Question about Baumatic 18 in. BDW45.1 Built-in Dishwasher
Door will not shut.No error code.Door keeps springing open!
Checked for obstructions none found
  • 1,214 Answers
Hi there
If this door was mine I would get the dishwasher -doctor to come and fix the door. On the other hand if you have a good friend who likes repairing things he might talk to your machine.
kolbrun
Posted on Feb 25, 2012
The only thing I have is an idle,Bogs down like plugged exhaust
It is probable a clogged catalytic converter if it has one. Sounds like it is pluged or a valve is not opening when throteled.
Jan 28, 2014 | Mercury Grand Marquis Cars & Trucks
Door will not stay shut
There has to be some sort of spring on the door latch assembly that keeps the door closed. If broken or no tension the door will not latch and spring open. And when the door springs open, a safety switch shuts the machine off.
Nov 21, 2013 | Bosch Nexxt WTMC3321US Electric Dryer
I am getting a E1 F5 error on the oven - what is the cause?
E1 F5 error is indicate that door latch is not working
This may display if the door is not shut properly, if it is jammed or if the spring-loaded mechanism has broken. Make sure door is completely closed and switch is closed. Test latch, solenoid and actuation switch (require an ohm meter to test).
Considerations: Try opening the oven door and shutting it while putting pressure on the center of the switch until you hear a click. Jiggle the latch to try and reposition it so that it shuts properly. Examine the latch to make sure it is properly attached.
Prevention/Solution: If none of those methods remove the error, you may need to replace the door latch. Visit the Whirlpool customer service website to find the correct part you need.
Hope this helps.
Jun 02, 2011 | Ovens
Error message! I just got a Kodak 5210 printer and it keeps saying "printhead carriage jam. open printer access door. clear any obstruction. check installation of printhead and ink cartilages. close...
To resolve the error condition:
1. Disconnect the power adapter from the printer.
2. Wait 30 seconds to allow the printer to reset.
3. Connect the power adapter to the printer. Turn the printer on if necessary.
4. Wait until the printer is ready to use.
If the error condition continues:
1. Open the printer access door.
2. Remove and install the print head two times. - See http://faqs.kodak.com/atg/faq/attachments/AUR1780-2.pdf
3. Close the printer access door.
5. If the error is still displayed, contact Kodak
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 03, 2011 | Computers & Internet
Door drops hard and i have an error code 7 -
The door slamming open is a broken spring/springs. They are very easy to replace - remove the screws holding the dishwasher in... pull out slightly and replace with good ones on the sides.
Can you clear the error code by shutting off power to it?
(Mdl # helps)
Dec 01, 2009 | KitchenAid Dishwashers
Door opens only 6 inches and stuck
I would try jumping a wire across the white & red terminal to see if your safety sensors are working Properly! If your door opens you have a loose connection or faulty sensors.
Oct 22, 2008 | Sears Craftsman LiftMaster Chamberlain...
Garage door stalls
The mechanical bearings and gears need some lubricants to smoothen the rotation. Try to apply some on the roller paths and joints
Aug 28, 2008 | Sears Craftsman LiftMaster Chamberlain...
I get an error code on my Whirlpool RF362BXKW range. I have shut down the power to the unit, have cleaned the unit and the error code won't go away. None of the oven cooking options work with the error....
What I did was hit cancel and hit the unlock button. Then I leaned against the door a bit as I hit the lock and hit the self clean and start the lock check dissapeared. I hit lock again and nothing else and it started the cleaning process.
Apr 08, 2008 | Kitchen Ranges
Baumatic 18 in. BDW45.1 Built-in Dishwasher Logo
108 people viewed this question
Top Baumatic Dishwashers Experts
Oloyede Monsuru
Kolbrun...
rich2481
Are you a Baumatic Dishwasher Expert? Answer questions, earn points and help others
