Question about Frigidaire ATF6000ES Front Load Washer
Where do you put oxyclean? - Frigidaire ATF6000ES Front Load Washer
Air jet tub shoots out black flakes
it sounds like there is a build-up of some kind in the lines. Replacing the lines may be your simplest solution. Replacing the entire system would definitely fix the black flakes.
Dec 27, 2013 | Home
What dispenser should you use for oxyclean?
Hi if there are three dispensers, We assume one is for prewash, second for the rmain wash and the third for rinsing fluid.
So I would start with putting the oxyclean in the prewash dispenser.
Good luck
kolbrun
Feb 25, 2012 | Washing Machines
How do i clean the bassinet part of the pack and play?
a gentle cleaning solution of white vinegar and water or oxyclean and water would probably work just fine on a bassinet without damage.
Apr 12, 2010 | Graco Pack 'n Play
Ink pen splattered in Kenmore front loader washer...
I would try running a few empty cycles with some oxyclean through it...
Jul 08, 2009 | Kenmore Washing Machines
OxyClean in the gas tank?
Maybe being that he was a "Stortster rider" that's why he used it? I wouldn't put anything like that in the tank. No telling what results you may get when it contacts the parts in the system. Possible he was pulling your leg?
Nov 20, 2008 | 1993 Harley Davidson XLH Sportster 883...
Can you use Oxyclean along with detergent in front loaders?
I use 2 Tablespoons of Liquid Detergent and a 1/2 to 3/4 scoop of Oxyclean and I have had good results in my Front Loader. Clothes come out very clean and there is no residue on the inside of my washer.
Jul 26, 2008 | Frigidaire ATF6000ES Front Load Washer
Washing machine wm1814cw
Check the wire ring that goes around the rubber seal located just inside the door - we had to call a repair person out one day because our door was leaking, and he told us it's important that the spring be at the top of the door opening to prevent leaks from happening. He had a hard time moving the spring to the top but that seemed to help.
A few months later we found a water leak from our soap tray, so we had the tray replaced under warranty, although I'm not sure that helped because the replacement looked identical to the old one. It only leaked when we used powdered Oxyclean and liquid soap in the tray at the same time; the leaking water ran behind the front cover and dripped out onto the floor all along the front of the machine, mostly near the left corner, but we stopped putting Oxyclean into the tray & the problem stopped. Hope that helps.
Feb 05, 2008 | LG WM1814CW Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
15 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
