32" TV
Controls Hello, I am not able to turn on my Wega from my remote control. When I turn on the tv from the unit itself, the tv turns on but none of the other controls (menu, input, channel) work either. In fact, when I attempt to press any of the tv's controls, it immediately increases the volume all the way up. When I attempt to turn it down and take my finger off the volume control, the volume goes right back up to full volume. Any ideas on what the problem is or how I can fix it. Thanks ED
  • phill2927 Jan 19, 2009
    I have the same problem with my SONY Wega. The volume goes all the way up when turned on. Is there a fix to this? Called SONY & they could not help.
  • 105rox Apr 19, 2009
    Our Tv's volume is stuck at high and the other controls don't work.  If I attempt to turn it down, ti goes right back up.
    Sergeant:
  • 337 Answers
Someone push the volume up button too hard and is stuck,this also has the micro(brain) confused,all this happen before you fund out your remote would not work.
Posted on Sep 12, 2006
Once TV is turned on can't none of commands work
If you're using Universal remote controller make sure it's programmed correctly.
Please provide more details.
Good Luck!
May 22, 2013 | Televison & Video
How do i reset a sony wega kdf55wf655 tv?
Hello
To reset this set to its factory settings:
Press when in a Menu, to reset the settings to the factory defaults. Also user to clear Labels, Channels or Favourite Channels.
To reset the TV fully to its Factory Defaults:
Turn ON the TV while Holding Down the "RESET" button on the remote control, Press the POWER button on the TV. The TV will turn itself OFF, then back ON again. Release the RESET button. OK.
Oct 08, 2011 | Televison & Video
I can't figure out how to get my Sony KV-34HS420 to factory settings!
Hello
To reset your tv to factory settings do the following:
1 Press POWER to turn on the TV.
2 Hold down RESET on the remote control.
3 Press TV POWER on the TV. (The TV will turn itself off, then back
on.)
4 Release RESET.
OK
Jan 23, 2011 | Sony FD Trinitron WEGA KV-34HS420 34" TV
The TV is frozen on one channel manual buttons not working nor re
hello here is how to reset your tv. turn on the tv while holding the reset button on the remote control,press the power button on the tv (the tv will turn itself off, then back on again) release the reset button. if this don't work get back to me and we'll try some think else good luck
regards
shaun
Jul 11, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Remotes will not work
change sensor of your remote control ,if there is not solve than change your sensor of your tv
Jun 02, 2010 | LG 42PG20 42 in. Plasma HDTV
Problem for Sony Grand WEGA KF-42SX300 42 in. LCD TV Only goes from red to amber on led
hello try a factory reset. turn on the tv while holding the reset button on the remote control, press the power button on the tv, the tv will turn itself off and back on again release the reset button
shaun
Nov 02, 2009 | Sony Grand WEGA KF-42SX300 42" LCD TV
Sylvania lc370ss9 remote problem, comcast
you have to turn off the power save setting
Mar 01, 2009 | RCA RCR450 Remote Control
Old remote quit. Need factory replacement
try contacting www.remotes.com for a new factory original remote
Nov 23, 2008 | RCA RCU300 Remote Control
Front panel controls are unresponsive
Check volume up switch in front panel locked continuously. If it is not take away the remote control from the TV or remove the battery in the remote. Because maybe the remote continuously sending volume up commands. Rarely this type problem occurs through remote control also. Even problem is not sorted there is problem in EEPROM ic (memory ic). This can be sorted out by the technical persons only. I hope this useful to you.
Aug 31, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony FD Trinitron WEGA KV-32FV300 32" TV Logo
223 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
