Question about Garmin Nuvi 1390 Car GPS Receiver
Pin number is lock
Was sold to me w.a pin number set on it..now doesnt do any...theres no battery to remove..just the usb to charge and power buttom on the top left screem
    Top Expert:
  • Garmin Master
  • 74,473 Answers
Hello
To know all about the setting and unlocking its security code, just goto its user manual page [46]. If you haven't it user manual with you now, just downlaoad it free from internet.
Try
www.retrevo.com
http://www.dataentryjobs.us/67948.html
gps-device.pikimal.com/garmin-nuvi-1390lmt.../garmin-nuvi-885t-4...Cached
Posted on Feb 25, 2012
How to open APC UPB10 battery pack to change the chargeable battery?
1. Remove front cover by sliding front panel down.
2. Install 4 new AAA (LR03) batteries (sold separately) and replace cover.
3. Turn unit on by sliding ON/OFF switch towards USB port. LED will
illuminate.
4. Plug USB charging cable (sold separately) into the Emergency Power Pack's USB port.
5. Plug the other end into your mobile device. (Make sure you do this last, as a few devices will not recognize the charge otherwise). Your device is now being charged
Apr 27, 2014 | Computers & Internet
Tip
The iPod USB Charger
<p>The USB cable that came with all iPod has two purposes: to your device to your computer so you can update and add music, and iPod to charge. All iPods have a lithium ion battery stops charging when the battery is full, the total life of your battery is not affected if you leave the iPod is connected to a power source. It usually takes four hours to recharge most iPods. <br /> <p><br /> <p>1. Connect the USB connector into an available high-power USB 2.0 port on your computer. Low-power USB ports, such as those in external keyboards and hubs do not work. <br /> <p><br /> <p>2. Connect the 30-pin connector at the other end of the USB cable 30-pin connector on your iPod. If you charge an iPod shuffle, there is no dock connector port. Instead, use the connector on the other end of USB cable that fits in the headset. Set the iPod down and let it recharge. <br /> <p><br /> <p>3. Unplug the USB cable when the iPod battery indicator is full. If you charge an iPod shuffle, the green light will appear. <br />
on Aug 09, 2011 | Apple iPod touch
Battery not charging in asus f5
Hey,, Turn the laptop over and remove the battery, There is a lock pin or switch there that holds it in place. There may be a tape covering the charging pins remove it.. If its clean chances are you got a defective battery.. You will need to return it to the store to get it replaced.
Dec 28, 2012 | ASUS F5R-AP038A Notebook
It took a lightening strike. is there a power reset on the unit?
There are two ways to do a reset on *********** board.
CMOS Jumper
1. Open your computer.
2. Look for a mother board jumper labeled as JBAT1, CLR CMOS, CLR TC or just a push button for a mid to high-end mobo. it should be placed near the BIOS or beside the CMOS battery.
3. It should look like this, as you can see there is a white triangle indicator and a number 3. The pins 1,2 are shorted, try to removed the pin and short pins 2,3.
4. Now put the jumper back to pins 1 and 2, it's all done. now you can go to bios and load defaults before you can change values.
CMOS Battery
1. Look for a 3v battery on the mother board.
2. Press the lock downward to remove the battery.
3. After removing the battery re install the battery. by doing this you have successfully cleared BIOS settings.
NOTE: 1. Check the fuse of your AVR if it is busted. replace the busted fuse with same rating.
2. Check your power supply. If it's dead try to fix it by replacing the fuse but it will require soldering tool and skills. 3. Your computer might still work but in my case the usb ports can only read flash drives after the lightning and the network interface card is busted.
Hopefully this information helps.
Thank you for using FixYa.
Aug 14, 2011 | Computers & Internet
Where can i get pyramid-9 PCB No BA41-00167A manual book for setting up power switch,hdd led,reset etc connection setting ???????????
Hello, i was made a search in google, i guess you must look it too, and a don't get nothing, but, I think i've a solution for you, according my own experience, i've installed 2 kinds of different MB, and, althoug there are different brands, the connection pins are the same, ie, the front panel connector that connect HDD Led, Power Led, Reset and Power, is a 9 pin conectors (really have 10, but 1 pin is cut for reference) and commonly is called PANEL 1
Then, i guide you
2 8
. . . . this will be 2,4,6 and 8 pins (from left to right)
. . . . . this will be 1,3,5,7 and 9 pins
1 9
Power Led + in pin 2
Power Led - in pin 4
Power Button # or + in pin 6 (It's no critic the orientation, it have no polarity, is a push buttom)
Power Button GND or - in pin 8
HDD Led + in pin 1
HDD Led - in pin 3
GND from Reset Buttom in pin 5
# from Reset Buttom in pin 7
THE PIN 9 has no connection
Source: My own experience, and check this instalation manual, at 21st Page
http://download.asrock.com/manual/Wolfdale1333-D667%20R2.0.pdf
Jan 07, 2011 | EPoX EP-3PTA Motherboard
My mix max doesnt turn on. it was working and all of a sudden it said "connect to usb". i did then it turned off and it doesnt turn on anymore i tried to charge it but it still doesnt work. HELP!!! please.
If this doesn't help, the MixMax must be opened up. By CAREFULLY prying the corners loose, you can remove the back. You will break several of the smaller retainer clips during this, but it's OK. The main retainers will hold the unit together just fine once completed. Once opened, unplug the battery. NOTE THE ORIENTATION of the red and black wires. Use any 5V 500ma or less power supply and connect to the battery. Charge it for at least 30 seconds. return the battery to the unit, and reassemble. DO NOT TURN IT ON. Plug the USB cord in and let it charge completely.
The MixMax will disable the power if there is an unexpected power interruption, then the battery will run completely dead. Once dead, it cannot detect the USB when connected.
Jul 30, 2010 | Disney Mix Max Digital Media Player
Bios password
After removing the battery take a pice of wire or piece of metal and short the two battery terminals, where the battery  goes, together in  order to discharge the memory chips that hold the code,the restart it after replacing the battery.The charge can be held for hours without shorting it.
Jan 27, 2009 | Toshiba Satellite R15-S822 Tablet PC
IPOD 2GB LOCKED UP
let it charge fully
if it doesnt charge, then the USB cable is bad
the pins can be pushed back and wont charge
so get a new cabel and get it charged!
May 29, 2008 | Apple iPod nano
Reset buttom
Try doing a cold reset ( no data loss) disable the battery by sliding out and then back in, the battery pin at the back base of the phone without removing the battery PLS do not remove the battery!!!!.
If that dosen't work then you may need to remove the battery and do a default reset (you loose your phone settings) you should back up your data first before trying this.
Feb 21, 2008 | i-mate PDA2k Pocket PC
I have a GoGear device that won't charge
Hi, I had the same problem with my SA31xx, when I plugged it into my PC it made the normal usb sounds and then a flash symbol appeared over the battery on the screen. It would not charge at all, I replaced the usb cable and it now works perfectly. Hope this helps.
Oct 03, 2007 | Philips GOGEAR SA6045 MP3 Player
Garmin Nuvi 1390 Car GPS Receiver Logo
97 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
