Question about Dell Dimension 3000 PC Desktop
I have no sound
My computer recently crashed and I went thru dell support to get windows and the drivers reinstalled. And now I have no sound. Not sure what to do. And I even updated the drivers.
  • 68 Answers
Its better whenever you are downloading any driver for your dell computer try to put the service tag of your computer instead, so that it will direct you to the actual hardware that you have on your system.
Posted on Oct 31, 2008
    Scholar:
  • 35 Answers
Download The Driver from this link and save the file into the desktop :
http://support.dell.com/support/downloads/download.aspx?c=us&l=en&s=gen&releaseid=R94481&SystemID=DIM_CEL_3000&servicetag=&os=WW1&osl=en&deviceid=2430&devlib=0&typecnt=0&vercnt=3&catid=-1&impid=-1&formatcnt=1&libid=3&fileid=122481
After Download, double Click on the the file and just follow the on screen prompts to install the Driver than restart the computer. If still there is no sound coming out of the speakers. The problem should be on the physical connection of the speakers to the system. Check the speaker connection and make sure the cable is plugged in to the right audio port at the back. If you are not sure where to plug the speaker cable, play a music and try each port. (Make sure that the speaker has power as well - Applicable for speakers with power adapters).
Posted on Oct 28, 2008
Widi crashes on start, can someone help?
If your system is running a Windows operating system, you should remove the WiFi manager that dell supplies. The Windows one is the most effective and efficient. When you have more that one system trying to do the same job you will always have a chance of conflict. If you are getting a "Blue Screen" when your system crashes then you should remove anything you have fitted since it was working properly. This type of system crash is usually caused by a hardware problem-either physical or driver based. To eliminate the drivers from the equation you should try and run your computer in "Safe Mode". this allows the system to run without external drivers.
Apr 04, 2013 | Dell 14Z-N411Z
No sound. My system crashed and I've had to reinstall windows xp, now no sound. I've restared system, went to device manager to adjust volume(can't says no sound card?, enabled system, etc. any help? Steve
hi steve
You need to go to the dell website and download the latest drivers for the sound first.
after you install those drivers, go to device manager and check if there is any Audio and sound option there or not.
Feb 05, 2011 | Dell (8H390) Sound Card
Recently i formatted my laptop (Dell latitude c400). i installed fresh copy of windows XP. i finished the installation but when i open it again after i turned it off, i think it crashed (i hear the start...
You would probly want to completely reformat and reinstall your copy of XP, if it is already crashing on a fresh copy, it most likely didn't install correctly. Make sure you format first. You can do this before you run your installation. Reboot your computer and hit f8, select the option that says command prompt with networking. when the screen comes up with the C: type in there vol you will need the volume label to format, it will display this for you and make a note of it. At the next C: type in there C: format it will ask you to enter the volume label, do this and hit enter. It will then ask you if you are sure you want to delete all data, type y and hit enter. It will go through the format process. Enter your XP cd into the drive and reboot your computer, you should now be able to reinstall windows with no previous errors or versions already installed. Hope this helps!
Lori
Oct 13, 2010 | Dell Latitude C400 Notebook
ASUS Web Cam not Working!!
You have a bad webcam driver it may be corrupted you can unistall and reinstall the driver. :)
Jul 30, 2010 | ASUS Eee PC 900 Notebook
Audio driver for dell dimension 4700 will not work
This tutorial will guide you through the process of updating your hardware driver. If you have the recovery disk from dell, you will have on it a copy of the original drivers for your sound device. See also this dell support article.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Sep 03, 2009 | Dell Dimension 4700 PC Desktop
My Compaq Presario V2000 will not start.
Ok, this makes sense. If this was a legit dvd, then it most likely had extra content on it (like wallpaper, sounds, etc) that installed something that crashed a driver.  If it wasn't legit, then the "player" that was used to play the movie installed something that crashed a driver.
If you can. I would reinstall some drivers to start.  Have you tried the "Last known good configuration" option?
Then if reinstalling drivers doesn't work, I would just restore the Windows OS.  But remember to BACKUP YOUR FILES.....once you restore it will be erased.
That compaq is a good machine unless you really want another PC this is fixable.
Feb 15, 2009 | HP Compaq Presario V2000 Notebook
Dell sound driver
Check and see if you need M/soft UAA sound driver first
A lot of built in sound cards require these drivers B4 normal sound driver will install and work
Sep 26, 2008 | Computers & Internet
No sound and not reading sata drive
What was the cause of the crash? Could it be related to the SATA drive or the sound problem?
You may need to enable SATA in the BIOS. Look closely at the BIOS options.
In Control Panel/Hardware/Device Manager/Sound look to see if the sound driver is installed. If not, look on the manufacturer's site for the driver and install it.
Make sure the sound is not muted and the hardware connections are correct.
Nov 15, 2007 | Chaintech 9CJS ZENITH Motherboard
Dell Dimension 3000 PC Desktop Logo
136 people viewed this question
Alun Cox
