Question about Nintendo Wii Console
Dropped wii Kids dropped the console, the face plate came off and one wire is disconnected. What should I do?
Solder it back on duh stupid *****
Posted on Oct 29, 2008
Wii wont take disc completely in the unit help
try taking it to your local game store or take it apart or maybe the led reader is broken
Sep 01, 2012 | Nintendo Wii Console
I've dropped my wii alot in these 2 years now it will only load one of my many games. Please help i want to brawl so badly.
Well my solution would either be to take it somewhere to have it fixed or go buy a new one. Considering you have dropped it numerous times it could be a wide variety of things going on.
Jun 07, 2011 | Nintendo Wii Console
Unable to read disc
If your console is unable to read disc, then there seem to be a problem with the console, and the problem most likely is as a result of a bad laser/lens inside the console.
To replace the lens of the nitendo wii console, remove the two flip up panela on the side of the wii to reveal the black face plate with the controller ports and memory card slot.
Then remove the three screws located underneath the flip up panels using the fine phillips head screwdriver, then remove the black face plate.
Then remove the two tri wing screws located underneath the face plate. There are also two phillip head screws under the face plate but you can leave them in place.
Use a scalpel to peel off the two white stickers that are covering the screws located near the two front rubber feet on the bottom of the wii. This will reveal two black tri wing screws.
Use the scalpel to remove the two back ribber feet on the bottom of the wii, this will reveal two silver tri wing screws. Remove the two black tri wing screws and the two silver tri wing screws revealed on the bottom of the wii.
Use the scalpel to remove the rubber foot that is covering a screw in the top left corner at the back of the wii. Remove the screw using the fine phillip head screwdriver. Then use the scalpel to remove the white sticker covering the screw directly below the bar code on the back of the wii. Remove the screw with the tri wings screwdriver. Then use the fine phillip head screwdriver to remove the screw that is holding the battery cover in place on the back of the wii. This will reveal another screw that you can remove with the tri wing screwdriver.
Remove the front face plate of the wii, be careful because it is still attached to the console by a black and red wire. Disconnect the wires by lightly pulling on it. Remove the wii shell casing by gently lifting the separating it from the internal electronics of the console.
Remove the DVD drive by taking out the four corner screws using the large phillip head screwdriver then lift up the DVD drive and disconnect both power cable and ribbon cabble connecting it to the console.
Turn the disassembled console upside down, remove the two screws holding the DVD citcuit board in place, disconnect the three ribbon cable that are attached to the DVD circuit board, Use the tweezers to free the wires that are still connected to the circuit board from the plastic clips, Lift up the DVD circuit board and remove it from the way, then remove the lens case that is holding the lens ribbon cable in place.
Use the tweezers to remove the lens casing by lifting up on one side hooks that are holding it in place. This will reveal the laser lens unit, Which is held in place by two metal bars. Take out one of the metal bars by first removing the screws located next to it, and then gently lifting up on the plastic tab so you can slide it out.
Remove the laser lens unit and turn it over to reveal a white plastic part held in by a screw. Take out the screw so you can remove the white plastic part. You will need the part to install the replacement lens.
Attach the white plastic part from your old lens to your new lens using the same screw from the old unit. Place the new lens in the console and reassemble The DVD circuit board.
Remove the two solder points located on the lens ribbon by using a hot soldering iron.
Then reverse the process to reassemble the console.
Take care and good luck.
Hope this was helpful
Dec 03, 2010 | Nintendo Wii Console
Eject button not ejecting
mmm, try eject the game whit the wii face up side down
Apr 17, 2009 | Nintendo Wii Console
Wii Console gives message not able to read disk
when did this happen and when did you get your wii becuase production of wiis was rushed during christmas so the early games as super smash brawl usually after awile gets an error
Apr 12, 2009 | Nintendo Wii Console
The Wii console is not powering up at all.
Hi there, this is a power board failure. It seems to be a manufacturing error considering the fact that, this Wii is only 2 months old. i would excercise the warranty if possible and return for exchange. this is a defective unit.
Feb 18, 2009 | Nintendo Wii Console
Drop wii disc stuck
Your disc is stuck in Wii Console, It needs to eject manually.. You might check out Wii Fix Guide, that gives step by step information on Dis-Assembling with screenshots, even a novice can fix the disc eject problem with the help of this DIY Guide. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide.
Jan 20, 2009 | Nintendo Wii Console
DROPPED WII
is it still under warenty if so i would return it if not then i am guessing youll want to take it to a shop as the motor has most likly shaken loose or the laser was broken
Jan 13, 2009 | Nintendo Wii Console
Dropped the system everything working but will allow me to go to the map screen
Did you try to reset the unit? Place you thumbnail in the groove located under the Garmin logo on the face plate. Gently pull off the face plate. Press the reset button. Turn the unit back on and see if it works - Of course replace the face plate carefully. Good luck! Dr. Know
Dec 20, 2007 | Garmin StreetPilot C330 GPS Receiver
Nintendo Wii Console Logo
107 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
