I had my device loaded with almost 6 GB of music, removed that music, used the removable hard disk feature, and then ran into troubles trying to reload music onto the device.
I've repartitioned the device so that only 250 MB is for the Removable Disk.
When I try using the Creative media library software, iTunes, or Windows Media Player, I can't get timely responses from the device or reload any tracks to it. For example, Windows Media Player took 10 hours just to verify the files on the device (I have about 32 songs on the device).
Afterwards, Windows Media Player reported an I/O Error when trying to transfer a 55-track play list to the device (thread exit or application request). These same songs have been successfully copied to the device in the past.
No matter what I do, I can't import new songs onto the device using any of the methods which worked before.
I've tried turning the device off, removing the battery in an attempt to reset it, rebooting my machine, waiting inordinate amounts of time.
Any suggestions?
I ALSO HAVE A ZEN MICRO, I PURCHASED IT FOR USING WITH THE NAPSTER SERVICE NAPSTER TO GO. I TO HAVE THE SAME SORT OF PROBLEM I WAS FULL OF TRACKS AND IT THEN STOPPED RESPONDING SO I DID A RE FORMATT SO ALL THE TRACKS WERE LOST. EVER SINCE THEN WHEN I TRY TO LOAD TRACKS FROM NAPSTER ALL I GET IS A TRANSFER ERROR (I/O ERROR)
THESE TRACKS WERE ON IT BEFORE AND IT TAKES FOREVER TO LOAD. I HAVE TRIED CREATIVE BUT THEY WERE CRAP AND THERE EMAIL CUSTOMER SUPPORT IS A JOKE. NAPSTER TRIED TO HELP BUT AFTER 6 40 MIN CALLS STILL NOT WORKING THEY KEEP GOING OVER THE SAME THINGS. I HAVE TRIED WEBSITES LIKE THESE BUT TO NO AVAIL. DO YOU KNOW OF ANYTHING OR HAVE ANY SUGGESTIONS, I AM A COPMPLETE TECHNOPHOBE BUT I WILL HAVE A GO.
The service is completely free and covers almost anything you can think of (from cars to computers, handyman, and even drones). click here to download the app (for users in the US for now) and get all the help you need. Good luck!
2)When the unit is connect to a computer, it will create a gray and green icon in the system tray.
3)Go to "my computer" section of computer. In there you will find a section called "devices with removable storage"
4)Locate drive created by unit, generally just called removable disk
5)Open drive by either double left clicking on the drive itself or by right clicking to open the option menu then left click on the desired drive.
6)Locate music stored on computer
7)Once you located song files, click songs itself then transfer to removable disk.
8)Repeat step 7 as many songs as you want to copy on to the unit.
<p>The second generation iPod Touch, also known as the iPod
Touch 2, was in storage sizes of 8 GB, 16 GB and 32 GB. Depending on the model,
he may never need to remove songs to free hard disk space. If you find yourself
in tight space, or low-end version 8 GB or more 32 GB mode settings, use iTunes
to manually manage the songs on the iPod Touch. <br />
<p><br />
<p>1. Hook touch to your computer using the USB device. <br />
<p><br />
<p>2. Open iTunes. The program takes a while to read and
display the name of his touch in the source list left. <br />
<p><br />
<p>3. Click on the name Touch the left in the source list. <br />
<p><br />
<p>4. Click the "Manually manage music and videos"
box, located at the central, if not already selected. This mode is used for
music from your iTunes library once the iPod touch in the library computer. <br />
<p><br />
<p>5. Click the "Music" option in a list of source
Tap the left pane. Touch your music will appear in the center pane. <br />
<p><br />
<p>6. Click the number you want to delete. If you have multiple
numbers, hold down the "Ctrl" and click on the numbers. <br />
<p><br />
<p>7. Right-click a selected song and click "Remove."
<br />
<p><br />
<p>8. Click "Remove" to delete the song (s). <br />
how you can upload music to your divice if you have i tunes and want them on your mp3/mp4 this device is not user friendly. 1. plug into your usb conection port
2. click on "my computer" 3. double click on "removable disk (F:). you should make a make a new folder for your music. 4. Open Itunes or what ever you use to listen to mp3's on your PC. 5. Drag song to "new folder" and any other songs you want to have 6. Drag your new folder into "Removable Disk (F:) window. which is your mp3/mp4
There is an alternative to loading song onto your friends mp3 players like all players.
Many people find it difficult to sync there mp3 with windows media player, because it can be very annoying.
To get around this, First: Connect the mp3 player to your computer.
Next, got to my computer.
You should see the mp3 player in there as a removable disk,
Right-Click on the removable disk and select "explore"
This will open a window showing all unhidden files/folders in the mp3 player.
Leave the window open,... next find the music you want to add to the mp3 on your computer.
Windows Media Player music can be found in the my music folder.
Once you have discovered the music you want to add to the mp3 player, go to the mp3 player folder (removable disk).... there should be a folder in there labeled music.
From here on it's just a simple drag and drop process.
Select all the music file you want on the mp3 player from the my music folder, and move them inside the music folder found on your mp3.
What you should try is backing up your unit, if there are songs from any other source on your player other than the one main computer you use.
Determine whether the entire load is less than 2 GB and if so, then reformat your MP3 player to make use of space from songs which, though deleted from your player, (such deletions only decapitate the file header) still may occupy significant disk space which is at a premium on your player.
Totally reinstall your player and then load your music onto same, leaving some headroom (some portion of 2 GB i.e. 100 to 500 MB) on your player to allow for streaming of your music, which will enhance your enjoyment of same.
Drivers required only for Win98. Other versions on Windows have drivers installed. Plug usb cord into PC and into Missil Player. Open my computer, removable disk which is the Missil player) and file where desired music is. Drag music from storage file to "removable disk in "my computer". Treat it as a hard drive copy to, delete or format. To continue playing where you left off when restarting, hold off/pause button down for 3 seconds before shutting off.
While the preferred method to load music onto an MP3 player may differ from model to model, most MP3 players will feature the ability to upload music using a "drag-and-drop" method.
Normally, this can be done by opening the folders that contain your music library and accessing the MP3 player's hard drive by navigating through the "My Computer" option:
My Computer > Removable Devices
Simply click on the files that you want to transfer to your MP3 player, drag them over to the icon that represents the player itself, and drop them into that folder.
Again, please keep in mind that this method will not work with every MP3 player available - some players require special software that must be downloaded or installed onto your computer from a CD that was included in the original factory packaging.
1 Find the MP3 song or group of songs on your hard drive
2 select them
3 copy them
4 Open the “My Computer” folder
5 Open removable disk(x) {there will be a drive letter in the place of the x} if you have multitude removable disks select the last one in alphabetical order .
6 Paste the song(files intothat drive .
7 Disconnect and your ready to go.
before copying the songs into mp3 player first format the card in the mp3 player after that insert the card into computer and copy all the songs what ever you want
after hooking up the device to your USB, open my computer and you should see something like removable drive E or some thing like that. Double click on that device and drop your songs in there and give a try. Some of these devices do not come with a default music folder created already. You have the option of creating one if you wish just like on your hard drive. Or just drop them into the device it's self.
