Question about Gateway Computers & Internet
Computer cycling trying to start - Gateway Computers & Internet
  • 33 Answers
System cycling can be caused by a number of problems.
First: try using F8 on startup and go to "Last Known Good Configuration." You could also try booting up using a recovery disk and repairing the installation. If that doesn't work, there are a few other options:
Try booting to the Windows XP CD-ROM and go to the recoveryconsole. Once there copy the USERINIT.EXE from the CD or from anotherworking PC to the windows system32 directory. Once done, reboot .
It could be that RAM has failed or has gotten dirty. Try removing your ram and cleaning it with an electrical cleaner like Truvolt, and then replacing it.
Or it could be caused by processor overheating. Click delete, F1, or F10 when your computer starts to go into your BIOS and look for PC Health > Temperature (or similar). This should show you the current temperature of the computer and theemergency shutdown temperature. The emergency shutdown temperature is asafeguard for when your computer gets too hot it will shut itself downto prevent damage.
You can either raise the shutdown temperature or switch it off completely, however be warned that you may damage your computer (or the clients) if the computer gets too hot.If the temperature was causing the reboots then you should considergetting better cooling for the computer such as more powerful CPU fansand more case fans.
Your computer could be set to reboot on a system failure. Try getting in via safe mode by tapping F8 on startup.
Then go to “My Computer” and choose “Properties”. Goto the “Advanced” Tab and under “Startup and Recovery” press the “Settings” button.
Under the “System Failure” box there will be a checkbox saying “Automatically Restart”. Untick this box and click Ok.
On your next restart you'll see a blue screen with technical details. Create a new problem report with these. Or you can diagnose with the following list: http://www.technibble.com/troubleshooting-windows-stop-errors-what-they-mean-in-english/
While you're in safe mode, you can also use your event veiwer to see if there are any error messages that explain the reboot. Start> Run, type “eventvwr” -- please share these as well or google them for information and share this.
You could also have corrupt boot files or a virus. If you can get into safe mode, you might want to consider copying data to an external hard drive and using your manufacturer restore discs. If you can't get into safe mode and your data is already backed up, you might also consider this.
Posted on Oct 28, 2008
    Scholar:
  • 65 Answers
If its cycling and doesnt seem to get past the point of intial boot screen, then your power supply might not be enough or it is having serious issues. replacing a power supply is relativly easy, every plug on it goes to only certain things. Basically, and no offense intended from this, Its idiot proof, or as near idiot proof as possible.
Only other Issue that i can see that the computer would be cycling is if the boot files somehow became corrupted to the point that the system is trying to get past it, but just cant quite, which means you either need to use the system recovery disk or if that is either not working or not possible, then you will need to reinstall the entire system
Machine stuck in drain mode, & will not register in other cycles....turning machine off does not reset cycle?
Washers are computer and they must finish the program you last started. So with that being said the washer is trying to finish the cycle you start before it can move on. If it keeps draining there must be a clog in the pump. The water may be below the inner clothes basket so you can't see it. The washer knows it is not all drained out so it keeps trying. A model number would be helpful.
Mar 15, 2015 | Washing Machines
Miele W1712 honeycomb care front loader the door will not unlock after cycle has finished, it has been 24 hrs
Try unplugging the washer's electrical connection, wait for about 20 seconds then plug back in. See if that resets your cycle to Start mode from an unfinished mode. If not, see if you start another cycle, such as a spin to complete any draining of water. It might have blockage that is keeping the water from draining thus thinking the cycle is not over - or- a bad sensor not telling the computer that the cycle is over and it's OK to release the door lock.
Nov 24, 2014 | Washing Machines
Immobilizer light will not go off when key inserted, Lock smith said my computer was not responding, Toyota wants to replace computer but that's 1200 bucks and I want to make sure that this will fix the...
YOU MUST HAVE MASTER KEY:
1. Start with key out of ignition, drivers door is open all others closed and
drivers door is unlocked.
2. Insert key into the ignition (Do NOT Turn) and Pull key out.
3. Perform these steps within 40 seconds.
A. Using the power lock switch on the drivers door, perform 5 lock/unlock cycles
starting with lock. Use an even pace and try to go about one cycle per second.
(1Cycle = 1 lock and 1 unlock).
B. Close, then open drivers door.
4. Perform these steps within 40 seconds.
B. Insert the key in the ignition cylinder.
C. Turn the ignition to ON (Do NOT Start) then back to OFF.
D. Remove the key from the ignition.
5. Within 3 seconds the power door locks should cycle automatically indicating successful
entry into programming mode. Return to step 1 if the locks do not cycle at this point.
6. Perform these steps within 40 seconds.
A. Press the lock and unlock buttons on the remote simultaneously for 1 second.
B. Immediately after letting go of the lock and unlock buttons, press the lock button by
itself and hold for 2 seconds. Within 3 seconds, the door locks should cycle once
indicating successful programming. If the door locks do not cycle, or cycle twice.
repeat steps A and B in step 6 as your remote has not been accepted.
C. Repeat steps A and B in step 6 for each new remote.
7. Close drivers door.
Sep 18, 2013 | 2001 Toyota Land Cruiser
What is the drive cycle for 1996 jeep cherokee
A term relevant only to the engine computer's operation. The computer counts drive cycles for a certain few functions, like for example, a detected malfunction may require a set number of drive cycles for the computer to set a trouble code.
One drive cycle is starting the car, and the car running long enough to warm up so it goes into closed loop operation (meaning the computer is controlling or managing engine operation through sensor information it receives). When car is stopped and key turned off-end of drive cycle. It can be just a short trip, an errand to the store, or it can be a longer drive cycle. From the time car is started and goes to closed loop operation till the key is turned off-one drive cycle.
Jun 11, 2012 | 2001 Hyundai Sonata
Had to jump start, when tried to get emission insp I was told it would have to go through drive cycle to pass what is this
Cars do have a drive cycle to clear up a fault. It more less ensures the issue has been corrected after a certain drive cycle. Some issues have to cycled for 500 miles.
Jan 05, 2012 | 2001 GMC Jimmy
Acer Aspire 5520
Sounds like a fried battery. Try a brand new one.
Jul 14, 2009 | Acer Aspire 5520-5579 Notebook
Hot point wmlt80, dail clicking and turning, cycle wont start,
Yes, I work for GE what you need to do is to resent the appliance. Something should had happened with the computer of the washer. Just unplugged the machine for 40 seconds. You can unplugged or turn off the circuit breaker for 40 second and plugged back in. Select a normal cycle and let it run.
Jan 15, 2009 | Hotpoint WMTL80 Top Load Washer
Monitor repeatedly flashes Acer logo and computer display in cycles
We had the same problem with the 17" we bought in Aug. Sent it back for repair. Acer sent it back without fixing the problem. Started doing it again in Nov. This time I called a supervisor and they sent me a new monitor. Well yesterday it started doing the same thing. You can fix it temp buy unplugging it and holding down the on-off switch for 30 seconds. Please let me know if you have a better fix.
Dec 13, 2007 | Acer AL1715 (Black, Silver) 17" LCD...
Maytag Washer, Neptune TL
This means the computer is not seeing that you opened the lid between cycles 3 times. So likely the lid locks are faulty. PLEASE rate my help as solved all other ratings dock us
Oct 02, 2007 | Maytag MAT13MN Top Load Washer
Computers & Internet Logo
76 people viewed this question
Top Gateway Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Prashant M
Prashant M
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
