Question about Panasonic (WJ-HD316A/500) (WJHD316A500) Hard Drive
What hard drive is used in wj-hd316a
Does anyone now the make/model 250gb hdd used in a panasonic wj-hd316a dvr?
  • Panasonic Master
  • 27,725 Answers
The hard disk is divided into three partitions: "Normal Recording,"
"Event Recording," and "Copy." Image data is automatically
recorded to the appropriate partition according to the recording
mode. For the normal recording partition, the data is overwritten
when the capacity is full. The event recording partition prohibits
overwriting to protect data. Copy partition prepares data for
retrieval to external medium.
Hard Disk Partitioning Function* automatically
selects the partition to be recorded.
RAID5 distributes image data to multiple hard disks in the
extension unit. Upon hard disk breakdown, lost data can be
restored from other hard disks. When using one WJ-HD300A
Series unit, mirroring function is available for data backup.
RAID5 / Mirroring Function
Playback VMD
One VMD area can set one
playback image for motion
search.
WJ-HD300A Series
Conventional
(* 10, 13, and 16 screens are available only with the WJ-HD316A.)
Even when images from multiple cameras are displayed on a multi-screen,
live monitoring can be achieved on all cameras at a full rate of 60 ips
(image per second). Experience real-time,
full surveillance with
full-rate video images.
Full Rate Live Multi-Screen
4-window 7-window 9-window 10-window* 13-window* 16-window*
Multi-screen in versatile variations
GUI Setup Menu
Time Table
Actual recording result (Example)
hope it helps
Posted on Feb 26, 2012
Testimonial: "This didn't help me learn the make/model of the hard drive but I was able to find the information I needed after about 4-hours of digging around on www. Thank you Brian for the info, it will be hellpful when setting up the DVR."
Panasonic wj hd316a accessing through verizon router
If you're trying to access it from outside your network, you will need to setup port forwarding to whichever the recorder uses. Google "Port forward <your router model"
Mar 08, 2014 | Computers & Internet
Cann't connect to wj-hd716 via network
Hi
in some case, you need to check the compatibility view settings in the Microsoft IE.
- go to "Tools->Compatibility view settings"
- add the ip address of your DVR
- try open the DVR web.
Feb 17, 2014 | Panasonic Wj-hd716/4000 16-ch Real-time...
How i can see dvr hd716 in ipad
so far, you cannot view the Panasonic WJ-Series Recorder using other browser than Microsoft Internet Explorer. because it use ActiveX Component to view the Video.
you can acess the Web Base interface of the DVR, just input the IP Address of the DVR, set disable pop up blocker for your browser, then it will show.
in some case, other browser than Internet explorer won't show the web correctly.
Sep 15, 2011 | Panasonic Wj-hd716/4000 16-ch Real-time...
How do i connect to Panasonic Wj-hd716 from my iphone?
Sep 07, 2011 | Panasonic Wj-hd716/4000 16-ch Real-time...
We have a samsung DVR model number SHR2160. We require assistance on replaceing or checking the HDD? Can you help?.
What is the problem with the hard drive? Is it not working anymore? There are a couple of options you can explore. The easiest is to hook an external hard drive up.
Your DVR can use up to a 250gb external hard drive. It can also be upgraded internally, but unless you are familiar with changing out hard drives, I would not recommend this.
Mar 24, 2011 | Video Game Consoles & Games
How to control panasonic wv-cw960 through controller wv-cu161
how do i control my speed dome cam wb cw 960 connected to wj rt 416v, now that i dont have wv p416e 4 channel card in the market. i need to add rs485 cable but is there a connection port or do i need to add a hub i am talking about adding 3 units 960 units. pls advice.
Jan 08, 2010 | Panasonic WJ-HD316/6500 Series 16 Channel...
Tried installing hdd from cctv dvr to save it's contents.....
Most PVR's use a small linux micro operating system to run there menus and handle the drives, as such many of the drives used by them are formatted in Ext2/3. You will need to install a driver in windows that allows it to mount ext? drives and then you should have no problem accessing it. The link below will take you to a download site for a free driver, but they do ask you to donate. Please if it works throw them a bone as this is how they keep providing such useful software for all of us.
If this works, copy the files to your computer and then let the PVR reformat the drive, unfortunately when windows doesn't recognize the drive as being formatted, it marks it. That mark is messing with the PVR but after you add these drivers you should have no problem moving the drive back and fourth as it will recognize the drive and it's data in the future.
http://www.fs-driver.org/download.html
Hope this helps FixYa,
Chris
Jul 06, 2009 | Western Digital Passport WDXML800UE...
"could not repair disc" after power outage
If this happened after a power outage and not a hit/drop then it's probably fried the board to the hard disk, you can often get another board from the same model drive and fix it, by swapping the boards over.
May 25, 2009 | Pioneer DVR-640H DVD Recorder/HDD Recorder
Panasonic DVR WJ-HD500B
the Web interface will not open says page is not there
Nov 10, 2007 | Panasonic WJ-HD500BV/960
Panasonic (WJ-HD316A/500) (WJHD316A500) Hard Drive Logo
548 people viewed this question
Top Panasonic Computers & Internet Experts
micky dee
Computer Repairing
Computer Repairing
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
