Question about Kenmore 23822 Top Load Washer
Washing machine leakes some where frome the bottom of washer
When the machine is filling and posable when it is washing
  • 370 Answers
It sounds like you pump is leaking. This happens most of the time( if its a kenmore or whilpool)lean your washer back and then you will see the pump on the end of the motor. it is held on by 2 clips and then you can take it off (after pulling iff the 2 water hoses) Look at where the motor shaft goes onto the pump if its leaking there will be a water streak. Replace the pump... leak is fixed
Posted on Nov 17, 2008
Admiral washer leaking water from bottom
What is the model number of the unit?
Nov 24, 2012 | Admiral Washing Machines
Water leaks (spewing) from sides of bottom of machine when it's filling up
The normal cause of leaking while it is filling is a leaking Inlet hose. Try pulling the washing machine away from the wall and watch the hoses as the machine fills. If it is leaking you can see which hose is leaking. You may either need new tighner clips or to replace the hoses depending on how bad they are leaking. Another possibility is the water pump inside the washing machine could be broken and spewing out water.
Aug 31, 2007 | Malber WD1000 Front Load Washer/Dryer
Where would the water come from if it is draining from the bottom of the washer when trying to fill tub
more than likely the pump is cracked and as it fills its leaking out. If I had the model number off the machine I could give you a better answer
Jun 05, 2012 | Washing Machines
Our washing machine started leaking lots of water during the fill and empty cycles. Water pours out of front bottom left corner. Any ideas as to what is wrong?
My Maytag Ensignia washing machine leaks large amounts of water when filling and during spin cylce. What could be wrong?
Jan 04, 2010 | GE WSXH208A Front Load Washer
Water leaking at time the washer is being filled, not during wash cycle. Leak appears to be starting a bottom left side of the machine toward the front from the middle of the side. Observation does not...
you say water only leaks when it fills correct? am wondering if its the hose that feeds in to the washer
this would be from the inlet solenoids check the clamps in the machine.
Dec 02, 2009 | Kenmore HE2 Plus Front Load Washer
Washer leaks during fill up
check the bottom of the inlet hose where it enters the machine. It is most like;y a split hose or a corroded valve.
Sep 25, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Leaking from bottom of washer
Do you have the little door at the bottom to collect lint and stuff that goes through the washer? I had a leaking problem once when I simply didn't tighten it enough. Check that.
May 06, 2009 | Kenmore 94702 Front Load Stacked Washer /...
Leaking wash machine
Depending on where exactly the leak is coming from, it could be a drain hose, drain pump, or tub seal. If this is a top-loader, here's how you can tell:
1. If the leak is coming from the BACK area under the washer, this can be caused by a leaking fill hose, dispenser hose, drain hose, or fill valve.
2. If the leak is coming from UNDER the center area of the washer, this could be your tub seal, a crack in the tub, or an air dome hose leak. NOTE: If the air dome hose is leaking, the washer will fill continuously and not turn off.
3. If the leak appears to be coming from the FRONT under the washer, this could be your drain pump, or drain hoses.
Posting a model number, could assist with determining how your washer is configured. I suspect you may have a drain pump leaking as this is the most common cause, but I want to be sure.
Apr 27, 2009 | Washing Machines
Water leaking from washer
you most likely have a pump leaking post your email so i can send you the manual
Nov 03, 2007 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Kenmore 23822 Top Load Washer Logo
56 people viewed this question
Sal De
 Brian Main
Brian Main
