Question about Jandy Lite 2 Natural Gas Pilot Light Heater
My swimming pool indicator reads a water temperature of 200 degrees f. is it the thermocouple?
    Top Expert:
  • Jandy Master
  • 4,292 Answers
Bad temp sensor
Posted on May 28, 2015
Hs error code what does it mean?
Water Temperature Sensing Error
A) Inlet water temperature sensor is reporting a temperature in excess of 104 degrees. Normal operation resumes 2 minutes after inlet water temperature sensor reports temperatures of 104 degrees or less. This error functions in both normal and remote thermostat modes.
or
B) Inlet water temperature sensor is reporting a temperature change at a rate faster than 6 degrees in 60 seconds, indicating a potentially damaging low water flow condition. Normal operation resumes when temperatures stabilize. If this condition is detected 3 times, the heater will lock-out until the electrical power is cycled off and back on.
Jun 19, 2014 | Hayward H400FDN Low NOx Natural Gas Pool...
Pool heater throws code h5? smoked
HS
or
B) Inlet water temperature sensor is reporting a temperature change at a rate faster than 6 degrees in 60 seconds, indicating a potentially damaging low water flow conditon. Normal operation resumes when temperatures stabilize. If this condition is detected 3 times, the heater will lock-out until the electrical power is cycled off and back on.
Jun 10, 2014 | Hayward H Series Pool & Spa Heater...
Pool heater won't heat water
How big a pool? You normally will not notice a temperature rise immediately. On average, swimming pools will see a one degree rise in temperature every 45 - 90 minutes.
Jan 22, 2013 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Display reading 109 degrees pool at 77 degrees so heater wont turn on
If the display is displaying what the heater thinks the water temperature is then there is likely a problem in the water temperature sensor or the board that reads it. I would be prepared to take the heater apart to measure values with a volt/ohm meter before calling the Sta Rite technical support number at 888-782-7483. They should be able to help you figure out what part is malfunctioning.
Please let me know how this turns out. Thank you.
Aug 30, 2011 | Sta Rite 200 Btu Propane Gas Heater...
Have a brand new AquaPro heat pump for our brand new swimming pool, It worked 3 days and quit. Is saying pool temp is 136 degrees
Thank youfor posting your question here on Fixya.com. It sounds like the water temperature sensor is faulty. I recommendyou call AquaPro Systems at 1-877-278-2797 and they should be able to help youfigure this issue out. I hope this helps.
Ifthis answer does not resolve your issue, please comment with additional informationbefore rating the answer. Positive feedback is especially appreciated once yourproblem is solved! Thank you.
Aug 24, 2011 | Aqua Pro Swimming Pool Heat Pump 125000...
Rapid Heat Bath Heater - indicator light on but not heating water
Bathtub heaters will not produce the heat out a the jets like you would feel coming out of a return jet in a swimming pool.
Bathtub heaters will ONLY maintain whatever temperature water you put in there. they only heat 1-2 degrees an hour. that is for a 1500 watt heater. Many heaters today are only 650 watt or perhaps 700 watt.
Feb 21, 2009 | Jacuzzi RapidHeat In-Line Heater U395000 [...
Pool and Spa Heaters pros and cons
An electric heat pump needs heat available to pump. If it is 30 degrees outside, heating a spa to 102 or so, may be impossible unless the heater has some type of alternative heat source. A properly sized, gas fired heater can take care of a larger range of heating needs. A combination heat pump and natural gas heater, probably with a controller, really makes the issue more difficult, expensive, and would require a lot of study for efficient, cost effective operation. Bottom line: In really mild climates a heat pump might do the job. In cooler climates the gas heater rules. And where a wide range of temperatures and high heat demand is wanted by the customer, a gas heater is the only way to go. A backup heat pump may take years to payout.
Aug 27, 2008 | Saunacore Special Edition Residential...
Jandy Lite 2 Natural Gas Pilot Light Heater Logo
64 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
