Question about Kicker SX1250.1 Car Audio Amplifier
Wiring diagram 354xi kicker amplifier
I need a wiring diagram for a 354xi kicker amplifier .
    Problem Solver:
  • 9 Answers
Do you need the internal schematics, or how to hook it up? let me know.
Posted on Jul 05, 2009
I need to know how to wire 2 Kicker comp 10" subs
you can find your wiring diagram here
http://www.crutchfield.com/S-lCf6ewrWNQM/learn/learningcenter/car/subwoofers_wiring.html
Select from the list shown which describes your amp and subs (ie 2 channel amp with 2 4ohm subs)
Hope this helps and please rate, thanks
Mar 19, 2011 | Alpine MRP-M500 Car Audio Amplifier
Can kicker 1000x1 amp detect if my speaker is bad and turn itself off?
The Kicker 1000x1 Amplifier does not turn off if their is an Open Line (blown sub) on the Speaker Terminals.
  1. Remove all Speaker Wiring from the Amplifier, leaving the Power, Ground, Remote, and RCA wires plugged in.
  2. If the Amplifier fails to turn on, check your Remote wire for power.
  3. If the Remote wire is powering up with the Head Unit (should be anywhere from 5-12 Volts), check your Power wire for +12 Volts, and check your Ground wire.
  4. If you are getting +12 Volts Power and your Remote wire is putting out 5-12 Volts but your Amplifier still won't turn on, it will need to be serviced.
Jul 24, 2010 | Kicker ZX10001 Car Audio Amplifier
DONT KNOW HOW TO RUN 2 OHMS
Hello storres18,
If you have the Kicker model number 06CVX122, with dual 2ohm voice coils, they can be connected to a mono amp at 2ohms. First jumper the voice coils in series, the dotted positive (+) to the undotted negative (-) (or vice versa). Each sub is now 4ohms. Then wire both of the remaining positives and negatives together on the amp terminals (in parallel). The amp sees a 2ohm load. Here's the diagram:
If you have the Kicker model number 06CVX124 with dual 4ohm voice coils, they cannot be wired to present a 2ohm load. They can only be wired as a 1ohm load (too low for the amp) or as a 4ohm load (at reduced power). Here is the diagram of the 4ohm wiring:
Hope this helps.
May 10, 2009 | Visonik V900XD Car Audio Amplifier
2 channel amp to 6-6x9 wiring diagram
Hello magoocsl,
Yes, with the use of 2 high-pass and 1 low-pass crossovers, that Kicker amp will operate in what they call stereo and mono simultaneously (SAMS). You'd run 4 of the 6X9's in mono. Wire them in series-parallel with a low-pass crossover on the positive leg to the amp. The amp would see a 4ω load. The other two 6X9's would be wired as stereo, one to each channel with a high-pass crossover. Again, the amp sees a 4ω load.
Here's a link to the appropriate wiring diagram. The diagram is on page 5. Just substitute your 4 6X9's wired in series-parallel where they show the "mono" speaker.
http://www.kicker.com/sites/default/files/02KX300_400_500_800_2AmpManual.pdf
Hope this helps.
Apr 01, 2009 | Kicker KX500.2 Car Audio Amplifier
Wiring details
thunder 81000D not bridgeable,i have two daul voice coils kicker cvr how would i wire them up?
Mar 30, 2009 | MTX Thunder 81000D Car Audio Amplifier
How to get the best out of this amp
"google" subwoofer wiring diagrams to find out how to hook it up to the right ohms and everything..........hope this helps
Mar 21, 2009 | Kicker ZX350.2 2-Channel Amp - 220W ZX...
Wiring diagram
What kind of "wiring" do you need?
Positive goes to battery
Negative goes to ground
Rem goes to remote turn on from deck.
Attach speakers to speaker terminals as labeled on amplifier.
Please be a tad more specific of what you are trying to do, and I can help further.
Jan 11, 2009 | Kicker 2-Channel Amplifier (06ZX2002) Car...
Kicker solo-baric L7
ok here is a real pdf manual from kicker and please rate me
www.kicker.com/06/tech-support/manuals/manuals/02SL7TechManualV2_0.pdf
Jan 21, 2008 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Kicker SX1250.1 Car Audio Amplifier Logo
733 people viewed this question
Top Kicker Car Audio & Video Experts
Professor_V
Professor_V
Tygh Duval
Tygh Duval
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
