Question about Lexmark Office Equipment & Supplies
Is the printerdriver easy to install? - Lexmark Office Equipment & Supplies
    Genius:
  • 1,124 Answers
Yes, follow this steps
Most new printers, especially USB printers, come with installer programs. If you have neither installation instructions nor an installation program, you can use one of the following procedures to install most printers:
USB printers (Windows 98, Me, 2000, and XP only)
  1. Make sure that the USB cable is unplugged from your computer and your printer. USB devices work differently from older devices and usually need to have the drivers installed before you connect the device.
  2. If you have an installation disk, insert it into the drive. If there is an installer provided, it should run or be executed here. Follow its instructions, and it should take care of installing your printer in a few moments.
  3. If you don't have an installation program, plug the USB cable into your computer and your printer. This should trigger the Add New Hardware Wizard.
  4. Click Next, and then select Search for the best driver for your device. Click Next.
  5. Uncheck all options except Specify a Location. Click Browse. Browse to the disk, CD, or directory where your printer drivers are located. Click OK, and then click Next twice. Note: You can download some drivers from the web. Consult the web site of your printer's manufacturer, or see Where can I find driver updates for my Windows computer?
  6. When all the files are copied, click Finish.
  7. Turn on your printer. Windows should detect the printer's presence and finish the installation. If the option to print a test page is offered, do so. This will confirm the installation. Click Finish.
Parallel port printers Windows 2000 and XP
  1. In Windows XP default view, from the Start menu, select Printers and Faxes, and then double-click Add Printer. In Windows XP Classic view, or in Windows 2000, from the Start menu, select Settings, then Printers, and then double-click Add Printer. This will start the Add Printer Wizard. Click Next.
  2. Select Local printer or Local printer attached to this computer. Click Next.
  3. Select the LPT port.
  4. Select the manufacturer and model for the printer you are installing. If you would rather use the driver disk that came with the printer, insert that disk and click Have Disk, and then browse to the driver disk and the proper folder. Click Open, then OK. Sometimes at this point, you will be asked if you print from MS-DOS programs. Most people can safely answer No here, but if you print from any DOS-based programs, answer Yes.
  5. Windows will offer a name for the printer that you may change if you like. If this is your only printer, or you wish to use this printer most of the time, select Yes to make this the default printer.
  6. You will be given the option to share this printer on the network. Unless you specifically want to do this, select Do not share this printer. Click Next.
  7. Make sure the printer is connected and turned on, and then answer Yes to print a test page. This will ensure that your printer is working. After the page has printed, click Finish. Your printer should be ready to use.
Posted on Oct 28, 2008
Windows 7 epsom sx515 printer, driver detective installs sx510 driver
Please. Do NOT rely on 'Driver Detective'.... !!!
Just un-install the software from this and the driver and download
and install the original Epson SX515w printerdriver and software!
Oct 17, 2011 | Office Equipment & Supplies
My 966 dell printer wont print on my sony vaio laptop.. is there a driver for it?
Yes there is a driver or software for everything you have or get on your computer.
go to www.dell.com/printerdrivers or you can also go to www.drivers.com there will be several options once you get there but the fast and easy way is at the dell home page.
good Luck
Mar 31, 2010 | Dell 966 All-In-One InkJet Printer
Cd can't install printerdriver
OK you need to go into your BIOS and enable the correct option in you LPT Printer port settings, LPT setting is set to EPP in the bios & save. This should sort that problem out.
Feb 17, 2010 | Lexmark X3470 All-In-One InkJet Printer
Printerdriver voor windows 7 64bits
There are 3 choices, but only 2 that are relevant to what you're looking for.
http://software.canon-europe.com/products/0010421.asp
More than likely, the first download is what you'll need to get and install. If that doesn't work, then the third one might help.
Jan 24, 2010 | Canon i-Sensys LBP5360/EN 21ppm A4...
I have lost the mp 160 canon printerdriver installer
Firstly you'll want to check the company's website for any downloads : http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=2610&modelid=13368#DownloadDetailAct
Go there and select your OS (Operating System) and download whatever you need under the Software category. Probably My Printer & Easy-WebPrint.
Best of luck, hope this helps :)
Nov 30, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Double sided print with HP officejet 7310
Go to www.hp.com and let the website auto-detect your printer and download the drivers automatically.
Jan 16, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Very light print -- EASY SHARE 5300
papabuyme: try updating drivers...Disconnect printer from computer and double-click on C:\program files\kodak\printer\printerdriver\uninst.vbs. restart PC and re-connect printer when PC has boot up...if your problem persists...
you both need a new printhead. contact support
Guest: get a new printhead
May 09, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Printer
If you are using only text print, you can install windows default laser jet printer.
This default printerdriver will not print your graphical out put,
Dec 26, 2007 | HP LaserJet 1020 Printer
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
