Question about iLO XM-MP3-CD Car Stereo
Static noise from car stereo
My car stereo makes a static noise. i have to push it in or wiggle the stereo around and it sometimes stops and sounds good. but if i turn on my car or drive over a bumpy area the stereo starts to make loud static noise again. one person told me that because its a detachable face stereo that its not making proper connection. could that be it or something else?
  • mzzz_cricket Oct 28, 2008
    so it has nothing to do with the stereo itself? just change out the speakers that are most likely to be blown. ok thanks i will look into that.
  • 3 Answers
I had a static/hiss sound coming from one speaker on my Sony head unit. The stereo was brand new and had just installed it. The stereo that it replaced had no static. Turns out it was the input setting on the separate amplifier being too high. The stereo has 4 volt pre-amp outputs.
Posted on Jan 17, 2011
Change youre speakers they are blown if they are making staticy sounds i have recently chnged my speaker cuz of the static and it was kuz they were blown
thats all i can think about
hope it works
Posted on Oct 28, 2008
Volume switch on Panasonic radio has scratchy static sounds
Sounds like oxidized contacts.
If volume is a turn-knob, then wiper-track (inside potentiometer) is worn.
If it's a PTM (push-to-make) standard button, the button contacts may be dusty/dirty/oxidized.
Suggest you:
buy a contact cleaner such as Servisol,
open case,
identify controls
and squirt liberally to wash out any gunk.
Move/press/wiggle scratchy one to help 'scrub' the contacts clean.
If this doesn't help try have control replaced.
Oct 11, 2017 | Panasonic Radio Communications
Got new stock stereo for my Honda crv because the CD player jammed up on the old one. Put in new stereo, cd and tape player work fine but radio is just all static. Antenna is plugged in. Ideas?
You might cure this with inline suppressor which you connect somewhere between aerial and input jack.if it makes static noises when engine is not running then it is an aerial issue.either the input is not pushed all the way in or the braid is touching metalwork or the cable is faulty.
Nov 16, 2015 | Honda Cars & Trucks
2004 chevy cavalier/ a noise suddely became noticeable coming from near the fan or ductwork under the dash.It sounds as if the fan blades are striking something and also sounds similar to static . It...
My car's glovebox door/trim was rattleing makeing a static noise. I had a friend push up on the trim while it was making the sound, and it stopped, so I just jammed a small wad of tissue up between the trim, and that solved it for the time being. Funny thing tho, after I had my tires balanced, the noise went away never to return. You could have a faulty blower motor tho, if the tissue don't work, or you can't stop it by applying pressure to the trim, look into blower motor replacement.
Dec 16, 2013 | Cars & Trucks
When I plug in my speakers, they make a constant static sound. It can become quite loud at times and I've found that turning the input chord around can sometimes work, or unplugging the charger for my...
if your speakers are near to some electronic devices you'll get theses static noises try to keep them away from electronic devices which solves it very easily..
Sep 30, 2010 | Audio Players & Recorders
There is static coming out of my speakers on my stereo. I I checke to make sureall the wires are connected properly and the power is plugged in securely. There is static with the sound on all...
Don't worry, it's more possible that you have the static electricity and through your stereo this electricity goes to the ground. Try touching another metalic surfasce (refrigirator, oven etc), try to change your shoes (especialy if your stereo is on a carpet floor and you walk on it) Sometimes when we are very nervous the static electricity on our body is higher. So keep calm.
Stelios.
Feb 20, 2010 | RCA WSP155 Main / Stereo Speaker
My 2005 Accord's radio / CD player will not produce sound to the speakers, the display panel works fine. Sometimes a loud static sound will come from the speakers with no volume control, powering off gets...
The sound chip may have gone in the stereo, especially if someone has had it on very loud they sometimes blow, otherwise you have 2 speaker wires touching each other, that way you only get static noise, insidee the door they sometimes come free and touch the body
Check all your speaker wires first.
Jan 17, 2010 | 2005 Honda Accord
My am radio makes static noise from other apliances.
Hello
Yes, this is a grounding problem, had the same problem with one of my older devices.
Best Regards
Andrea
Nov 03, 2009 | RCA Alarm Clock w/CD Player, AM/FM Stereo...
Stereo static
shut down all electrical sets around and check if the static goen the problem will be in electrical sets and you have to check it one by one.if it is not solved check your cables for any bad connector -open circuit- short circuit(try with a couple of new cables).-apply a contact cleaner in all sockets and move jack in and out in all sockets(with no power on)
Jun 12, 2008 | Audio Players & Recorders
My harman/kardon speakers has static noise but no sound
The first thing is to make sure the speakers are bad. You can seitch them around from side to side if only one of them is bad, if the one speaker still has bad sound, thats your problem. You can also test the woofer of the speakers. Just push in on the woofer with your fingers to move the woofer in and out (with the stereo off). You should here nothing, if you do, the speaker is bad. If both speaker are bad, expecially if they went bad at the same time, the stereo is bad, expecially if you are getting the static with the stereo on and the volume all the way down. Going buy your problem I thing that your stereo is bad. It will need tobe repaired.
Mar 20, 2008 | Audio Players & Recorders
iLO XM-MP3-CD Car Stereo Logo
2,402 people viewed this question
Top iLO Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Libran Moreno
Are you an iLO Car Audio and Video Expert? Answer questions, earn points and help others
