Question about Belkin (F5D5231-4) Router
Wireless router I am trying to get my wireless to respond to my laptop. I have a Imac that is connected to the wireless. When I got a new cable modem it wasn't secure. I got the info on who to make it secure but I then couldn't log on to the wireless. I have tried every thing I could think of to get it hooked up but to no avail. The laptop recognizes the laptop but I can't open up to the internet.
    Scholar:
  • 53 Answers
Start afresh, normally you will be able to find a hardware reset button on your router, it depends upon the make / model but the idea normally is locate the reset button press it down while the unit is powered off, keeping the button depressed power back on the router and keep the button pressed for up to a minute.
start with 10 seconds then work your way up in 10 second intervals.
you will know if it has worked by checking your computer and seeing if the SSID you entered changes back to the factory default one.
Posted on Nov 04, 2008
Wireless Router showing as connected, but cannot access Internet.
You have _THREE_ separate network connections to check:
1. your router, through your ADSL modem, to your ISP;
2. your computer, through an Ethernet cable, to your router;
3. your computer, through its wireless adapter, to the wireless adapter in your router.
So:
1. Connect the Ethernet cable from your laptop directly to your ADSL modem, bypassing the router.
Turn the router off.
Restart the modem.
Restart the computer.
Click Start
Click Run
Enter CMD and press ENTER
Enter IPCONFIG and press ENTER
You should get output like:
Ethernet adapter Local Area Connection:
* IP Address. . . . . . . . . . . . : 123.456.789.249
* Default Gateway . . . . . . . . . : 123.456.789.1
* Subnet Mask . . . . . . . . . . . : 255.255.255.0
Enter PING 123.456.789.1 and press ENTER
If PING does not respond, then telephone your ISP, and get them to trouble-shoot your connection.
2. Turn off the ADSL modem.
Connect the Ethernet cable from your laptop to one of the LAN ports on the router.
Turn the router on.
Restart your computer.
Click Start
Click Run
* IP Address. . . . . . . . . . . . : 192.168.0.100
* Default Gateway . . . . . . . . . : 192.168.0.1
Enter PING 192.168.0.1 and press ENTER
If PING does not respond, then your router is not working.
If PING does respond, connect another Ethernet cable from the WAN port on the router to the ADSL modem.
Turn the modem on, and wait until the flashing-lights on the modem, and on the router, settle-down to a steady pattern.
Type PING WWW.GOOGLE.COM and press ENTER.
If PING responds, then everything is fine.
3. If you fix #1 and #2, above, then your wireless adapter should work.
Apr 02, 2010 | Computers & Internet
A random guy came in and setup a home network for us using a Netgear Wireless router (WGR614v6). We have a PC on main level, an iMac and laptop in the basement that connect wirelessly and without any...
Hi whioch computer has a problem ?
A PC with the new hard drive ?
Mkae sure that you have the wireless adapter working on the computer.
If it is working then try to find the network .
Click Here for more info about wireless network.
Oct 08, 2009 | NetGear WGR614 Wireless Router
New iMac very very slow loading pages with Actiontec GT704-WG
I have seen this before and this has cured it:
Check the DNS settings in the Network panel and enter a manual DNS that matches the base address of the router (192.168.0.1 for this router).
System Preferences > Network > Ethernet > Advanced > DNS. Click the + sign and add 192.168.0.1. Click OK, and click Apply on the next screen.
macs2u
Aug 04, 2009 | Actiontec GT704WG Wireless Router...
Can't connect to AT&T VPN
as you told me that all the ports are open so in that case you can get in touch with your ISP and ask them to enable IPPASSTHROUGH on your office laptop.
Jan 17, 2009 | Zoom ComStar 56K 2818 Modem
I currently use a cable modem to connect to the internet from my Imac. I have dlink wireless router that I used to have for my old pc so that my work laptop could connect. How do I install the dlink on the...
No need to install the dlink on the imac. All you need to do is connect the modem first the dlink. (Modem connected to Internet or WAN port of the dlink). Now if they are connected, your imac should be plugged in to port 1 of dlink, and your PC to port 2. That should do it.
Nov 18, 2008 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
Belkin Wireless G wont connect to cable modem
If you switched ISP then you have tor reconfigure your router according to the settings of your new ISP.
Aug 24, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Wireless internet connection
I may be able to help with this...but I need a detailed description of how you have things connected between the XP desktop, the cable, modem, the Linksys router, and the laptop. Also, is the Linksys router new?
Typically, the wan port on the wireless router connects directly to the cable modem with a cat5 network cable....then the desktop pc connects to the router...on port 1 for example...with a similar cable. Once the wireless router is set up properly, the laptop should then be able to connect using wireless.
Feb 01, 2008 | Computers & Internet
IMAC 660H Router Wlan
Have you tried connecting to the router using an ethernet cable? this will allow you to set the router up, which in turn will allow wireless connectivity
Jan 29, 2008 | Zyxel Prestige 660H Router
D-Link DI-524 Router
You have interference...go into router and override the channel selection from auto to a different channel. The band is limited by the FCC and most manufacturers tend to default to the same channel (frequency). Dont confuse this with band...ex. G, N, B, A You want the actual frequency to change. Good luck
Sep 10, 2007 | Computers & Internet
Belkin (F5D5231-4) Router Logo
27 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
steve morris
steve morris
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
