Question about Whirlpool LER4634J Electric Dryer
MY DRYER BLOWS COLD AIR
IS IT A FUSE??? WHERE IS IT LOCATED. BY THE WAY ITS A WHIRLPOOL DRYER AND IS RAN BY GAS
  • mjzlp Nov 03, 2008
    1. I have placed a new thermal cutoff kit on the dryer and is still blowing cold air . Do you have anymore suggestion
    Scholar:
  • 112 Answers
Check your exhaust vent first to make sure it isn't clogged. Remove the vent at the dryer and run it for a moment to see if the air out is warm. If it's not, you've got to pull off the access panel to access the back of the unit. There should be a thermal fuse/cutout right near the burner tube. Ohm it out, replace if open. Next, you will have to try to run it without the back on to see if the ignitor is glowing hot. Also, check the gas valve for voltage when the unit is running (carefully) and see if the valve is getting voltage. If it is, replace it.
Posted on Oct 28, 2008
I have a whirlpool elect. dryer it runs but it blows cold air what could be the reason why
Hello & Welcome to FixYa
When the dryer blows cold air then the issue is with the Thermal fuse which is located on the blower wheel housing inside the rear panel that is bad and needs replacement. Please get back to me if you have any other questions.
Kevin
Nov 30, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Dryer jus blows cold air on heat cycle and i replaced thermal fuse
either you have an open limit or your element is bad . thermal fuse if bad won"t even let dryer turn on
Jan 25, 2010 | Whirlpool LGR5636L Gas Dryer
Dryer blowing cold air whirlpool awz3513
Check for a blown thermal fuse or a faulty heating element. Both components can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity indicates a faulty component. The thermal fuse is about an inch long and is located just inside the rear of the dryer and is usually attached to or near the exhaust duct. Hope this helped and best wishes.
Aug 31, 2009 | Dryers
Gas dryer wont heat up, blows only cold air.what would cause this
Could be a bad hi limit thermostat. Could be a bad glowbar ignitor. Check the glowbar ignitor at the gas valve, is it glowing bright orange/red? If not. Replace the ignitor.
Jul 22, 2009 | Whirlpool Dryers
Gas Dryer does not continue to heat.
Check the Following to address this issue--
1. Gas valve coils
Igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
2. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
3. Igniter
Igniter may burn out or break. Replace the igniter if found defective.
Note: Igniters are very fragile and break easily. It is recommended to handle the igniter only touching the ceramic part of it (usually white in color).
4. Flame sensor (or radiant heat sensor)
Replace the sensor (located near the igniter) if found defective.
Jun 02, 2009 | Whirlpool Dryers
Whirlpool Dryer blows cold air when starting no heat
Did the fuse blow out? If so then the heating element is shorted out. This happens frequently when they fail. If the fuse is blown check the condition of or change out the heating element.
Dec 29, 2008 | Weather King 12AJA4801AH Air Conditioner
ELCTRIC DRYER NO HEAT JUST COLD AIR
There is a thermal fuse its location depends on the dryer if the filter is on the top then you have to take off the back panel and check the white fuse. If the filter is inside the dryer you have to take off the bottom panel. a flathead screw driver for the 2 clips the check the white fuse behind the lint trap (where the filter goes).
Oct 29, 2008 | Whirlpool GGQ8831L Gas Dryer
Blows fuse for heat after about 30 minutes
yes , occassionally though it will run for full cycle ....but not very often
Sep 06, 2008 | Kenmore 73952 Gas Dryer
Whirlpool Lgr7646eq2 Dryer
Hi thanks for the question. most times the problem is with the thermal fuse . failure is caused by clogged venting. clean all vents . the thermal fuse is located on the air duct, inside the dryer on the left , a small piece of plastic, with 2 blue wires to it . replace thermal fuse. thanks the appliance doc
Apr 06, 2008 | Whirlpool LGR7646E Dryer
Whirlpool LER4634J Electric Dryer Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
