Question about D-Link Wireless
Wireless router dlink dire-301
I can see my network , but cant connect, even though i have the correct pasword
    Genius:
  • 1,124 Answers
1) Check and test your firewall. Your firewall, especially if its a software firewall like ZoneAlarm, Black Ice, Norton Firewall or something else could be blocking the connection. Disable your firewall and test the connection. You may have to resolve the problem by even uninstalling and reinstalling the firewall.
2) Check your IP address - Renew your IP address
3) Reset your TCP/IP stack by downloading and running WinsockXPFix.exe a Visual Basic program designed to fix corrupted TCP/IP issues, host file problems and a variety of other connectivity issues.
Posted on Oct 28, 2008
Dlink wbr 2310
change the password with a new one (not the default), then change the ssid with a new one (not the default). then reconnect
Aug 25, 2013 | Computers & Internet
I have a dlink n150 router dir-600L. i tried to configured it and changed the SSID and network key. the problem is, i cannot connect it to the wireless connection even though the network appears on my
Did you enter the security key (password)? It may be your laptop? Try resetting the D-Link to default settings and connecting to the laptop. They reconfigure the SSID and Security Key. Write down the info for future use. Here's a user Manual: http://www.dlink.com/uk/en/home-solutions/connect/routers/dir-600-wireless-n-150-home-router
Jan 24, 2013 | D-Link DIR601 WirelessN 150 Home Router...
Laptop cannot aquire network address from wireless router
If you connect the computer to the router , it works.
That means the wired connection is OK.
Open the set up page of the router check the wireless settings of the router.
I think your network is secured and you are not typing the correct network key.
just open the router set up and check the wireless settings .
Make sure that the DHCP server on the router is enabled
Click Here for step by step solution
Apr 30, 2010 | D-Link 802.11g Wireless Router WBR-1310...
My dlink dir 301 wireless router has stopped working. Laptop airport can see dlink but there doesn't seem to be a signal. Couple of lights flashing on router??? Help
May be due to the exceed in the range of the router.Change the direction of ur wireless router towards ur machine .
Apr 29, 2010 | D-Link Wireless
Can not connect to internet
My first guess is that your Dlink ADSL modem is really a modem router, so you are getting double routing. Sometimes this works just fine, though, so I'm not confident that's the whole explanation.
You'll need to setup your IP plan carefully
set the D-Link modem(router?) to bridging mode & the DLink wireless router does the login to Exetel.
DLink wireless router WAN side: DHCP + login to Exetel
DLink wireless router LAN side: 192.168.0.1
Subnet 255.255.255.0
DHCP on: range 192.168.0.10 to .20
DNS Servers: 220.233.0.3, 220.233.0.4
with PC's wireless adaptor set to DHCP
so picks up eg:
IP address: 192.168.0.10
Gateway address: 192.168.0.1
Aug 03, 2009 | Computers & Internet
Need software for dlink dir 301 wireless router
Here is the link to the manual for your router. Follow it's instrunctions to login into the router and from there you can run the setup wizard. If you feel comfortable in doing so, you can set the wireless configuration manually. Please reply if you need specific assistance.
http://74.125.93.104/search?q=cache:FT1VlyIdfuUJ:ftp://ftp.dlink.co.uk/dir_products/dir-301/DIR-301_Manual_English.pdf+dlink+dir+301&cd=5&hl=en&ct=clnk&gl=us
Good luck and thanks for using FixYa!
Apr 09, 2009 | Computers & Internet
Cant connect my laptop wirelessly...
Try to reconfigure your wireless network on your DI-524.
To access the configuration page of your router by Default type in on the address bar 192.168.0.1. On the login page by default the Username is admin and leave the Password blank.
If inside the the configuration page of the router
>Click Home
> Click on WIRELESS located on the left side and you will have the wireless setting of your network
> Change the wireless network name
> Under security choose either WEP or WPA -PSK for this type of router.
> Type in your new network key (also know as Passphrase of Key1).
For WEP use 0 to 9 Number or A to F character and it should be exactly 10 characters.
For WPA-PSK you can use alpha numeric from 0 to 9 and from A to Z. The minimun character would be 8.
> Click on apply
> Click on continue.
Try accessing your wireless network first using your wireless computer. If you are connected to your wireless network try connecting to the Internet.
Jan 27, 2009 | D-Link AirPlus DI-524 Wireless Router
Sir, i cant acces irles internet conection from my room,becuse i don't know pasword
Try accessing the configuration page of your router by typing 192.168.0.1 on the address bar of your browser and log-in to the dlink.
>Configure your wireless setting on this window.
>Under setup click on wireless setting
>Then click on manual wireless ....setup
>You will have the configuration of your wireless network.
>You may use WEP or WPA for your password on your security
>For WPA with pre shared key or passphrase the minimum character for your password is 8 characters
>For WEP with pre shared key of passphrase the minimum charactere for your password is exactly 10 characters.
>Once you have save your wireless network
>Go to your laptop and connect to your wireless network before
Jan 12, 2009 | D-Link Xtreme N DIR-655 Wireless Router
I have a dlink - dir-301 wireless router and i can connect, i can see my network but i can connect, even though all correct lights are on the router and i have the correct password
Oct 28, 2008 | Computers & Internet
Computers & Internet Logo
112 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
