Question about Adler Royal 121 PD Plus Calculator
How do i insert the paper into the calculator
I am trying to insert paper into the calculator and it wont go in. how do i put the paper in?
  • Anonymous Jan 21, 2009
    i cant insert paper into a casioHR-16A bk
Royal alpha 1000ml
That has a thermal printer.. did you buy thermal paper? Did you insert it in the correct direction?
Apr 01, 2014 | Royal 29043x Alpha 1000 Ml Cash Register
How do you put the adding paper into the machine? My machine is a EL-1197iv
Never insert paper roll if torn. Doing so will cause paper to jam.
Always cut leading edge with scissors first.
1) Insert the leading edge of the paper roll into the opening. (Fig. 1)
2) Turn the power on and feed the paper by pressing . (Fig. 2)
3) Insert the paper roll to the paper holder. (Fig. 3)
DO NOT PULL PAPER BACKWARDS AS THIS MAY CAUSE
DAMAGE TO PRINTING MECHANISM.
Jan 03, 2011 | Sharp EL-1197PIII Calculator
How do I load paper in my canon p23 dh v printing calculater
Put paper roll on paper arm with the end of the paper coming down from behind. Cut paper on a diagonal. Insert the paper into the **** at the back of the calculator. You need to really look to see it. Use the feed button to feed the paper through..
Nov 06, 2009 | Canon P23-DHV Calculator
How do I feed the paper through to start printing
Put paper on paper arm with end of paper hanging down from the back. Cut the end of the paper at a diagonal. Insert paper into **** on back of calculator. Use feed button to feed the paper into the calculator.
Hope this helps.
Oct 28, 2009 | Canon P23-DHV Calculator
Cannot load paper into feed into machine
Put new roll of paper on paper arm with the end of the paper hanging down from the back. Insert the paper into the **** at the back of the calculator - you need to look carefully as it is not very wide. Use the feed key to feed the paper through. Hope this helps.
Oct 25, 2009 | Canon P23-DHV Calculator
How do i install the printer paper???
i can not feed paper into printer on my calculator
Jun 23, 2009 | Canon P1-DHV Calculator
Tape wont register on this after we changed the tape
Make sure that it is installed properly ... going under not OVER. Does the paper feed when the paper feed key is depressed ??
1. Lift the paper holder up.
2. Fold the leading edge of the paper roll 3 to 5 cm. (Do not fold it slantwise.)
3. Insert the paper roll from the left side of the paper holder and make sure the paper
roll is set in the proper direction (with the paper feeding from the bottom).
4. Insert the leading edge of the paper into the opening directly behind the print
mechanism.
5. Press the paper feed key and feed the paper under the edge of the paper cutter.
Dec 07, 2007 | Sharp EL-2196BL Calculator
Sharp EL-2196BL
mechanism.
Paper not moving forward
please confirm that nothing droped inside in your printer (pins-stapler-small pieces of torn paper)-double a piece of paper roll and try to insert it while you press paper feed button to remove any object in paper path- apply light grease in gears and test your calculator.if the problem exist pass it to service center.
Sep 18, 2007 | Sharp EL-2630P Calculator
Loading paper
Hi, I had the same problem...but I fixed it. Here's how: At the very back of the calculater under the paper roller there is a very thin horizontal slot. Insert the tip of the paper roll into the slot, then press the paper advance button located on the top left hand sidw of the calculator until you see the paper. Guide the paper through the top slot and voila.
Mar 28, 2007 | Canon P23-DH Calculator
Adler Royal 121 PD Plus Calculator Logo
51 people viewed this question
Top Adler Royal Office Equipment & Supplies Experts
Electroboy
Electroboy
Kevin Michael
Kevin Michael
P Scarbs
Level 1 Expert
Are you an Adler Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
