Question about Cell Phones
Electratech heating system code needed - Cell Phones
  • shelleysam Jan 23, 2009
    My Mum died and I have her house up for sale, it was working fine but I pressed the code button to alter heating settings and now it won't let me do anything with out entering a code which I haven't got. There must be a way of bypassing the code, why would you need a code anyway! Shelley
I know it is a litt;e late to help you but if anyone else has this problem press code then mode 3 times. Then press code once, the display should ask you to confirm this . Press code again as requested. Code should then be removed.
Posted on Apr 30, 2010
  • Bunglebugs Oct 20, 2010
    Thanks flossie 129 that was magic. I've programmed the heaters as before but they are not turning on. checked. They are all switched on. Any ideas ?
I have a problem with this system. I have managed to set it all again since a powercut and all settings lost. But i just cant get the washer to power up any more.
This as it's own key pad ( no 9 ) it's flashing , but not working
any help is much apreciated...
Thanks Mike
Posted on Jul 04, 2010
What does h3 mean? The system is not cooling well why?
Need to know what system you have. Make, model, serial numbers
Aug 25, 2017 | Filter Heating & Cooling
My program is set for heat from 6:00am to 10 pm.. Furnace not running even tho set for 70, actual says 65. small message on screen next to temp "following schedule in recovery". How do I get heat?
You will need to do additional trouble-shooting. This could be a faulty thermostat, a broken wire at the thermostat or a problem with the furnace. At the thermostat, check that the wires are fully seated at the terminals. Make sure that the conductors haven't broken. (I've seen the wires break after they weakened.) You can try placing a jumper between the terminals for heat and ground. (For a single-phase forced air system, the Rh wire calls for heat.) If your system has a C (common) wire, make sure that the voltage is getting back to the furnace. You can try a different thermostat.
Also look at the furnace. Some systems will have an LED indicating a problem with the unit. Gas systems can have a problem with the flame. Gas or electric forced air systems could have an issue with a blower. Heat pumps can freeze up if the temperature is below their operating range.
I hope this helps. Please add a comment with the manufacturer and type of furnace (oil, gas, steam boiler) that you have if you need more ideas for trouble-shooting.
(my own gas furnace went out on Wednesday and was temporarily fixed by resetting the thermostat and using a jumper across the appropriate terminals. The flame didn't come on at 6 A.M. when the thermostat called for heat. Today, the blower completely failed and needs to be replaced. The earlier failure is likely to be related to this failing blower motor. When I followed the manual's instructions for testing the system, I got a "needs service" code. However, the unit didn't display a trouble-code before I did that test.)
Dec 16, 2016 | Heating & Cooling
My 2004 Honda CRV showing code P0133 and P0171
  • P0133 O2 Sensor Circuit Slow Response (Bank 1 Sensor 1)
  • P0171 System Too Lean (Bank 1)
Hi Michael, After fixing errors you need to reset your computer by disconnecting the battery for a minute or two, Also you'll need your radio code to reset your radio, I hope this helped...........CHEERS..
May 07, 2016 | Honda Cars & Trucks
P0421 code
"FWIW, according to the Mazda factory service manual, the P0421 code indicates "Warm up catalyst system efficiency below threshold".
The DETECTION CONDITION for this code indicates "Number of heated oxygen sensor (rear) inversion becomes closer to that of heated oxygen sensor (front)".
Warm up three way catalytic converter deterioration
Leakage exhaust system
Heated oxygen sensor (front) malfunction
Heated oxygen sensor (rear) malfunction
Mass air flow sensor malfunction
Throttle position sensor malfunction
Vehicle speed sensor malfunction"
I copied the above from a discussion group on the PO421 code. The code can be caused by any of the above listed problems. The vehicle should be further inspected and diagnosed, so you do not have components replaced that do not need to be replaced.
Apr 16, 2014 | 1998 Mazda 626
Codes p0132 and p1132
p0132 is heated oxygen sensor.......wiring short to positive
and p1132 is heated oxygen sensor not switching, fuel trim, rich mixture.......intake/fuel system injectors MAF sensor, ECT sensor. hope this helps and if you need any more info just ask
Feb 27, 2012 | Ford Explorer Cars & Trucks
My dryer works fine for about 7 mins then it stop and says f03
this is what it means :
  1. This code indicates a problem with the dryer's heating system. The code will appear when the heating circuits are broken or when there is an intermittent break in the power source for the dryer. If the heating circuits are working and the power source is steady, you may need to replace the central control board.
Feb 15, 2011 | Frigidaire FEQB4000F Dryer
The heat/air Temp reading is blinking.....when this happens we loose heat. If the car is restarted the problem is corrected for about 20 sec, then the temp blils again, and the heat is lost.
There is a problem with your Automatic Climate Control System. You need to check the system for fault codes and diagnose the system for the code or codes that you get.
The information that I have says that the codes in this system can only be retrieved by GM's Tech 1 Scan Tool. (Nice little feature that GM added to force people to take their cars to the dealer for repair)
This is a classic case of why I personally support the Right To Repair Coalition.
See this link:
Jan 23, 2011 | 1998 Pontiac Bonneville
Need to see what part is code 32
Dec 09, 2010 | Chevrolet Silverado 1500 Cars & Trucks
My Central heating system as no vent
You are talking about a gas fired system I assume. So no, it's not a big deal. Code now states that you need to vent the gas furnace from the attic or a crawl space and not from the living space. They change this code back and forth all the time. It's nothing to worry about if you do not plan to sell the home.
Apr 01, 2009 | Protech Systems FasNSeal FSWMKE4 4" Vent...
You need to get into the installer setup. Download the installer manual from Honeywell or an on-line vendor and it has the installer codes to alter the maximum heat setting. Press the system button and then buttons 2 & 4 at the same time for 5 sec to enter the installer mode. I believe the code is 0600 and then you enter the max temp for heat setting. Press done and your done!. Try this link for the installers manual
Jan 21, 2008 | Honeywell Programmable Thermostat Heater
Cell Phones Logo
245 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
