Question about Dryers
Hot Point Dryer Model DLB 2750 BAL WH will not run. No light no anything
5 Suggested Answers
MARCLAVORIS
  • 110 Answers
SOURCE: Electric Dryer run too hot
wow, dont get burned, check your ventillation, make sure your vent is not clogged or smashed, if this continues, then change out your thermastat
Posted on Aug 23, 2009
jyackle5
  • 8197 Answers
SOURCE: I have a hotpoint dryer model # DLB 1550PHLWH I
You can buy the belt on the link below.
http://www.repairclinic.com/SSPartDetail.aspx?s=t-DLB+1550PHLWH-%3d%3di1472898&PartID=1472898
Good Luck and please rate 4 thumbs up for the free answer
Posted on May 07, 2010
heatman101
  • 43501 Answers
SOURCE: i have a hot point
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Posted on Nov 11, 2010
heatman101
  • 43501 Answers
SOURCE: Model # DLB 1550 BRL
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
heatman101
Posted on Jan 03, 2011
I have a Samsung dryer model #DVWhen I turn it on the check filter light comes on momentarily & the display shows as if the dryer is running but it is not. I cleaned the filter but still not working
the dryer isn't running most likely the belt could have snapped or you could have a bad thermal fuse inside the dryer,only way to tell is by getting in there and check it.next time send the full model number dv isn't anything.you can remove the top cover and check the belt,if it broke the dryer won't start there's a safety switch so if the belt breaks the dryer won't run,if the dryer never was taken apart and cleaned out one of the t-stats could have popped,also a safety if the dryer runs to hot the thermal fuse pops,all a dryer does is get hot spin the clothes and move air,if the vent line is clogged or sometimes people have a cage outside,it fills with lint,the dryer can't move the air outside,heats up and the fuse pops,you'll have to get in there with a meter and read them out.
Nov 05, 2017 | Samsung Dryers
Hot Point dryer DLB 1550 BALWH not drying clothes
There are several reasons for dryer not drying clothers.
It might help to go through the guide on this website. Hotpoin Dryers are rebadged GE appliance. So should be same.
IF you find a particular area or part that might need replacement then go to this page for parts availabiity
http://www.appliancepartspros.com/parts-for-ge-dlb1550bal.html
http://www.appliancerepair.net/clothes-dryer-repair.html
Apr 17, 2014 | Hotpoint Dryers
Hotpoint manual
Your blower wheel
Blower Wheel
Has a screw and a clip holds it to the motor I wonder if maybe you should check that. Lots of GE hotpoint dryer videos out there. Mine is kinda crappy but it does show how to get inside:
Jan 23, 2014 | Dryers
I have a Frigidaire Dryer model number GLER341AS2. The dryer runs fine, but won't get hot. I pulled the dryer from the wall to see anything obvious. I noticed what I thought at first to be anim
Are you mechanically inclined? You may have several problems. 1st, heating element is most likely burnt out. Then I would check ball and socket assembly that back of drum fits into. Also check felt in front of machine that drum rides on. May need competent service person on this.
Sep 13, 2017 | Frigidaire Electric Dryer
Model # DLB 1550 BRL WH Runs, but no heat
heatman101
Jan 02, 2011 | Hotpoint Dryers
Aug 16, 2009 | Frigidaire FDE647RF Dryer
Broken belt
Hi , in replacing belt try to trace where belt way to go outside remove some bolts be sure unplug power , in putting back belt is the same way go in to install belt.
Feb 21, 2008 | GE DCSR483EA Electric Dryer
Dryers Logo
69 people viewed this question
Top Dryers Experts
