Question about iRiver iFP-799 MP3 Player
Need help with my iriver ifp799 doesnt turn on
My mp3 player doesnt work at all,despite new battery...nada.. i would like to know how to fix it or where i can take it for repair....
  • 4 Answers
Cajunito,
After more than 4 years of everyday use, mine stopped as well. The problem was that the [Play] button/switch soldering dislodged from the PCB. I opened the player and resoldered the [start/play/stop/off] switch back on the PCB. It now works again. I noticed the problem because I could still get the player to operate by using more force and put some side pressure on the switch, which apparently pushed the switch and the PCB together to make contact again.
With a problem like you have there can be many different causes, so this might not be your solution.
Regards,
Robert Ilbrink
Posted on May 09, 2009
SOURCE:
Iriver H320 will not turn on
After 3 years constant use my iriver H320 would not charge.I bought a new battery kit online and fitted it myself.Now its like having a new iriver!
p.s. not bad for a technophobe eh!
Regards Tezra.
Mar 25, 2009 | iRiver H320 MP3 Player
I need a new battery for my iriver H10 5GB mp3 player.
wow, you asked for help back in 08! I had problems getting a responds from them too. I hope your problem was resolved, but just in case....I found my replacement battery on ebay. Amazon may be helpful too.
Dec 01, 2008 | iRiver H10 MP3 Player
Iriver h 10 mp3
OK, one day i turned on mu iriver and it's say's "system file missing to restore the system files connect to H10 to iriver and i dont know how to connect it.The other proplem when playing the music it's like a scratch CD i dont know how to fix it.
Sep 25, 2008 | iRiver H10 MP3 Player
Iriver 5gb
That is one SURE way to kill an Mp3 player - it is toast. I know you do not like my answer, but it is the only truthful answer. I have saved THOUSANDS of Mp3 players - this is the one scenario where the player cannot be revived. But if it makes you feel better:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Jun 03, 2008 | iRiver H10 MP3 Player
IRiver X20 mp4 player will not turn on.
Mar 23, 2008 | iRiver X20 MP3 Player
Iriver t20 problem
have you tried hitting the reset button when it hangs? You need to use a pin to do so, there's a small hole on the end of the player.
Nov 30, 2007 | iRiver T20 MP3 Player
Tried new batteries, but still doesn't turn on
Yo with mine whn I turn it on it immediatly turns back off and no Holds not on but I left mine on the usb for a while as well
Nov 09, 2007 | iRiver T30 MP3 Player
Gavin h10 5gb
Take the battery off, wait 10 seconds and put the battery back on. Then attempt to connect to the iRiver firmware updater in emergency mode. Then use the recovery tool, which will erase everything on the playe,r and re-format the drive.
Should result in a good-as-new player.
Nov 03, 2007 | iRiver H10 MP3 Player
My h10 will not switch on, iriver support will not help
Try to reinstall the software CD you received with the player. Good luck
May 01, 2006 | iRiver H10 MP3 Player
iRiver iFP-799 MP3 Player Logo
317 people viewed this question
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Peter Dragonetti
Shawn DuRee
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
