Question about Zanussi FJS1225W Front Load Washer
Zanussi jet system 1200 Will not start!!
I have just brought this washing machine from a friend, when i got it home and plugged it all in, i put clothes in, set the cycle and the door locked ready for the wash, but the start/pause switch is flashing and i push it and it beeps but it does not start, i have also tried switching it on and off, the other issue it the door it is permently locked and i cannot open it even when i switch the machine off and i cannot get my clothes out. Please can anyone help :-(
4 Suggested Answers
  • 1294 Answers
SOURCE: zanussi jet system 1200
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too. Press "end of cycle" to finish the mid stoppage..
Rate me pl.....if helped.
Posted on Jan 02, 2008
SOURCE: SKIP/RESET BUTTON NOT WORKING
abhishek33 Thanks for trying but this model is all electronic, no mechanical timers etc.
HOWEVER,
Left the machine on , (drying, as it could not be cancelled) overnight (not cheap) in Morning clothes very dry, door was unlocked and now washes ok. Dare I try the dryer again!
Posted on Nov 19, 2008
tunde007
  • 2382 Answers
SOURCE: i have a zanussi 1200 6kg washing machine.
Hi, the flashing red light is an indication that you have a problem with your machine not spinning and draining.
If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it.
If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Posted on Nov 20, 2010
Turn on my jet system 1200 fj 1254w xc just makes clicking sound
Obviously appeared family error code E40 (visible to the customer) what means a problem with door interlock. Could be: door open (mechanical failure), door interlock malfunction, the problem with main PCB (triac) or wiring. In service mode you can see exactly error code: E41,E42,E43,E44 or E45.
Dado
Jun 07, 2015 | Zanussi Washing Machines
Jets system has weak flow can I clear it?
most hoses come with built in filters can b removed
Feb 20, 2015 | Zanussi Washing Machines
Water in the fabric softner compartment after wash cycle
You need to poke all the holes clear in the top of the dispenser housing with a piece of wire or similar.
This should solve the problem.
Dec 15, 2009 | Washing Machines
Washing Tabs
Hi Zanussi do not recommend tablets for this machine as it is a jet system and uses far less water than conventional machines. it recommends liquids or loose powder to be used in the tray I know as I sold these for 10 years.
May 04, 2008 | Zanussi ZWF1440 Front Load Washer
Just wont work
  1. Turn it off.
  2. Unplug it.
  3. Wait 5 or 10 minutes.
  4. Plug it in.
  5. Turn it on.
Apr 09, 2008 | Washing Machines
Zanussi jetsystem 1200 XC leaking from underneath
Check the door below, it's pretty vulnerable.
Jan 19, 2008 | Washing Machines
Jan 02, 2008 | Zanussi FJS1225W Front Load Washer
Machne wont start
Hi. Dangerus to by-pass on off switch. Re check wires to make sure they are not burnt out, check wires to door lock for burn out, could be lock needs replacing.
Slim jim
Nov 08, 2007 | Zanussi FJS1225W Front Load Washer
Zanussi jetsystem Turbodry 1200
It appears that you may have a faulty door interlock or a faulty PCB. pcb is not really a DIY job as some boards require proramming on certain versions. Regards Advisor
Oct 30, 2006 | Zanussi FJS1225W Front Load Washer
Zanussi FJS1225W Front Load Washer Logo
175 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
