Question about Logitech Z-2300 Computer Speakers
Rca jackplug on L speaker - male rca jack pin broke off in main woofer, the yellow smaller one
How do I fix this... the rca assembly is all one piece soldered in...where do you get parts?
  • 57 Answers
Broken connector in subwoofer connection on receiver
The only thing you do is to open your receivers,then locate the output connector if you see the female RCA jack ,then push it out the broken piece ,that's it
Jul 27, 2008 | Audio Players & Recorders
Panasonic stereo
Most likley your Panasonic does not have an 1/8th" input. Go to your local rip off shack. Purchase an 1/8th" male to dual male RCA stereo jack. Plug the 1/8th inch into you laptop, the RCA Red and White into an input on your reciever. Select that input on your Panasonic and blow the windows out...
However if you have bought pc speakers that have a subwoofer and some smaller sattelite speakers they should already have the 1/8th" jack to feed them. Either way it should be an easy fix.....
Sep 02, 2013 | Computers & Internet
I have SONY DVD player DVP NS575P and SONY 5.1 channel how can i connect the DVD player to Sony 5.1 channel speakers
check behind your sony Dvd player for the RCA inputs and fix in the provided RCA cables, match the red jack pin to the red port, white to white and the other end which has one jack pin connect it to your woofer 5.1 speakers. check carefully where to connect as its clearly indicated IN. Remember the remaining yellow cable should be for video signal and the same connected to the monitor for video display.
Sep 15, 2011 | Sony DVP-NS575P DVD Player
I have a fisher price smart cycle and do not see how the wires fit onto the TV . the wires are yellow, white , red but i don't see how they fit am i missing something or some part that makes it fit?
Generally speaking, the yellow wire is for the video (the pictures and graphics on the screen), and the white and red wires are for the audio (the music and sounds for the speakers). The white wire would be for the left channel or speaker, and the red wire for the right channel or speaker. The connections for these wires are usually RCA phono plugs. These plugs have a small metal cylinder or jack in the center of the plug, and 3 squarish metal pieces surrounding the jack - the whole jack or plug looks a bit like a flower with its stamen in the middle.
These RCA jacks fit into corresponding holes or sockets on your TV that are color-coded just like the plugs are - there should be a yellow socket for the video, and a red and a white socket for the audio left and right. Most TV's have these sockets. On older TV's, there should be a yellow, red, and white set of sockets on the front or the back of the TV that the jacks from the wires you are trying to connect fit into. On newer TV's, like high-definition TV's, these sockets might also be found on the side panel of the TV.
You can check your owner's manual for your TV to see what sort of connectors/sockets it has available. Usually most TV's will have a set of RCA connectors to plug your wires into. Other types of connections include VGA, DVI, or HDMI. If you do not have any RCA connections on your TV (unlikely), then you can cheaply buy an appropriate adapter from your local electronics store or a place like Radio Shack or Wal-Mart.
Some of these adapters are called "Y-adapters," and allow you to connect all 3 of the yellow, red, and white wires, to the adapter, and then the adapter plugs into the appropriate connector on the TV, which might be a VGA connector, or even an HDMI connector. Again, check the owner's manual for your TV, and bring it with you if you need to go hunting for an adapter to connect your device.
For your reference, VGA connectors, the older type, are usually blue in color and have 9 pins for the male connector, or 9 holes, for the socket. Whether it's audio, video, electrical wiring, plumbing, or computers, the "gender" of a connection is always the same: the socket or holes end is female, the male or pins end is male.
The newer HDMI connectors are flat and have just one row of pins or holes inside a metal sheath.
So, basically, you need to figure out what sort of connections your TV has to plug into. If it has red, white, and yellow RCA phono connections, you are all set. I do hope that this has not confused you further! I do try to help, and I wish you all the best in connecting your smart cycle.
May 17, 2011 | Computers & Internet
How can i get the boston digital ba735 to work on my computer?
if now your computer not support this speakers,you must buy new soundcard support this speaker then build in to your computer hardware.good luck
Apr 28, 2010 | Boston Acoustics BA735 Computer Speakers
Connecting BA735 digital 3.5mm plug with S/PDIF coax jack
The male mono plug (from the left small speaker) should be connected into the right speaker (small speaker with controls) . After plugging the multi pin cable from the control speaker to the sub-woofer you need to plug in a signal source from your computer (or any other digital signal) into the sub-woofer. This digital input looks like an ordinary RCA plug but carries many channels of audio. That connects to the enabled digital output of your computer. Some computers output digital through a 3.5mm jack others look just like an RCA phono jack. If you are lucky some BA735 sub-woofers have a second input that is a standard 3.5mm stereo jack and it will take analog audio from computer, DVD, MP3 player or the like. I have three sets of these speakers that I love because of their big volume considering such a small size.
Mar 29, 2009 | Boston Acoustics BA735 Computer Speakers
No output from woofer connection
If I understand you correctly, your subwoofer does not have RCA jacks but speaker terminals only. This should solve your issue but I have seen less expensive ones in the past.
Mar 29, 2009 | Yamaha RX-V463 Receiver
Sony KV- 32V35 Front Jacks
Yes, the front RCA jacks on the Sony sets always seem to crack loose. I have seen that many, many times. To get to those jacks, you will have to remove the back of the TV and carefully pull out the main chassis, taking care not to pull out any wires or jacks. When the main chassis slides back, there is a smaller board in front of the main board, and the pushbuttons and RCA jacks are on that smaller board. The connectors to that board usually come off when you slide the main chassis back, so you will need to put those jacks back in place when reassembling. Slide the smaller board back, flip it over and resolder the connections on the RCA jacks. Sometimes I find that the copper trace to the center pin of the video (yellow) RCA jack is broken, so test for continuity and solder a small jumper wire to take the place of the cracked copper trace if necessary. Reassembnle the set and your jacks should be working fine.
Aug 31, 2007 | Sony KV-32V35 TV
Logitech Z-2300 Computer Speakers Logo
395 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
