Question about Ovens
Need a user manual for Diplomat ADP3300
Moved into new home cooker hob and oven already built in
BADBOYJAY
  • 264 Answers
SOURCE: oven does not work
its just your heater element you will need to wright down your model number and go on ebay or go to your local appliance shop they might order you 1 there about £35 pound
Posted on Jan 07, 2008
SOURCE: DIPLOMAT SELECT 920/AHY4401 S/S OVEN MANUAL
I have a copy of the Select 920 double oven instruction manual. Send an email to sharemonger@tiscali.co.uk and I will reply with a copy in .pdf file format.
Posted on Sep 25, 2008
Illeagle
  • 525 Answers
SOURCE: I have moved house, and the oven is a Diplomat ADP
This is a very good source for manuals
http://www.managemyhome.com/mmh/
Posted on Sep 08, 2009
SOURCE: need a user manual for a Hygena diplomat oven
I have a manual for AHY3420, it's a very generic manual which covers different ovens. I am happy to send you a scanned copy if you send me an e-mail address.
I have the same oven and all the symbols have disappeared on the third dial (the one which switches on the oven), so I still haven't worked out which setting does what - I can just about make out a grill symbol, but that's about it. Is there any chance you could tell me what the symbols are on the 3rd dial?
Thanks very much.
Sigrun
Posted on Apr 25, 2010
SOURCE: Diplomat Oven ADP3650 Instructions
User manuals are hard to find.
The problem I had was setting the clock on a single Diplomat oven, with no clock button. Here's my solution :
DIPLOMAT OVEN OPERATING INSTRUCTIONS
The Diplomat single oven is controlled by two knobs and a set of buttons along the middle of the control panel.
The left knob sets the temperature of the oven, while the right knob selects the function to be performed, e.g. fan oven, grill, etc.
The buttons along the middle set the cooker clock, the start and end times of cooking, and the “+” and “-“ buttons will increase or decrease the time shown on the cooker’s clock.
PLEASE NOTE THAT THE OVEN WILL NOT OPERATE UNTIL THE CLOCK IS SET.
If there is any interruption to the power supply (including manually switching off at the main switch) the oven will not operate until the clock is reset.
Here’s how to set the clock:
First press simultaneously the first two buttons to the left of the control panel. They are marked as a Bell symbol (Alarm) , and a steaming Cooking Pot (Start of Cooking Time). Then immediately press the plus “+” or minus “-“ buttons to increase or decrease the time displayed. When the desired time has been reached, leave it for a few seconds, and it will remain set at this time. Any further changes to the displayed time will require this procedure to be repeated.
Hope this helps!
Posted on Apr 26, 2010
Where can I get a manual? Can it be downloaded? Thanks
.pdf user manuals can be obtained via steve.richardson@fisherpaykel.co.uk Quoting the exact model number located on the rating plate located on your appliance as detailed below.
Range Cookers
Behind the Drop Down Storage Panel beneath the oven door or on the Oven Chassis behind the door
60cm Freestanding Cookers and Ovens
On the Oven Chassis behind the door
Hobs
On the underside of the hob (any oven or hob situated underneath the hob may need to be removed to gain access.).
Feb 15, 2011 | Stoves Ovens
Diplomat Softline ADP0300 Gas-just not cooking ...anything!
Hi there..
I Just recently had the same problem, also with a diplomat gas oven..
The problem I found was down to a small resetable component under the main cover. ..
It took me ages to find the problem and I had taken the whole electical parts of the oven to bits before 'accidentaly' coming across this 'thermal switch' (located inside the main cover, at the top, behind the display module).. - to reset this there is a tiny red button between the connectors.. press this - and it should all be fine again... : One importnat note is that this may be tripping as a consequence of the fan not running or by my thinking not running on after the oven is switched off, leaving the casing to heat up and then trip this switch component.. - if this component is faulty it can be found in RS components or Farnell components.. look for Thermal swich manual reset part no: L100C 9082 470.
Nov 29, 2009 | Ovens
I have moved into a property that has a diplomat cooker. I am looking for instruction booklet for it can you help
Diplomat are no longer trading. These appliances where fitted with MFI kitchens who have also gone
Oct 19, 2009 | Ovens
Cant turn cooker on
Depending on the brand of oven, you need to get it off auto, and onto manual to be able to use oven.
You should find the info you require in your user manual.
Please rate my solution.
Thanks.
Sep 22, 2009 | Ovens
Diplomat integrated oven- 13amp?
You need to get an electrician to wire it in to a 30amp cooker outlet. It is 30amp rather than 13amp (like most sockets). It should go to its own fuse in the fuebox
Feb 22, 2009 | Belling XOU592 / XOU593 Electric Double...
Dec 24, 2007 | Ovens
Hope this helps!
Oct 10, 2007 | Ovens
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
