Question about Acer AL2016W 20" LCD Monitor
"Input Not Supported"
I used my laptop from home logging into GoToMyPC and everything worked fine. I got back to work and now my monitor is black and displays "Input Not Supported". I switched my monitor with another in the office and they both work fine on each other's computers, but I cannot get any display when I hook it back to my tower. I called Citrix and they claim it has to be my monitor. But other monitors work on my computer and my monitor works on other computers. What could be the problem?
  • 1 more comment
  • miscyn57 Oct 28, 2008
    it seems to be with the settings 1280 x 768...I get a black screen with these settings...there's no problems with the connectors, pins or anything.
  • alexmarrett May 11, 2010
    I have a similar problem but the solution you have suggested does not work for me. I used my lowest resolution 640X480. I still get the message "INPUT NOT SUPPORTED". Is there anything else I could try? Thanks
  • Frank
    Frank May 11, 2010
    what type of connector are you using?
    analog or digital?
    check the pins on the connector.
    Genius:
  • 1,605 Answers
What type o fmonitor are you using??
try to reset the monitor back to 800X600 or 1280x720, 60HZ or max. 72Hz
Posted on Oct 29, 2008
"Input not supported" even though it appears to be displaying correctly.
You will need to go to advanced settings under resolution options and set the display to 60hz refresh rate then go back to resolution and set your native, the problem is its probably trying to default to 75hz and is causing an issue
Apr 21, 2015 | Planar Computers & Internet
Why is my dell inspiron 531s stuck on black screen with input not supported message?
Start pc in safe mode and try to change resolution.
Then update the graphics driver.
May 06, 2014 | Dell Inspiron 531s Desktop Computer
19LVWK (Black) LCD Monitor: input not supported -- I have tried F8,changing th...
No bent pins on the VGA cable? Bootup in safe mode, select VGA support and set the PC video resolution to he native resolution of this monitor, reboot.
http://s807.photobucket.com/home/budm/allalbums
May 18, 2010 | AOC 19LVWK LCD Monitor
"Input not supported" roaming on my screen
It means that the resolution of the windows is set too high for your monitor. You will have to find some better monitor to connect it to it, and then to lower the resolution, after that, it should be working just fine
Nov 15, 2009 | Acer P191WBD LCD Monitor
My w17e monitor says "input not supported"
Not quite sure what the question is that you have not already answered for yourself.
That monitor's maximum resolution is given as 1440 X 900 at 60Hz and installing a more powerful video card won't change that.
http://reviews.cnet.com/lcd-monitors/hp-w17e-lcd-monitor/4507-3174_7-32735619.html?tag=mncol;psum
JOAT
Sep 29, 2009 | HP w17e Monitor
Monitor no longer works with the desktop, only with the laptop!
Maybe your new monitor don't supports the signal of your computer. Try finding another one, or otherwise, buy a graphic card, that will be supported from your monitor.
Hope this solve your problem!!
Jun 13, 2009 | BenQ FP731 17" LCD Monitor
"Input Not Supported" message on monitor at boot
Sounds to me like the input has gone out of the boundaries the monitor supports. IE the refresh rate is too high frequency (normally 60 to 72 Hertz for LCD's) or the screen resolution has been set too high.
Go into safe mode and set it back to 1024 X 768 at a frequency of 60 Hz, once back into windows proper you can try higher resolutions and change your refresh, if the screen goes black or displays a message "Out of Bounds" or similar it should revert after 15 seconds if left alone.
Have fun
Apr 27, 2009 | Envision EN-9250 19" Flat Panel LCD...
Acer Second monitor
input is either digital or anolog can't be both
Jul 30, 2008 | Acer AL1715 17" LCD Monitor
Monitor
When your computer is starting up, hit F8 and you'll see the safe mode, safe mode with networking, etc. screen...You should see a choice that says "enable vga mode". Select that and windows will start and the os will select a screen resolution for you. After that, everything will work fine...I hope.
Good Luck!
Anonymous
Mar 15, 2008 | Acer X193W LCD Monitor
Acer AL2016W 20" LCD Monitor Logo
166 people viewed this question
Brian Sullivan
Brian Sullivan
