Question about Kenmore 98702 Stacked Washer/Dryer
Soot from gas dryer!
Sears kenmore- gas dryer-- soot in drum and on clothes!
was told it is a burner issue and that gas is not burning correctly-- dryer is only 6 years old,- anyone else have this issue? do i call sears or gas company? - or just get rid of the gas dryer and get an electric?
  • 31 Answers
Have you recently changed from natural gas to liquid propane, or visversa? if so, this could be the problem. especially natural gas to lp.
Posted on Oct 07, 2009
How easy to replace motor Kenmore kenmore 417.92042101?
Replacing a motor is fairly easy, but they are very expensive. It is often a better bet to just purchase a new machine, because whilst you have the machine that far stripped down, you might as well replace the rear bearing and the front drum slides.
Your motor is $87, so not a bad price. And as yours is a gas drier, it is probably a good bet to just replace the motor.
Kenmore Dryer Model 417 92042101 41792042101 417 92042101 Parts
KENMORE DRYER Parts ' Model 41792042101 ' Sears PartsDirect > Model Search Results for "41792042101"
Shop for KENMORE DRYER repair parts for model 41792042101 at Sears PartsDirect. Find parts, manuals & diagrams for any KENMORE DRYER repair project.
How to Replace a Kenmore Gas Dryer Drive Motor - YouTube
? 4:24
Jan 11, 2015 - Uploaded by Sears PartsDirect
Sears PartsDirect. ... This video from Sears PartsDirect shows how to replace a broken drive motor in some ...
Jan 13, 2018 | Cars & Trucks
My dryers smells like its burning and inside when drying gets really too hot. The air vent going outside is clean. I took off the casing and cleaned the inside of the dryer. The belt seems like its ok....
Lint burns quickly and rarely holds a flame long enough to cause a fire hazard. Metal burning would probably indicate friction on spinning metal, like the motor shaft, or the drum rollers. Plastic/rubber are usually parts that are intended to wear, and can usually be replaced.
Along with the belt, you should also check the idler pulley that takes up the slack in the belt, as well as any drum rollers or nylon glides on the top of the dryer door where the drum rides. Metal, plastic, and lint have distinct smells, and you should be able to determine which one(s) you have by smell.
Lint is a common burner in dryers, and it seems you've looked in some of the obvious places it can accumulate. When you have the cover off, pay special attention to the burner area, and any ducts from the lint screen area. Also, any gaps in insulation where air flows could cause hot spots in the unit. If you can see the flame while its running, make sure its size is not excessive. Flames should not be too low or too high, and should not escape the burner housing.
If you notice soot buildup, your gas/air mixture is off. If you've switched from natural to bottled gas or vice-versa, you may need to swap the burner orifices to match the different pressures of the gas fuel.
May 18, 2011 | Kenmore 74632 Gas Dryer
Black soot causing whites to be gray
I too have the same problem with my Admiral dryer. Have come to the conclusion that the soot is making all my clothes greyer, but just noticed it with my whites. Took apart my dryer today and first of all found that the outlet below the lint vent was plugged. There is no soot on the outside of the drum or the dryer housing...however there is soot within the metal tube that surrounds the gas burner. Seems the gas is not being burned properly or the plugged lint trap was not letting the burned gases escape??? Laura
Jul 17, 2010 | Maytag PYG2300A Gas Dryer
Clothes are getting soot during drying cycle, is there a leak somewhere? Amana gas dryer, model LG8459
i would have to ask if you using naturasl gas or lp from a bottle
soot is usually from the heater if your set up for the wrong gas you dont get a clean burn and soot is deposited in the dryer
Oct 07, 2009 | Amana ALG331RAW Gas Dryer
Dryer turns white clothes gray.
Replace Burner.
I have the same problem, getting ready to try and tackle this. I've been told it is the burner that is the problem, a crack or cracks in the burner are letting the soot into the drum instead of venting to the outside.
Dec 29, 2008 | Dryers
Black carbon/soot on the door and lint filter of my dryer
I have the same problem with a Maytag Performa gas dryer. My husband took our dryer apart and found that the burner tube which leads from the burner to the back of the dryer was full of soot (which was getting blown back into the dryer drum with the hot air.) We are cleaning it out now but would like to know how to prevent this from recurring in the future.
Dec 16, 2008 | Kenmore 62602 Electric Dryer
Burning smell & Soot
Thanks for the question It looks like a piece of clothing caught fire The back felt around the drum at back must be worn dismantle and vaccum out if the felt is worn badly it will allow clothes to slip through THanks for the question The appliance doc
Jul 20, 2008 | Kenmore 63942 Dryer
Gas dryer kenmore
take front off burner on bottom ckd exhaust vent to be sure it's clear poor vent may cause poor combustion
Apr 24, 2008 | Kenmore 72062 Gas Dryer
Black soot in dryer
There are several possible causes: a)  exhaust vent is restricted forcing the lint to enter the dryer shell and overheat and/or be picked up by the blower -- you seem to have inspected this b)  check the hot gas inlet to the drum.. on some dryers, lint buildup can occur in tight spots and it will overheat and char c)  ducting is not intact or leaks allowing lint to leak into the dryer shell -- this will occur over time, and all dryers should be taken apart and cleaned out on a regular basis... also, all ducting should be inspected and sealed as needed d)  verify that the inlet vents to the dryer shell are not blocked and allow adequate air flow to the burner assembly -- natural gas normally won't smoke due to incomplete combustion, but..  likewise, verify the room has adequate ventilation particularly if the utility room or closet is very small,  e)  check the drum drive belt, as it gets old, it will release dust and minute pieces which will be picked up by the blower -- replace if needed... f)  verify that the seals on the drum are still good -- replace as needed g)  as 'washer-tech' advised, do a thorough cleaning and inspection... put it back together with all ducting tight and free flowing
Jun 28, 2007 | Whirlpool GGW9200L Gas Dryer
Soot in gas dryer
it sounds as though your dryer may need to be converted for the use of lp gas.or you might have a burner problem.
May 28, 2007 | Whirlpool GGW9200L Gas Dryer
Kenmore 98702 Stacked Washer/Dryer Logo
146 people viewed this question
Sal De
 Brian Main
Brian Main
