Question about Hotpoint Washing Machines
Hotpoint wf865 1600 spin, whilst washing alot of water is coming out of the washing machine
  • Hotpoint Master
  • 1,205 Answers
OHOHOH water comming out of the machine.
You have cleaned drain pipe and the opening as well as the glass. You will find that if after this cleaning process and take a short wash with old pillow cses, Hvis der setter sig a lot of debris in the material, there is still alot of cleaning to do.
kolbrun
Posted on Feb 25, 2012
SOURCE: Hotpoint Ultima WF865
i have a wf 860p hotpoint washing machine and it has come up with an error code of f 08 can you tell what this error is and how i can fix it.
many thanks
lynette
Posted on Nov 04, 2008
barkencoa
  • 3463 Answers
SOURCE: I NEED PCB BOARD FOR
I have checked the Hotpoint web site, and a pcb is £114.00.
You also need the eprom which plugs into the pcb,this is another £24.00, and is unprogrammed, this means that it is a blank memory chip, and has to have the programmes put into memory.
This is something that only Hotpoint can do, so you have to add the cost of calling an enginner to the cost of the parts.
This as you can see, makes it very expensive to repair.
It would be in excess of £200.00.
There is one other alternative, and that is, if the washer is less than 5 years old, then you should be covered by the Hotpoint 5 year part guarantee, but you would have to confirm this with Hotpoint.
It would certainley be cheaper to do it this way.
Plz rate my solution.
Thanks,
Posted on Jan 12, 2009
barkencoa
  • 3463 Answers
SOURCE: Hotpoint Ultima Super Silent WF865. I'm getting
Error code F04 indicates pressure switch jammed on empty.
Remove the lower rear panel of washer.
Remove the large black hose fastened to bottom of drum.
Remove and clean the plastic filter inside hose.
Remove the hose onto the pump, and check for blockage or obstruction here.
This should clear the fault
please leave feedback for my solution.
Thanks.
Posted on Dec 14, 2009
Testimonial: "Excellent, thanks for your help, problem solved."
  • 104 Answers
SOURCE: Hotpoint washing machine - WF865 showing F-08 fault
F08: Heater control or NTC (Thermistor) temperature sensor problem.
Posted on Jan 28, 2010
  • 118 Answers
SOURCE: washing machine stuck in test mode hotpoint wf865
To get out of it you need to press start, the display should go daft. Press start again and the display should settle down. Now press the on/off button and the start button at the same time and hold them down for a few seconds until the display shows d-end or d-off.
Your machine should now work. hope this helps.
Posted on Sep 20, 2010
Hotpoint aqualtis AQXXL 129PI
could be a bad timer? sticking at the wash cycle. it does agitate right? other wise bad water pressure switch
Aug 07, 2014 | Hotpoint Washing Machines
The belt has come off my hotpoint WMA5 washing machine
offer the belt around the motor pulley first , feed one side of the belt to drum pulley , whilst holding this side to drum pulley turn pulley using other hand , belt should follow natural path onto pulley .
Jan 23, 2013 | Hotpoint Aquarius WMA56 Front Load Washer
My hotpoint wd 860 washing machine won't spin and
Indesit (Hotpoint, Ariston) 'F05' decodes as 'pump'blocked'.
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Following are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Jul 29, 2011 | Hotpoint WMA13 Front Load Washer
Hi my washing machine is working but it sletting out alot of water,i think i put a rug in,and the rubber bit at the back all came off and has blocked something,i e filter or sumthing?? i sthere anything...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 08, 2010 | Hotpoint Washing Machines
H20 ERROR SPIN DRYING
The error indicates a problem with the incoming water supply.
Check for restricted or kinked inlet hose/s, check that tap/s are fully turned on and that you have adequate water pressure.
Mar 27, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Drum won't stop filling with water
i think u need a bearing seal to ur washing machine so ur gona need a technician and if its gona coast a lot just change it
May 31, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Wash machine stays on wash cycle and doesnt go to rinse or spin
If the water is not getting hot, this will probably stop the programme advancing .Check heater.
Plz rate solution to prob.
Dec 10, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Washing Machines Logo
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
