Question about Lexmark Office Equipment & Supplies
Is it difficult to install? - Lexmark Office Equipment & Supplies
  • 1,124 Answers
Most new printers, especially USB printers, come with installer programs. If you have neither installation instructions nor an installation program, you can use one of the following procedures to install most printers: USB printers (Windows 98, Me, 2000, and XP only)
  1. Make sure that the USB cable is unplugged from your computer and your printer. USB devices work differently from older devices and usually need to have the drivers installed before you connect the device.
  2. If you have an installation disk, insert it into the drive. If there is an installer provided, it should run or be executed here. Follow its instructions, and it should take care of installing your printer in a few moments.
  3. If you don't have an installation program, plug the USB cable into your computer and your printer. This should trigger the Add New Hardware Wizard.
  4. Click Next, and then select Search for the best driver for your device. Click Next.
  5. Uncheck all options except Specify a Location. Click Browse. Browse to the disk, CD, or directory where your printer drivers are located. Click OK, and then click Next twice. Note: You can download some drivers from the web. Consult the web site of your printer's manufacturer, or see Where can I find driver updates for my Windows computer?
  6. When all the files are copied, click Finish.
  7. Turn on your printer. Windows should detect the printer's presence and finish the installation. If the option to print a test page is offered, do so. This will confirm the installation. Click Finish.
Parallel port printers Windows 2000 and XP
  1. In Windows XP default view, from the Start menu, select Printers and Faxes, and then double-click Add Printer. In Windows XP Classic view, or in Windows 2000, from the Start menu, select Settings, then Printers, and then double-click Add Printer. This will start the Add Printer Wizard. Click Next.
  2. Select Local printer or Local printer attached to this computer. Click Next.
  3. Select the LPT port.
  4. Select the manufacturer and model for the printer you are installing. If you would rather use the driver disk that came with the printer, insert that disk and click Have Disk, and then browse to the driver disk and the proper folder. Click Open, then OK. Sometimes at this point, you will be asked if you print from MS-DOS programs. Most people can safely answer No here, but if you print from any DOS-based programs, answer Yes.
  5. Windows will offer a name for the printer that you may change if you like. If this is your only printer, or you wish to use this printer most of the time, select Yes to make this the default printer.
  6. You will be given the option to share this printer on the network. Unless you specifically want to do this, select Do not share this printer. Click Next.
  7. Make sure the printer is connected and turned on, and then answer Yes to print a test page. This will ensure that your printer is working. After the page has printed, click Finish. Your printer should be ready to use.
Posted on Oct 28, 2008
I find it very difficult to get the correct fit with the standard toilet seat,it always moves after installation
You need to tighten it down more likely. If that does not work install it with some silicvone sealant and let it cure for 24 hours before using it again.
Oct 14, 2014 | Home
Change front pads on ford focus 2009 model
The 2009 Ford Focus seems difficult to install the non-caliper side brake disk due to integral springs on the pad steel backing. Looks like the outer cage of the brake, the part that straddles the rotor, needs to be removed for pad installation, then reassembled onto the caliper system with brake pads installed. Haven't attepmted this yet, but it appears to be the only alternative given geometric constraints. This is a lot more difficult than other front disk brake systems where the pads virtually slip right into place.
Jan 28, 2012 | Ford Focus Cars & Trucks
How difficult is it to fit a twincam motor into a slantfront toyota
Hi SSSuperman, Everything is possible, and some things are difficult, and what you're talking about is difficult and time consuming. You'll need to give more details of the engine which is installed, the twin cam you would like to use and the model of Toyota you're referring to. If you intend to install a fuel injected engine, you'll need to install the electronic management system together with its harness. If you want to tackle the job share some more info! P.s. Its time consuming and could be difficult! Regards Johngee10
Sep 02, 2011 | Toyota Corolla Cars & Trucks
Timing belt installation. Difficult?
I would say difficult,if you never
did one.
Not a job to get involved in
for any reason.
Feb 09, 2011 | 1993 Dodge Spirit
I need to replace turbo, is it difficult?
Yes installing a new turbo is a difficult task. This will include pulling the turbo and piping, disconnection of the oil lines and air lines. And then installing a new one.
Jan 04, 2011 | 2002 Volvo S40
Need to replace back left rear wheel studs...3 out of 4 are broken. How difficult is this? Should I just purchase another drum? Is the drum difficult to get off and install for a want to be mechanic?
drum is not hard to get off and install
no dont buy another drum
once you remove drum,you can just knock the broken studs out with a hammer and punch
to install new studs,just tap them into place with a hammer. the studs go in from the inside of drum.happy mechanicing
Dec 23, 2010 | 2000 Ford Focus
Our Kohler Fairfax kitchen faucet 12176 has a difficult spout swing from side to side that I thought would get easier over time. It is installed on granite and when I use hot water is very difficult to...
was the base installed under the there a single hole in granite...faucets usually come with a long base to cover the holes in sink..or with one round ring for granite installation..which the faucet should be mounted on..
Nov 22, 2010 | Kohler Fairfax Single Control Lavatory...
Is it difficult to install the front bellows seal on a 110-44826-300
If you are not pretty mechanically inclined it can be very difficult. I would say and 8 on a scale of 10.
Mar 18, 2010 | Kenmore Washing Machines
My touch pad is nery slow and difficult to use.
Step1: Try by installing Touch Pad Driver.
Step2: If it doesn't help change the Touch pad Grid.
Nov 06, 2009 | Dell F3534 Touchpad
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
