Question about Dryers
Samsung DV665J NO HEAT SITUATION
After verifying and cleaning lint trap, rear unit vent, ducting, wall vent and venting slits in door and on bottom of unit. Also have resetted the breaker, just in case. I want to know the part number of the heat sensor and heating element on this dryer so that I may order them to replace them. Unless I am wrong and that there might be something else defective on this dryer that all works fine except the no heat situation. BTW the unit was purchased in 2008. drek4@yahoo.ca
5 Suggested Answers
ronpar
  • 27 Answers
SOURCE: Whirlpool Duet Dryer - Working but no heat
it sounds like your heating element is gone bad. there is no heat if they burn out or get corroded
Posted on Jun 29, 2008
huuum
  • 750 Answers
SOURCE: my dryer smells as if
Kandjmorse,
huuum At your service!
You told me that your dryer smells as if something is burning after running only a minute or 2, and the damp clothes are "smoking" NOT steaming. Vent duct is clean as is lint trap
I find two answers are possibilities for this situation.
1.If it is an electric dryer one of the connecting wires to the element is lose or not snug, and the electricity is arcing across the gape, so you smell a tiny bit of burn.
2. Or the thermostat is malfunctioning and you need hands on service to diagnose and change this part.
DO NOT RUN THE DRYER!
It is a fire hazard!
Sounds like a Thermostat problem to me!!
How old is the appliance?
If the appliance is 10 years old or more it may not be advisable to put good money into bad!
New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
And can pay for them selves in only a few years!!!!!!!!!!!!!!!!
You need a hands on tech for this repair!
You will be fine
Bless You huuum
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF
Posted on Sep 12, 2008
  • 12 Answers
SOURCE: dryer does not heat
Check the thermal cut-off, the thermostat, and the heating element. Most times one of the tree is the culprit.
I have seen a bad timer cause the no heat problem a few times but 99% of the time it is one of the three I mentioned.
If you change the thermal cut-off make sure you get both the cut-off and the thermostat. A stuck T-stat will take out a cut-off in a big hurry.
Posted on Feb 27, 2009
  • 10 Answers
SOURCE: Lint is not going into pull out lint trap. The lint screen is torn and lint is collecting behind trap.
Poor air flow would be my guess. How long is the vent hose? Does it have more than one angle/turn before venting outside? Is the lint gathering around the outer edges of the door? Keeping the length of air travel shorter will improve the operation.
Posted on May 12, 2009
Dryer wont heat up
If you are in the market for an Dryer Vent cleaning check out Dryer Vent Cleaning Dallas Tx.
Apr 08, 2014 | Samsung DV448AEE Electric Dryer
No heat in drum heat out of vent maytag mle2000ayw
Are you sure you dont need a professional Dry Vent inspection and cleaning?
Mar 17, 2013 | Maytag Neptune Dryers
I have a kenmore elite model 110.8586 or 8587 anyway I cleaned my lent screen put it back as I always do after every load and know it say check lint screen
Possibilities
The sensor is dirty..remove the lint trap and clean the orifice with a Swiffer duster. Dryer sheets can clog the lint trap use a tooth brush and detergent to clean the lint trap. Alternately see if it presents the same issue operating it without the lint trap. If you have an air compressor blow out the slot too. Make sure the main exit hose is cleared also *vent duct*. Tip the unit and blow the air in too.
Or a melting type fuse mounts on the blower housing and is tied into the same circuit as the door switch. When it melts it shuts down everything and this keeps the lint from catching fire.
Also check the belts.
You can turn off the beeping if you would like. Instructions are in the manual. By Pressing the buzzer button it has Loud medium low and off positions.
Remove the rear vent and try the unit...
I'm thinking that your sensor is probably the issue here.
Jun 10, 2011 | Kenmore Dryers
Clothes not drying proparley
, your vent duct is probably obstructed (it happens over time). If your model is the type where you could feel air if you removed the lint trap, do so and turn the dryer on. If you get warm air there, you know it is in the ducting, in the back of the machine, or at the wall vent. Pull off your duct, and give it a good cleaning. Clean out the back of the machine, and the wall vent. When you reinstall the ducting, minimize any twists and turns possible.
If the coils are good, but you get no heat, the problem may be the thermostat or the switch.
