Question about Yahoo Messenger
Login problem i am trying to log in to my istant messenger but it is givin me an error
    Sniper:
  • 73 Answers
What error message?
Posted on Oct 28, 2008
Hi I am getting 81003002 error for yahoomessenger and also for mail. Can u please help me out from this error.
Hi Kiran,
  1. Try to login after some specific time , and check if you are able to login successfully,
  2. After several attempts in the login fails, then you need to restart the PC and try again while you are connected to the internet.
  3. Make sure that you have not logged in to yahoo mail from your browser/internet explorer, if you have then you need to log out and check logging in the yahoo messenger only.
  4. Remove the application via uninstall from the add / remove programs option , and then delete the registry keys related to yahoo messenger or the complete yahoo messenger folder and then install it again , as many time it would work.
  5. To remove the registry keys you need to start regedit.exe from the run command in the start menu and search for yahoo messenger for e.g. "HKEY_CURRENT_USER\Software\Yahoo\Pager"
  6. Delete the folder for pager if it exists.
  7. Resintall yahoo messenger , and try to login again and it should work fine.
Please get back to me in case you have any queries, hope this solution would solve your problem, your feedback is valuable and it would be appreciated.
May 16, 2011 | Yahoo Messenger
When i login to yahoo messenger or yahoo mail it says that i logged in from another computer or device and disconnects . I ' ve allready changed password but nothing changes. When i go to yahoo mail it...
if your yahoo messenger is unable to connect, it all depends on firewall that blocks messenger connectivity. Try this open yahoo messenger> click on messenger> click on connection preferences> select no proxies> click OK. Now try login in. Cheers,please comment on this post by telling how helpful it is
Oct 31, 2010 | Yahoo Messenger
Yahoo Mail Login problem
There was a problem accessing your account. Please try again in a moment.
Error #1
is this you getting ??
Apr 29, 2010 | Yahoo Mail
Error 81003002
Check you password is correct...try log in with webmail...http://login.yahoo.com or http://webmessenger.yahoo.com ... please let us know...
Thanks
Dec 21, 2009 | Yahoo Messenger
When I try to login to yahoo messenger I get error 81003004
hi,
Follow these methods:-
First method:
1. go to messenger menu
2. select connection preference/ preference
3. the tab will automatic select connection preference, if it doesn’t, select it manual.
4. change your internet conection type, for my problem i choose broadband(DSL/Cable).
Second Method
For me, it was because I had set a localhost (127.0.0.1) proxy in Internet Explorer for anti-filtering purposes, thru which Y! Messenger was trying to connect. So I had to remove it to get it done.
just go to:
Control Panel > Internet Options > Connections (tab) > Lan Settings (button)
then uncheck the Proxy server checkbox.
Thanks!
Jul 17, 2009 | Yahoo Messenger
Messenger error 81003005
here are some causes: Firstly; this error occurs when your connection preferences are not properly set. I'm not talking about your Yahoo! ID and Password here, but you may need to adjust certain features depending on what network you're on. Let's says for example, if a firewall protects your network, it may block yahoo messenger when it tries to connect to the server. You need to change your connection settings, click the Messenger menu in yahoo messenger and select Connection Preferences. Select Firewall With No Proxies. Select your Internet Connection type from the pull-down menu at the bottom and enter your Home Country if the adoptions aren?t grayed out. Click OK and login again using the new settings. If this option doesn?t work, click Connection Preferences in Yahoo! Messenger again and select No Network Detection. Try to login again using the new settings. In some instances, you may need to provide yahoo messenger with the IP address of your firewall or proxy server (you can get this information from your network administrator or from your Internet service provider). Click Messenger and select Connection Preferences again. Select Use Proxies. Enable either the HTTP Proxy or the SOCKS Proxy as needed and provide the proper address. Click OK and login again using the new settings.Secondly; if you are using IM9 there are sign in problems. This is what yahoo has to say. Try an updated version of Yahoo! Messenger 9.0(9.0.0.2128). This latest build includes a fix for the sign-in issues that have been affecting some users. If you were seeing an error code?81003005? when trying to sign in, this latest version may fix that problem. Even if you were experiencing a different kind of sign-in issue, I recommend installing this latest version. Hope it was helpful!
Thanks.
Jun 16, 2009 | Yahoo Messenger
Cant login in to ym
You have not given the error which you are getting. Have you tried to login with diff id and the id which you can't login can be logged through other PC. If this is the case then your IP is banned by yahoo. You are advised to surf google on how to unban your IP from yahoo messenger. In case you need further assistance kindly revert back to us.
Jun 15, 2009 | Yahoo Messenger
Unable to Login to Yahoo Mail.
Hi yahoo
i am unable to log in my yahoo account..if i typed my user name and password ..again it comes same log in page ..
and i am able to access my email in my blackberry device ..only my desktop i am not able to log in ...
pls help me some one for this problem it will grate for me
Nov 30, 2008 | Yahoo Mail
Log in error 81003005
Here's how I solve it:
1. Open your Internet Explorer
2. Go to Tools > Internet Options then click the Connections tab
3.Click the LAN Settings button and a new dialog box will open
4. At the new dialog box, look for the Proxy server checkbox, if this is checked, uncheck it.
5. Then your done, click OK button for the dialog boxes.
6. Try logging in to your Yahoo Messenger account.
Oct 18, 2008 | Computers & Internet
Yahoo Messenger Logo
52 people viewed this question
Top Yahoo Computers & Internet Experts
micky dee
Mike
fixrfast
Level 1 Expert
Are you a Yahoo Computer and Internet Expert? Answer questions, earn points and help others
