Lcl1608wh 60898000050 burnt out
Modle number lvd198w
Modle number 2658866290 Where is the heat element on this dryer There is no heat
Usually behind the drum which means you might have to remove the drum to replace it.
Oct 30, 2017 | Dryers
My key board will not stay lite Modle Number G736
Does it go off on battery and AC power? Open power settings, change to High Performance, open Advanced Power settings, adjust settings.
Dec 17, 2012 | ASUS Computers & Internet
I have a jvc modle av-27920 that will not come on
This model should be covered by the Howard Sams Photofacts---you can buy one for it online with the model number--many large library's have them in archive as well.
3 burnt means a problem in that area which is why you want the schematic as well.
Nov 04, 2012 | JVC AV-27920 27" TV
Light blinks 3 times went off then started to smoke
Time to unplug set and have a look inside for the burnt part---all parts will have a location number on the board next to them.
Jun 10, 2012 | RCA HD52W59 HDTV Projection Television
I can't find my modle #--My modle is HD52W67- but
Replace the Flyback number 270125 and CP150 they are both available at the following link and they provide step by step instructions.
http://servicemanuals.vstore.ca
Jun 09, 2011 | RCA HD52W59 HDTV Projection Television
My modle number is aruf 036-00a-1 my serial number
MY MODLE NUMER IS CPLE42-1 SERIAL NUMBER IS 010940037
Aug 04, 2010 | Goodman CKL36AR36 Air Conditioner
Have a Disney modle tv and need the code for a remote the remote is not working now modle # P1300NTV
Try setting it to cable remote--see manual or check back label for manufacturer's parts and accessories phone number.
May 19, 2010 | Disney 13" TV
I have a behringer modle GMX112 amplifier. When I
Well the easy thing is that whatever is burnt up will be easy to spot and of course need replacing. So take the top off and see what you can see of it. That won't cost you anything. The problem is if the thing that has burnt up did so in a way you can't tell what it is! You will have a hell of a job finding out what it is. In which case you might as well let a repair shop do all the hard work! However if you can read the numbers of any damaged part(s). You can put them into google and find out what they cost etc. At least then you have the options of buying them yourself or working out what it might cost for fixing it assuming nothing else went!
May 10, 2010 | Audio Players & Recorders
F3 Error Code - GE Electric Oven JTP18
all ge codes f3 are saying ot replace thermal sensor, you can check the harness connecting them for a pinched or burnt wire i guess, as far as getting a part number , you can enter complete modle number her e and look for the sensor, i checked just the partial number you gave and a few different ones showed up
http://www.searspartsdirect.com/partsdirect/index.action
Apr 22, 2008 | GE Profile JTP18 Electric Single Oven
Televison & Video Logo
103 people viewed this question
Top Televison & Video Experts
