Question about Kenwood KRC-208s Cassette Player
Kenwood 208s output cable
Hi , We bought a second hand car, which had this receiver.But the connecector which comes out of the receiver has few outputs missing. So,we want to replace this connector cable with another cable from the market.I wish to know if there is any 'code' problem problem if this is done ? I read it in some other post here.... Thanks in advance...
Eagleeyes
  • 199 Answers
SOURCE: kenwood ks-122 in-dash car stereo/cd changer
Hi check with a multimeter each speaker output, you should have 6voltsa on each connection. if any have either anything other than 6volts then there is a good chance that your power output stage is blown. some unit do have diode protection. so it may not be as bad as it seams.
as a rule you should get half the supply voltage on the speaker outputs.
Reagrds
Mark
Blue ICE
www.blueice-electronics.co.uk
Posted on Feb 25, 2008
  • 30 Answers
SOURCE: Problems with Kenwood kdc-532u car audio
Find the short in your speaker wires.
Good Luck
Leadispenser
Posted on Aug 27, 2008
SOURCE: can not find the code for my kenwood kdc-516s
Same problem, different rig. Bought a bronco with a Kenwood KDC 516s in it, Guy had put a new optima battery in it CODE_ _ _ _  appeared and he has no clue what the "code" is. I have no "remote" and no desire to buy a "remote" for a #$%@ car stereo. Is there any way for me to re-set the code w/out the expense of a remote or a fee from a tech?? the musically challenged, Brew
P.S. The owners manual under the "accessory" section  mentions the KDC x617/v-6017 remotes but fails to mention a remote for the 516s??
Posted on Sep 19, 2008
SOURCE: Ipod to Kenwood 208 S
Get a cassette to ipod hook up. They are just black cassette tapes with a cord coming out that plugs into your ipods earphone jack. They're usually around $20.00
Posted on May 03, 2009
bill_48632
  • 149 Answers
SOURCE: Will the Kenwood KDC 1032 RCA outputs work with an
Hi, if you are trying to get your I-pod to play through your car stereo, then you would need to have the RCA inputs, not outputs. If you connect your i-pod to the stereo outputs it won't work because both things are trying to push sound out of their outputs. If you connect the adapter to the stereo's inputs then it would work.
Posted on Aug 11, 2009
I have a Kenwood KRC 208S and the source will only change to off and tuner. I want to be able to play tapes, but it's not working. Help?
The tape will only come on when you insert a cassette tape. If you do this and it does not work let me know.
Nov 17, 2016 | Kenwood KRC-208s Cassette Player
Kenwood vr606 reciever shutting off subwoofer and centre speaker simultaneously after few minutes/seconds of powering on. WHat's the cause?
The receiver's out put sections are grouped in pairs. Front left and right in one output, rear left and right in second output, and center channel and sub output on the third. Sounds like a semiconductor or semiconductors have gone bad in the center & sub output.
Nov 19, 2015 | Kenwood VR-606 Receiver
Can i hook up my cd player which is a kenwood cd-323m to a vr507 kenwood receiver
hi,
Yes you will be able to connect the same. Connect the line output of the KENWOOD CD 323M to the CD input of the KENWOOD VR507 receiver using a stereo RCA cable. The picture of the cable is added.
ok
Sep 12, 2011 | Kenwood VR-507 Receiver
I want to know the color for power to player
red - ignition, switched power, yellow - constant power, black - ground
Oct 13, 2010 | Kenwood KRC-208s Cassette Player
My kenwood krf-v4060d reciever on/off switch is faulty, it stays switched on for a few seconds and then switchs its self off.can i get a replacement ? i have had not much luck here,any suggestions !
The problem is not likely to be the switch itself. The unit is rpobably going into "protect" mode because of a problem internally. Try removing all the cables and try to turn on the unit. If the behavior remains the same, the output section requires repair. The most common failure is the output transistors. Expect a parts cost in the $40-$60 range.
Dan
Dec 09, 2009 | Kenwood Audio Players & Recorders
Jan 16, 2009 | Kenwood KRC-208s Cassette Player
Subwoofer doesn't turn on
I felt supid this morning.
I bought a high end cable for my subwoofer.... and it did not work but a regular RCA Cable did. When I went to put the cable back in the package I saw an arrow pointing one way, I turn the cable and it works great.
Dec 12, 2007 | Kenwood VR-405 Receiver
Kenwood KRC-208s Cassette Player Logo
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Mike Duncan
Mike Duncan
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
