I took the unit off the shelf to clean. And when I put the unit back on the shelf and I turned it on, I couldn't tune in to any stations.
Check to make sure your antenna properly extended, add a wire to the terminal or rod to bring up the gain, sometimes the tuner becomes dirty and causes a loud raspy sound, if that is the case buy electronic tuner spray, take unit apart! you should see a square plastic container with screws and tuning plates, spray into holes where the screws are, tune back and forth a few times, and repeat. Tuning will drift for sometime until compound dries.
