SOURCE: How do i get the top off of my duravit toilet??
try to check if there is any screw on the side of pulling knob...try to pull it and chek around it...good luck!
best rgds Stefano
SOURCE: my duravit toilet keeps running
Sounds like the flapper valve on it. Let me know the model number and I can hok you up with more info on it
SOURCE: How do I remove the toilet seat for duravit
You need an open end wrench or socket I believe 9/16 is the size
SOURCE: maybe I'm an idiot but I don't know how to get the top off of my
If yours is like mine, which has the flush and half flush that make up a circle, do the following:
Press either the flush or half flush.
Lift up the other half. (It should come straight out)
Lift up the remaining half.
There should be a white plastic screw that you can then remove.
Hope this helps.
SOURCE: cannot remove top of cistern
There are some dual flush cisterns where you have to depress one button to reveal a cavity in the second button. Put a screwdriver in that cavity to lever out the second button, then release the first button and prise that out.
Underneath the buttons is a screw which must be unscrewed to release the cistern lid.
Not sure if this will apply to you... but if not, good luck anyway.
