Question about Proview HV-207 20 in. HD-Ready LCD Television
Proview 2020 lcd on/off surfs chanlels by it self, middle of night! Haunted?
I have a Proview Model 2020, LCD. The TV will cut on and off by itself, many times when it cuts on it will surf through channels. I have taken the batteries out of the remote, still does this. typically I must get up and unplug it from the wall, to make it stop. Any ideas?
I can't answer this question. But I want the opportunity tell everyone...THIS TV SUCKS. THE SOUND IS TERRIBLE, YOU CAN''T HOOK UP HEADPHONES. I WOULD NEVER RECOMMEND THIS TV!!!!!
Posted on Dec 27, 2009
What are the codes for a universal remote.so I can program my proview LCD tv model no. 700
0271,0228. Check these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name" in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box.
http://remotesearch.blogspot.com/
http://electro-medical.blogspot.com/
http://electrohelponline.blogspot.com/
Jul 01, 2015 | Proview Televison & Video
TV turns on for about 5 minutes the the picture cuts out but sound stays on. Its a Proview 19 inch LCD TV
mrhackshack, Part of "switch-mode-power-supply" is going into SHUTDOWN mode having detected FAULT with other circuit (INVERTER) maybe???? Inverter lights-up the "cold-cathode-fluorescent-lamps" that provide RAW WHITE LIGHT so you can see all the pretty colors on the LCD GLASS PANEL. Technician will need to evaluate it!! Try YOUTUBE for vids on LCD TV repair and see if you can pull-off a DIY repair. Also see vids of LCD monitor repair and LCD monitor disassembly FYI. 12fixlouie Hope this points you in direction you need to go?????
Dec 10, 2009 | Proview PL926WBi 19" LCD Monitor
Proview HV205 (silver)model 2020 20" LCD
Check the remote control for its infrared emission. Check it with fresh batteries. Check it by pressing all the keys. You can detect the presence of infra-red emission from the remote control, using a cell-phone camera. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it. In some cases, the remote control might need to clean.
http://homenol.blogspot.com/
Search the site by type in this key phrase "how to test a remote control "in the "search box at the top right of the display window of the Homepage" to get the related post quickly.
https://youtu.be/wUpnETSm6_k
https://www.youtube.com/watch?v=jsSCNCW3IbQ [open and clean]
https://www.youtube.com/watch?v=Qp-l1uh-5gE [open and clean]
Sep 06, 2017 | Proview HX303 30 in. HD-Ready LCD...
Proview LCD TV is turning itself off inconsistently.
I don't know about your particular tv, but most of the LCD tv's have a power off option that it will turn off after 3 hours of no activity.
Why it would turn itself off at 3 and 30 minutes is beyond me. But I did want to write so you can check your settings to see if maybe someone has programmed in some shutdown times or something.
Hope this helps at least some. Good luck!
Jul 31, 2009 | Proview PA-32JK1A 32 in. LCD Television
Proview 32' without picture or sound
hi first of all u should check ur transistor connections.Check your Horizontal and vertical output transistors.You should also check the horizontal and vertical yoke connections as well as your low voltage regulators.... if any of these got damaged u should purchase a new one.. but try to purchase with the help of a tv service assistant...
thank u!!!
rate me
Jul 07, 2009 | Proview PA-32JK1A 32 in. LCD Television
Black mark in center of TV
If you have any vertical lines appearing in a LCD flat panel TV, you are looking a defect in the panel itself. If you no longer have any kind of warranty you are best to watch the TV as is and save your money towards a new TV as the LCD panels will cost in most cases twice the amount that you paid for the TV brand new.
Nov 19, 2008 | Proview PA-32JK1A 32 in. LCD Television
Proview 3200
Pat I do not know if you have a warranty you were required to retain the receipt from the store for the length of the warranty period to prove you have one ,also it is a good idea to register with the company on their website so they have a record of your tv and model, with your name and therefore the warranty they have included if any.LCD tv's are one of the most unsupported mass marketing consumer items that are being dumped on the US market. I think you have Blown capacitors, or more likely a problem with the power board, typically this requires soldering new capacitors onto the power board after unsoldering the blow ones and if this is all the problem is the issue will disappear, if there is an issue with a transformer, or some diode or computer chip then you might as well replace the whole power board. the capacitor issue is no big deal if you can get an electronics service center to look at the problem.
May 22, 2008 | Proview PA-32JK1A 32 in. LCD Television
Proview 470 HV-145 LCD TV
Hola que tal a todos........por si acaso alguien sabe donde puedo conseguir los drivers para el monitor Proview 470 HV-145 TV LCD...que me urge les agradesco......bastante por sus opiniones
Sep 27, 2007 | Proview HV-147 14 in. EDTV-Ready LCD...
Proview HV-207 20 in. HD-Ready LCD Television Logo
418 people viewed this question
Top Proview Televison & Video Experts
Steven Wander
Steven Wander
Tony
Are you a Proview Televison and Video Expert? Answer questions, earn points and help others
