Question about Xerox Office Equipment & Supplies
My phaser 8560 won't say on, so it prints out the cleaner page and info pages daily after the very long warm up session. How can I keep it running so I don't burn through this very expensive ink.
    President:
  • 2,072 Answers
Here you go.
To enable or disable the Power Saver (Energy Star) mode:
NOTE: The printer will only have the Power Saver menu selection if the printer was sold as an Energy Star machine.The Power Saver mode can only be enabled or disabled from the Control Panel.
  1. Press the [Up] or [Down] arrow button on the Control Panel to select [Printer Setup] on the Display Screen, and then press the [OK] button.
  2. Press the [Up] or [Down] arrow button to select [Printer Controls], and then press the [OK] button.
  3. Press the [Up] or [Down] arrow button to select [Power Saver], and then press the [OK] button.
  4. Press the [OK] button until the required option is displayed; either 'On' or 'Off'.
  5. Press the [Down] arrow button to select [Exit], and then press the [OK] button to return to the main screen.
Posted on Oct 29, 2008
My xerox phaser 8560 is printing muted color
First off on your screen access troubleshooting, and perform the remove light strips and also remove smears and skips.
Next go to Xerox.com, under support and drivers enter 8560 in the search box. then go to the support page.
You want to look up the procedures for TEC color correction. And follow those steps.
If you are using a generic ink then, all bets are off in getting true color reproduction.
Feb 10, 2010 | Xerox Phaser 8560DN Printer
Phaser 8560 not printing RED correctly
Even though Media Sciences ink is not compatable and is subject to burning and clogging your printhead, the most telling symptom you listed is the red shavings. This indicates the ink is not releasing from the drum properly. This version of solid ink has a problem with the cams on the maintenance camshaft cracking and this causes the maintenance kit roller to not oil the drum properly. You will also hear an odd noise either grinding, groaning or a slight tearing sound. This requires a technician to resolve as replacing the camshaft is not an enduser job. Print quality issues are either the printhead or related to the camshaft failing, there are a few others but they wouldn't exhibit the symptoms you listed.
Jan 11, 2010 | Xerox Phaser 8560N Laser Printer
Xerox 8560 is very hot even in sleep mode
the fusers get about 300 degrees to melt the toner to the page. If you do not have the phaser clean regularly, the paper dust that is next to the fuser could smell like it is burning.
Jul 16, 2009 | Xerox Phaser 8560MFP Laser Printer
Phaser 8560 magenta ink not transfering to paper
Hi jbasset285: Your printhead may be bad do to third party ink.
Try these steps first.
Diagnosing Print-Quality Problems
The Troubleshooting Print-Quality Page provides a good overview of the most
common print quality problems. To print the Troubleshooting Print-Quality Page,
follow these steps:
1. From the Control Panel, scroll to Troubleshooting, then press OK.
2. Scroll to Print Quality Problems, then press OK.
3. Scroll to Troubleshooting Print Quality Page, then press OK.
The Troubleshooting Print Quality Page includes instructions for printing the
Eliminate Light Stripes test print. These instructions are also provided on the next
page of this manual. The Eliminate Light Stripes test print indicates individual weak
or missing jets or an obstruction in the imaging path that affects a vertical band down
the entire page. Also, you may see color variation from jet to jet on the Eliminate
Light Stripes test print. Some variation is normal, occasionally occurs, and usually
self-corrects within a few printed pages. If a print-quality problem is not resolved
with the information provided in the Diagnosing Print-Quality
Nov 26, 2008 | Xerox Phaser 8560DN Laser Printer
Xerox Phaser 8560 mfp Printing issue
That really sounds like you need to replace the maintenance kit.
The white roller most likely is black and has depleted itself of lubricant a bit prematurely.
May 21, 2008 | Xerox Phaser 8560MFP Laser Printer
Xerox Phaser 8560 Waste INk
Although I agree totally, the anwer is no. Althought it appears black, take a piece of it an use it like a crayon. It is a combination of all the color inks combined. So if you take and rub it on a piece of paper it will be a purple color. So threfore would not create proper colors.
Now to save ink, Do not turn the printer off at all. Just let it use its own sleep mode. The power consumption is intermittent to keep the print head warm and uses about the same ammount of electricity as your refridgerator light bulb. The reason being, when you turn off a solid ink printer, it purges the print head of ALL old ink and dumps it into the waste tray. That is part of those weird noises you hear when you cycle up the machine, one is a compressor emptying the print head.
Also, honestly, althogh I am not sure what you are using the machine for. But you would be wise to put that product on a pay per page maintenance agreement. That includes all ink and all service. Some of the parts for those printers are super expensive.
I will say one thing you can do with that waste ink, if you know anyone who has children, they can use them as purple crayons..
Feb 21, 2008 | Xerox Phaser 8560DN Laser Printer
Phaser 8560 won't communicate with me or my computer
What you can try is making sure the ink sticks are fully in the loaded position. They may be keeping that cover from closing totally.
The other thing is the actuator on that cover, may have briken off and is not properly actuating the sensor that tells the machine the cover is closed.
Make sure the ink is fully forward, and look at the covers for some area of beoken plastic.
Jan 12, 2008 | Xerox Phaser 8560DN Laser Printer
362 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