Aug 14, 2009 | Candy Washing Machines
The dryer rotates but does not heat, I can reset the button on the back but have to with each use
Aug 11, 2009 | Danby DCD5505W Electric Dryer
My dryer turns, but it doesn't dry my clothes. After drying several time they are still damp
, your vent duct is probably obstructed (it happens over time). If your model is the type where you could feel air if you removed the lint trap, do so and turn the dryer on. If you get warm air there... you know it is in the ducting, in the back of the machine, or at the wall vent. Pull off your duct, and give it a good cleaning. Clean out the back of the machine, and the wall vent. When you reinstall the ducting, minimize any twists and turns possible.
If the coils are good, but you get no heat, the problem may be the thermostat or the motor switch.
Aug 11, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dryer not dryin but heating coils not broken
Bad thermal cut off . The smaller thermostat located at the top of the burner box or if horizontal box , the farthest foreward on the box .
Aug 09, 2009 | Whirlpool Dryers
I want to know how to remove the lint trap (not just the screen but the entire assembly) from a Maytag Performa PYET344AZW front loading electric dryer. The lint screen will not even properly slide back...
Besides drying clothes, dryers also remove lint. This fine, fuzzy material can cause trouble because it blocks dryer lint traps, clogs vents, and fills blowers. Lint can also gather around and in the tracks of the drum rollers, or in and under the pulleys and the drive belt. The result is poor clothes drying or -- sometimes -- no drying. To avoid lint problems, clean out the dryer's lint trap system every time you use the dryer.
To clean the lint screen, remove it from the unit. The screen may be located near or under the door sill, or in the top of the dryer near the control panel. It can usually be removed by pulling it up and out of its housing. Remove the accumulated lint to clear the screen; then replace the screen.
The exhaust vent also collects lint. Vent maintenance involves cleaning the lint from a screen in the dryer's vent exhaust collar and/or at the end of the exhaust vent where it sticks out through a basement window or through an exterior wall. To clean the screen, remove the clamp that holds the vent to the collar, or back out the screws that hold the vent to the collar, or pull the vent straight off an extended collar. Clean the screen thoroughly and replace it in the vent assembly.
To clean the vent itself, use a vent-cleaning brush (available at hardware stores) to pull out any lint deposits. Also check the vent run to make sure that the vent piping or tubing isn't loose at the joints, or -- in the case of flexible plastic venting -- isn't sagging between hanging brackets. Breaks or sags cause undue strain on the dryer's blower system, and can cause drying problems. If the vent pipe or tubing has become clogged with lint, remove the lint by pushing a garden hose or a drain-and-trap auger through the vent to a convenient joint. Disassemble the joint to remove the debris. With this procedure, it isn't necessary to disassemble the entire vent to find the blockage.You can head off problems before they become too serious by providing routine maintenance for your dryer's door gasket, thermostat, timer, and other frequently used parts. Let's discuss how to service these important components in the next section.
how-to-repair-a-dryer-1.jpgTHANK U.. RATE IT...
Sep 11, 2008 | Dryers
Dryer takes too long to dry
This complaint is most often caused by the dryer's vent being blocked with lint. Dryers need to be properly vented, otherwise the moisture in the air can't be properly carried away. Vents that go out the roof are particularly problematic-- the dryer may take far too long to dry clothes and the vent pipe may even drip water that can't be exhausted. Minimum size for a dryer's roof vent is 4 inches. If your dryer has chronically poor drying, if possible, have the vent moved to where it exits a house wall near the dryer. The vent should be made of 4-inch aluminum rigid duct and elbows or, where absolutely necessary, flexible metal (but not flexible thin foil). Do not use flexible plastic duct-- it restricts air flow and is combustible. The dryer should vent outside--never into a crawl space, wall, ceiling chimney, or other type of flue. The bottom of the exhaust hood should be located at least 12 inches above the ground. Here is what to do: 1) Check the lint trap and clean it. 2) Be sure the dryer isn't pushed so close to the wall that it pinches off the airflow through the vent's air duct hose. 3) Check the point where the air duct vents away from the house. Be sure plants, birds, or anything else hasn't blocked it. If the duct vents out the roof, it could easily be blocked with lint. 4) Disconnect the air duct hose from the back of the gas dryer and clean out built-up lint. Note: For safety, first turn off the gas to the dryer, then unplug the dryer; this means you will have to re-light the pilot light later if the dryer has one (read your owner?s manual for proper re-lighting techniques). 5) If necessary, clean out the ductwork from the dryer to the exterior wall where it vents; this may involve disconnecting sections. One trick that sometimes makes this job easier (but only if the dryer duct is fastened firmly at all connection points) is to blow lint and debris through the duct and out the exterior wall vent, using an electric leaf blower.
Jan 18, 2006 | AEG T57800 Electric Dryer
Dryers Logo
276 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
