Question about Sharp EL-2196BL Calculator
Calculator - fix decimals place problem, how to bring it back no decimals
  • bundoora28 Oct 28, 2008
    i want to remove decimals place when i turn on the calculato. it's currently shown as 0.000000000. how do you remove the FIX decimals place in the calculator.
    Thanks
How
Posted on Jan 17, 2010
Reduce the decimal places
Press the MODE key a certain number of times until you get FIX. Select it. You will be asked to specify the number of decimal places (enter a number between 0 and 9). You can also choose the normal mode. However, if the result is too small or too large, it will be displayed in scientific notation.
May 08, 2014 | Casio Scientific Calculator FX82
How to I stop my sharp EL-531X calculator from rounding when converting from decimal to scientific notation?
You need to select the number of decimal places you would like, or if you would like the calculator to behave as normal. Press SET UP and select FSE (press 1) . You now have 5 options.
0: FIX means you can choose a fixed number of decimal places for every calculation.
1: SCI means scientific notation and choose the number of significant values you would like to deal with.
2: ENG means engineering and the power goes up in multiples of 3.
3: NORM1 and 4: NORM2 are the usual or normal settings on the calculator. Most school calculations will use NORM1 mode.
Aug 28, 2012 | Sharp El-531x Scientific Calculator Green...
I can't see the numbers after decimal in TI-30XIIS. how can I fix the problem
Press 2nd [FIX] and then select from the menu a digit specifying the number of places after the decimal point or F specifying floating point.
Dec 01, 2011 | Texas Instruments TI-30 XIIS Calculator
For calculator TI-30X II S My solutions only come out in the tenth's place if its a decimal. for example: 0.123 will only show as 0.1
Press 2nd [FIX] to bring up the display menu. You can select the number of digits after the decimal point, or "F" to select the floating decimal display.
Apr 28, 2011 | Texas Instruments TI-30X-IISTK Scientific...
Is their away to round whole number on a ti30 calculator
To do this you need to set your calculator to a fixed decimal value. You can do this by Pressing 2nd + FIX (decimal point) and then setting it to 0 decimal places. This will round a number to the nearest whole number.
Hope that helps.
Apr 22, 2011 | Texas Instruments TI-30XA Calculator
How do i turn off "fix"?
All results are displayed to the FIX setting until you clear the setting by
either pressing [2nd] [FIX] [.] or selecting F (Floating) on the decimal notation menu.
Resetting the calculator also clears the FIX setting.
· After pressing [2nd] [FIX]?, you can select the number of decimal places in two ways:
- Press to move to the number of decimal places you want, and then
press enter, or
- Press the number key that corresponds to the number of decimal places you want.
· FIX affects only the results, not the entry.
Nov 25, 2010 | Texas Instruments TI-34II Explorer Plus...
Decimal places
To put the calculator back to NORMAL mode, try [2nd][FIX] then [ . ] (decimal point).
Oct 05, 2009 | Canon F-502 Calculator
Show two decimal places
Input the following and try:
  1. Press 2ndF and . the point button. This changes the screen to FIX DEG
  2. Press 2ndF +/- 2 Answer shown is to 2 dec. pl.
  3. If you want it to 5 decimal places, Press 2ndF +/- 5 answer shown is to 5 d.p. and so on
For normal, just take calculator out of FIX so just DEG shows.
Couldn't find you a YouTube video, so text will have to do.
crimsonnightt@hotmail.com
Apr 01, 2009 | Sharp EL-738 Scientific Calculator
EL-1197PIII Sharp Calculator
move switch for decimal places to "add",or to number "2" for 2 fixed decimal places
Feb 28, 2008 | Canon LS-100TS Calculator
Sharp EL-2196BL Calculator Logo
834 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
