Question about Thomson Audio Players & Recorders
Probleme reception casque sans fil tv thomson 3001
I cannot have any reception when plugging the base of wirless headphone through SCART plug (equipped with a side connection-wire and plug for headphones). I cannot use any other device because my TV is not fitted with an earphone plug. Where does the problem come from ?
SOURCE: innovage wireless headphones/how to connect to TV?
I have a plasma, and found when I plugged my HDR65 to back of the plasma audio out, it worked fine. does this help?
Posted on Jan 18, 2009
  • 20 Answers
SOURCE: No sound from the TV when the headphones are plugged in.
if you have a stereo unit(am+fm reciever) that has output to speakers, connect the out jack of the tv to input on back of stereo unit(aux in or cd input) then you can have output to headphone and speakers also.
Posted on Apr 07, 2009
SOURCE: RCA wireless headphones
Hey, my rca whp141 is incredibly quiet. Go ahead and turn the volume up on the TV.
If that doesn't work make sure
  • The headphones and headset are on the same channel (like 1).
  • the transmitter is on and working (Power: GREEN LIGHT)
  • the headset is on and working (GREEN LIGHT)
  • the headset is receiving a signal (St: GREEN LIGHT).
Hope this helps.
Posted on May 30, 2009
  • 51 Answers
SOURCE: Headphones: only left speaker works
yes if you have a multimiter and a soler iron, just check the cable where is moving allot, for example for the headphones near the volume controler, near connector or near you eyers is more likely to brake
Posted on Aug 20, 2009
Testimonial: "Yes, but it is probably brike between the left and the right speaker, is there any way to get to the cable?"
SOURCE: just bought the brookstone wireless tv headphones.
just received Brookstone Wireless TV headphones as a gift, trying to connect to Samsung Hi-Def mode HLR5067WAX/XAA. There is not 'headphone' jack so I connected the 3.5 mm to a pigtale for a RED-White cable.... any one have information on where the R-W cable is plugged into for sound???
Posted on Nov 25, 2010
Have hearing problem, need to attach speakers to TV. We can't find a port for plug
Most TVs have a headphone socket. Some have an audio output socket and others have a scart socket but I haven't seen a TV that has a means of attaching speakers directly.
If there is an audio output it can be connected to a hi-fi or an amplifier and speakers and similarly a scart adaptor can be used for the same purpose.
Probably the best and easiest way is to use the headphone socket and plug in a pair of powered computer speakers
Mar 26, 2017 | Audio Players & Recorders
I have a THS220 box and have difficulty recording programmes
Hello Joan,
To record a satellite you will need two scart leads.
Plug one end of the first scart lead into the "DVD/VCR SCART" socket on the back of the satellite receiver, then plug the other end into the "INPUT" scart on the back of the VCR. Take one end of the second scart lead and plug it into the "OUTPUT" socket on the back of the VCR and plug the other end into "SCART IN" socket on the back of the TV.
To record, select the satellite channel you want to record, then, on the VCR, select scart input, (at this point, you can record a satellite program). To watch a satellite channel or recorded satellite channel, select the scart input on the TV.
If you need anymore information, then let me know.
Kind regards,
Ron.
May 04, 2014 | Thomson Audio Players & Recorders
Tv goes silent when I put audio jack in to audio out
you suppose to lose the sound the sound is comming from the head sets right
Jan 16, 2014 | Thomson WHP3001BK WIRELESS HEADPHONES
I HAVE AN OLD THOMSON SKY BOX(NON HD) CONNECTED TO A SONY BRAVIA 32BX320. THERE IS A POOR RECEPTION ON SKY CHANNELS PARTICULARLY NOTICEABLE ON SKY SPORTS FOOTBALL WHERE IMAGES ARE "DRAGGING", "DELAYED
First step...clean out the "old" guy with clean, dry, compressed air to get dust off the capacitors and resistors. The frequencies that the "box" selects are regulated by those components. If this doesn't work you should realize that the electrical values of those components change as they age...and like grandma, can't do the tricks they used to.
Jan 12, 2013 | Televison & Video
I need to connect a surround sytem to my tv but cannot find an audio out on it
Depending on the TV you have and the surround sound system you can use the following:
An optical out cable.
Headphone jack to headphone jack (a cable with a 2.5mm headphone jack on both ends) you then plug this into the headphone jack in the TV and the other end into the audio in jack in your surround sound system.
You can also use a standard scart lead to plug into your TV and surround sound system.
May 03, 2011 | Televison & Video
My playstation 3 works find but I don't get any volume when I play my games
Try to determine what exactly is the problem:
Plug a pair of headphones in to your TV. If there is sound then you may have a problem with the TV speakers. If there is no sound then try fiddling with whichever cable you are using to connect your PS3 to the TV (either SCART or HDMI). Make sure each end is properly plugged in. It may be a simple case of a loose connection. If this does not work then switch cables to the cable that you have not yet tried (i.e. if you were using SCART then try HDMI and vice versa). If nothing works still then the most probable problem is that the cable is faulty. Try replacing it or using a different one.
Mar 06, 2011 | Sony Video Game Consoles & Games
Ihave got a dvdxvideo combi plus a thomsons freeview box could you tell me how to plug it into the correct places please
best connect via a scart lead on the freeview box plug into scart socket marked tv and the other end into tv then select the av funtion on tv remote.
Jul 12, 2010 | Toshiba Regza 32LV67U 32 in. LCD HDTV
I bought my husband some wireless headphones. The
All you have is to connect the 3 wires from the cable that is for going to the phones jack, at the pins 1,3,4 of the scart a/v of the tv. Mention that the shield of the cable (the one is going at the big outer metal of the phones plug) must connect at the pin 4.Here is a pinout of the a/v pins
I suppose that a euro a/v (or scart a/v) to RCA or mini jack adaptor is posible to be found at your market so you don't have to make one by yourself.
In case of a problem or clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
Feb 24, 2010 | RCA Personal MP3/CD Player
They Won't Work
You need to tune the headphones with the dial on the right ear phone as well as change channels on the base until you get good reception.
Hope that was all and it isn't anything worse. Good luck!
Dec 11, 2007 | RCA WHP170 Consumer Headphones
Top Thomson Audio Players & Recorders Experts
shaun taylor
Shehu Pro
Shehu Pro
 Mikey
Mikey
Are you a Thomson Audio Player and Recorder Expert? Answer questions, earn points and help others
