Question about Samsung RS2534 Side by Side Refrigerator
I have a Samsung fridge freezer SR-S2028CSS the problem is it is beeping for no reason, not continuous just intermittently. When it beeps the lock light comes on and then goes off. I have tried locking the functions but it doesen't work. Any ideas how to disconnect the buzzer. Works perfect just this buzz. Thanks.
2 Suggested Answers
  • 3 Answers
SOURCE: samsung side by side fridge freezer sr-s2028css
Have you tried Appliance DIY Repairs? They sell a repair kit for that model.
Posted on Feb 25, 2011
E240B Fridge Freezer door open alarm goes even when door closed.
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.
Cause of Beeping Noise in Frigidaire Refrigerator eHow
Dec 22, 2016 | Fisher Refrigerators
Samsung refrigerator alarm beeping continuously
May 15, 2016 | Samsung Refrigerators
Samsung American fridge freezer SR-S2028CSS keeps beeping and randomly turning the fast freeze on and off.
quite possibly it needs some freon added to the system and only service people can do this
Jan 06, 2016 | Samsung Refrigerators
Samsung side by side fridge freezer sr-s2028css. having seeked advice from refridgeration engineer was told compressor was not working, had a new compressor fitted by another engineer but still existing...
Did they change the start relay as well as the compressor? On Samsung refers the start relays do not come with the compressor. If they didn't its possible that the start relay is clicking.
Oct 07, 2010 | Samsung Refrigerators
Samsung SR S2028CSS Fridge Freezer - Fridge temperature problems
Try setting it to lower temperature. If that don't work the thermostat is bad.
Jun 28, 2009 | Refrigerators
Freezer temperature display keeps flashing
on the main circuit board on top of the fridge is a button with "test" on it. hold that in for a few sec, it should start beeping at you. push it again and it will beep again, do this about 4 time till it goes quite. this may fix it but the reason for it is prob your sensor is covered in ice, you need to leave it off with the doors open. there are 2 drain pipes at the back of the fridge ( bottom ) defrost it till no more water comes out of these, when you think its done, leave it for a few more hours and if any water comes out your not defrosted yet--- mine took almost 3 days.
Jul 29, 2008 | Samsung CoolTech Plus / Basic Bottom Mount...
I am having problems with my samsung fridge model - SR-S2028CSS
does it freeze at all? you may have a problem with the coolent in the back of the fride which if so (depending on the cost of the fride) may be cheaper to replace, also the dial you use for selecting the freeze level could be faulty
Feb 19, 2008 | Refrigerators
Samsung SR-L39 fridge freezer switching off
replace the thermostat of the freezer
Sep 16, 2007 | Refrigerators
Samsung RS2534 Side by Side Refrigerator Logo
198 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
