Question about HP 1040 Plain Paper Inkjet Fax
What does AU mean at the end of the date? - HP 1040 Plain Paper Inkjet Fax
  • Jill Cole Feb 25, 2012
    I need to break a password - how do I do this and not catch a virus.
  • HP Master
  • 1,684 Answers
Hello Jill,
If you are still using the HP 1040 fax machine please read the following article. That machine was recalled by HP last month due to a potential fire hazard.
http://www.ccl-la.com/blog/index.php/recall-on-hp-1040-and-1050-fax-machines/
BuddyMc
Posted on Mar 03, 2012
Could you help me with my roxy crushin krw222dr watch ? i cant set the time and date . please ?
Click on this link, to view the manual
http://media.quiksilver.com.au/media/rx/watch-manual/RX%20Crushin.pdf http://media.quiksilver.com.au/media/rx/watch-manual/RX%20Crushin.pdf
May 13, 2014 | Watches
Uranus facts
Mean distance from Sun:19.19 AU = 2.871x109 kmMaximum distance from Sun:20.07 AU=3.003x109 kmMinimum distance from Sun:18.31 AU=2.739x109 km
Hope this helps!
Oct 17, 2013 | Computers & Internet
Bought MMP501 in Sept 2009 Want current Map upgrade How do I get it?
http://www.hitachi.com.au/Admin/Uploads/Documents/f373d20e-820e-46b1-8aef-0da43082e0d1.pdf
Check this out, I'm guessing you are in Au. ? There is an e-mail addy to request the most recent up-dates! If you're not in Au. let me know, I'll try again to solve the problem!
I hope this helps!
Feb 25, 2011 | GPS
C66 BOTH RED LIGHTS FLASH
could mean number of things, but most likely your waste ink reservoir is full. Usually there would be also be an error message on your screen saying: "some parts of your printer have reached end of usefull life..." (or something like that).
You can either have the printer serviced, or reset the error using free software. Find more information here: http://www.inkbank.com.au/webcontent22.htm
good luck with it
LC1000
www.inkbank.com.au
Nov 30, 2010 | Epson Stylus C66 Inkjet Printer
Red light is on on dc05 motorhead, its usually green, loss of suction.
Hi there, VacuumGuru from VacuumSpot.com.au here. There are a couple of common causes of the red light being on. The first and best option is that there is a build up of dust and **** in the end caps of the roller itself.
This is relatively easy to sort out, just remove the base plate - it has little turn type tabs. With the base plate off just pull up one end of the brush first and remove the end cap (little dust cover) and clean it. Then put the cap back on and lift up the other end and do the same. Take a moment to get the hair and stuff off the roller too.
Now all you have to do is pop the baseplate back on and retest it.
If its now green all good!, however if its not it is in the mechanics of the head for which there are no spare parts. Unfortunately this means you will need to get a new one.
You can get a new head from Vacuumspot.com.au or NelsonVacuums.com.au
Hope this helps you out!
Aug 09, 2010 | Dyson DC05 Bagless Canister Cyclonic...
In excel how to display date in previous cell, a hyphen, and the end of that month
I'm not sure exactly what you mean, but you can highlight the cell that you want, right click, select "format cells", select "date" in the "numbers" tab and scroll through a bunch of different options for displaying the date.
Jun 08, 2009 | Oracle Database Enterprise Named User Plus
Need to change the time
You weren't precise if the change was due to Daylight Savings Time or just a general need to change the time so I'm giving you the complete set of instructions for changing the time
Setting the Time
Note: Use 24 hour and 60 minute format when setting the time.
For example: 2:00 pm = 14:00.
1. To make changes to your clock’s time setting, you must first put the clock into Program mode. See
section Accessing Program Mode to Update Calendar, Time and DST for instructions. When the
display flashes P1 dAtE, press the ◄ left button until P2 CL oc appears, then press the ● right
button.
2. Press the ◄ left button to choose 12-hour AM/PM display or 24-hour military time, then press the ●
right button.
3. Press the ◄ left button until the correct hour appears, then press the ● right button.
4. Press the ◄ left button until the correct minutes appear, then press the ● right button.
5. When the display flashes the correct time, press the ● right button.
6. The display flashes P2 CL oc again. To make changes to the DST start date or DST end date, press
the ◄ left button one time until P3 BDLE appears in the display and continue to How to Set the
Begin Date for DST. Otherwise, press the ◄ left button several times until END appears, and select
the ● right button to save your updated settings.
How to Disable DST
To disable Daylight Saving Time, set the DST beginning date equal to the ending date (i.e., DST begin
date = 08-03-09; DST end date = 08-03-09).
See next for details regarding setting the DST begin date and end date. Typically, clocks operating in
Arizona, Hawaii and Puerto Rico do not observe DST, and disabling the DST function typically applies to
those areas only.
By default, and unless otherwise modified, DST takes effect on the first Sunday in April and ends on the
last Sunday in October (this was the United States standard through 2006).
How to Set the Begin Date for DST
Note that in 2007 the standard for DST changes to a different start date and end date. The steps below
correct the change in the new start date for DST. The new start date and end date need only be changed
once, since the clock’s rolling calendar function auto-calculates the start date and end date for DST every
year thereafter.
Note that if the begin date for DST has passed, in addition to modifying the begin date (and end date),
you will also need to modify the time.
1. When the display flashes P1 dAtE (see earlier section Accessing Program Mode to Update
Calendar, Time and DST for instruction), press the ◄ left button until P3 bdLt appears, then press
the ● right button.
2. Press the ◄ left button until the correct year appears, then press the ● right button.
3. Press the ◄ left button until the correct month appears, then press the ● right button.
4. Press the ◄ left button until the correct date appears, then press the ● right button.
5. When the display flashes the correct year, month and date, press the ● right button.
6. When the display flashes P3 bdLt, press the ◄ left button once to select next menu option, P4
EdLt, which provides a way to set the end date of the Daylight Saving period.
Setting Daylight Savings Time for model PIX-10/15/21
Page 4 of 4
How to Set the End Date for DST
correct the change in the new end date for DST. The new start date and end date need only be changed
year thereafter.
1. When the display flashes P4 EdLt (see conclusion of previous section How to Set the Begin Date
for DST for instruction), press the ● right button.
6. The display flashes P4 EdLt again. Press the ◄ left button several times until END appears, and
select the ● right button to save your updated settings.
Note: To disable the Daylight Saving Setting, set the beginning and ending date to the same date.
Apr 16, 2009 | Office Equipment & Supplies
Mail not listed in order
Ok. Change the hierarchy to BY DATE, instead than BY NAME. (Just click on the DATE tab). The triangle pointing UP means NEWER FIRST, pointing DOWN means OLDER FIRST.
Mar 13, 2009 | Apple iMac G4 Desktop
HP 1040 Plain Paper Inkjet Fax Logo
73 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
