Question about Philips 32PW8608 32" TV
30" philips tv
On the post before I described loun squealing sound. When I turned the tv on tonday that had stopped, but now has no sound, just a little static. The picture has returned to normal.
0 characters
1 Points
After tv is on for approx 20-30 mins it starts to make a loud high pitched squeal or whine. once turned off for approx 10-15 mins can turn it back on for another 20-30 mins before squeal will return....
Sounds like a problem I had with a Polaroid t.v. Take the cover off the back and look for capactors that are buldging on the top. The top should be slightly concave. If they are convex at all, you can buy new one at Radio Shack and replace them for under $5.00
Apr 10, 2010 | Emerson EWF2004 20" TV
Philips tv with sound going in and out
Try bypassing the set's speaker by running an external audio amp. I use my bookcase stereo for audio direct from the satellite receiver and turn the volume off on the TV. Sounds better this way! Could be the audio amp in the TV is going bad or the speaker may be bad and the TV's audio amp goes through a shut down cycle.
Feb 10, 2010 | Philips 30PW850H 30" TV
I have a Philips Model 50PL9126D131. The sound
Your Y-Sus Board is blown. Replace it will be fine.
Jul 11, 2009 | Standard (CRT) Televisions
TV randomely turns off
it may just be a static buildup from the dust.
open the tv and blow it out with a air compressor.
if that doest not work then the circuit may be overloading.
remember it stores a charge for days.
Feb 17, 2008 | Philips 30PW9817 30" TV
Stopped working and squealing sound
Your set is shorted circuit condition. The power supply is making the noise. Unfortunately almost any of the hi current circuits will do this. If picture went out 1st look for video or hi voltage problems.
Jan 11, 2008 | RCA 32F531T 32" TV
Now it squeals when turned on
That is a CTC203 chassis that is VERY difficult to estimate without seeing it... The "squeal" symptom you described indicates that the HOT (horizontal output transistor) has shorted. (Q14401 RCA p/n#242224 (2sd2578)). But I would not stop there... Check also: Q14101 RCA p/n#244223, R14107 p/n#244214 (43 Ohm 1/4 Watt) and really go over the underside of the board for poor solder connections. Tri State Module can rebuild that board to like new for $100.00 dollars plus shipping. and even if a shop locally did the teardown and re-assembly that's a lot cheaper than the cost of a new TV of comaprable value. Hope this helps! Bill
Jun 04, 2007 | GE 31GT740 31" TV
No sound/picture
The set is what we call squealing because the power supply is sensing a problem and is screaming for help but that could be a good sound for a technician to find the problem fast and correct it inexpensebly.Keep it unplug to prevent more damage.
Sep 26, 2006 | Philips Magnavox 20MS233S 20" TV
Philips 32PW8608 32" TV Logo
Top Philips Standard (CRT) Televisions Experts
Sp Gupta
Jim Evans
Are you a Philips Standard (CRT) Television Expert? Answer questions, earn points and help others
