Question about Health & Beauty
How can I replace the Norelco T760 battery?
Only one screw is visible. Does the case snap apart or is there a hidden screw(s)?
brector3
  • 1602 Answers
SOURCE: Replace battery
It is a #8 torx screwdriver. if needed, you can purchase one from shaveroutlet.com. See link below
http://shaveroutlet.com/screwdriver-access-tool-for-norelco-shavers-and-some-braun-p-262.html
Posted on Mar 01, 2010
SOURCE: How to replace battery pack for a Norelco 6885xl electric shaver
The battery pack is soldered to the shaver's circuit board. Yes, it's a poor design in building something that people can't readily service unless they have a soldering gun, ******, and wick, plus patience. However, there are plenty complaints online already, and my shaver won't get fixed by b-tching some more.
There are 2 choices for replacement:
1. Bring or mail it to a service center to have the batteries replaced. The fee usually runs $29.99-$39.99, which includes the battery, parts, labor, lubrating your motor, cleaning the interior, cleaning/stripping the cutters, heads, and trimmer, plus return shipping.
2. To save yourself $26-33 bucks, make sure you know how to solder and have the equipment described above. you can find single NiCad AA with solder tab for $3ea or a pair for about $7.95+. Table the batteries together, solder a single tab across +/- on one side, and solder the others onto their respective tabs in your shaver.
For me, I'd love nothing than to hobby around and do it myself, but with 3 kids, a full-time, job, Wii, and other hobbies, it's easiest to just send it out... some services will guarantee to have it done within 2 days of receipt. You'll just have a lil beard to test it out when you get it back. :-)
Posted on Oct 16, 2008
  • 161 Answers
SOURCE: won't charge
They may not be replacable? you can try the Norelco website for some info but these days theres a lot of devices that do not have end user replacable batteries
Posted on Mar 20, 2009
  • 4 Answers
SOURCE: norelco t860 how to take apart to replace
The battery can be replaced. There is a single AA NiCd battery w/ tabs soldered into the main circuit board.
To open up the trimmer, first take the silver screw out (located near the lower back side). Then pull the trim guard off the top (should come off easily). Next, the rubber-like ring used for adjusting the trim height needs to be pulled off -- this can be difficult but just work your way around and ease it off. Finally, the metal clip on the end of the trimming head needs to be removed, and the plasic case can then be popped open, revealing the circuit board.
If you're not comfortable soldering or disassembling it, it can likely be done at a local Batteries Plus store.
Posted on Mar 30, 2010
SOURCE: How to open case on Norelco T-3000 beard trimmer
Remove the bottom screw. Next, the on/off slide switch has to be lifted off carefully with a small flat screw driver. Its kept in place with a small spring steel clamp. After you've removed it lift off the steel clamp and remove the slide mechanism by carefully twisting it out of position. Once that's done it will twist open easily.
Posted on Dec 24, 2010
Norelco 5822 XL - need new battery, but can't determine how to take apart!
There are just two screws on the back. Remove the screws to take off the back cover. You can then access the batteries.
You will find replacement batteries at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-battery-pack-for-most-norelco-more-p-278.html
If you are not able to complete the repair yourself, shaveroutlet.com can do this also. See link below
http://shaveroutlet.com/professional-battery-replacement-for-most-models-p-374.html
Mar 14, 2010 | Norelco Reflex 5822 XL Electric Shaver
Battery door replacement
Does this mean you have a replacement door already?
If so, you will need to figure out how the camera comes apart. This is not always easy to do. I suspect there will be screws or snaps hidden. Improper dis-assembly will cause damage to the case and/or finish.
I would contact Canon and ask if there are any repair shops near you that they could recommend.
Joe
Mar 08, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
How to replace battery in Norelco 6867xl
You will need to remove the two screws on the back to remove the back cover. Inside, you will first need to remove the two white plastic pieces that the screws you just removed screw into. The larger one snaps in and will have to be popped out from the bottom on each side. The other one has two screws that need to be removed. Once these are removed, you will be able to better access the batteries.
The batteries are soldered to the circuit board but instead of unsoldering them, I suggest carefully breaking the solder tabs off of the ends of the batteries. This leaves the old tabs still attached to the circuit board and you can them simply solder the new batteries to those old tabs. This prevents you from having to put a hot soldering iron directly to the circuit board.
You will find batteries for your model at shaveroutlet.com. See link below.
Feb 10, 2010 | Norelco Quadra 6867 XL Electric Shaver
How do i replace my screen?
you will have to take the phone completely apart, and you will most likely need special tools to open it. unscrew all screws you find, there could be hidden screws under soft objects and labels.
ones you have the screws out the case should snap open from the corner, with the help of a flat screwdriver.
ones you have the case apart, you will need to unscrew and disconnect the display. then replace it with a new display, and put everything back together.
all you need are the tools, maybe some special screwdrivers etc and you can do it.
Jun 07, 2009 | LG CHOCOLATE VX8500 Cellular Phone
I have removed all the screws from my Evesham W730-K8 laptop because i need to get to the power socket inside, but the laptop still won't come apart. What am I missing?
The best rule to remember is do not force it apart if it does not come apart easy then look for a hidden screw the case does have snap locks on the sides try starting at a point that you can get your fingernail into and slowly move the part that is not coming apart apply a little force but make sure that all screws have been removed you may have to remove some of the thin plastic covers and the battery to make sure all of the screws have been removed
Jun 06, 2009 | Computers & Internet
I need to replace battery. Is it easy to get back off? Manual says I need to take it to repair shop
Basically to take any phone or pda apart, unscrew all screws and look for hidden screws under soft objects or labels etc.
ones all screws are out, use a small flat screwdriver or a case opener tool to carefully open the case of the phone or pda. it should snap open, very likely plastic holders on the corners that keep the case closed, carefully snap them open / off, don't break them.
May 13, 2009 | Mitac MIO P350 PDA POC PC+ GPS SAT NAV...
Casio JF-100TE Battery Replacement
Remove two screws at top. Then there are 3 hidden **** on both the right and left side of unit for a total of 6. Pry the case apart starting at top on one side. Then slide a small thin screw drive down the side till you come to first *** and pry just a little till it comes apart. The first *** is on the side at display height center. The next *** is between the GT key and division key on side. The next *** is on side at top of plus key. The case will now swing open like a door with the same 3 **** on on side of case. The top of case **** are female. The bottom of case **** are male. The battery slides in and out. Make sure you get + and - right.
My problem is I changed the battery but display still only works with solar power.
Jan 22, 2009 | Casio JF-100TE Calculator
How do I open the case of a Philips 107S 17" CRT Monitor?
Recently most of monitors Like samsung and LG appears 2 screws at the bottom and Internal fixing at top .push it to appear some Gap of top side
Sep 30, 2008 | Philips Computers & Internet
HELP ME PLEASE!!!!!!!!!!! I CAN'T GET IT APART!!!!!!!!
Have you removed the battery, and checked for screws there? Looked under the memory cover. Chgeck the the two halvers of the shell are not 'snap' together?
Jun 24, 2007 | Acer Aspire 3003WLCi Notebook
Health & Beauty Logo
506 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
